VSDK installing need activation code ?
5,610 次查看
liuqimin
Hello:
when VSDK installing ,a windows popup that ask acivation code,like following picture. where we can get this code?
Best regards!
Liu qimin
5,222 次查看
paulvlase
Hi @ qimin liu,
Unfortunately the link from where to get the activation code for APU compiler is shown in a previous step of the installation. It is easy to miss it, we did that a lot of times at the beginning.
To get the activation code follow these steps:
1. Go to https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=NXP-APU-COMPILER
2. Read the Software Terms and Conditions and click the I Agree button if you are OK with them.
3. Click on the License Keys tab.
3. Here you will find the Activation Code
Hope this helps,
Paul
5,222 次查看
liuqimin
Hi Paul:
    I can find the activation code now.
 thanks!
 Liu qimin
5,223 次查看
paulvlase
Hi @ qimin liu,
Hope this helps,
Paul
