Develop camera with S32Design integrated environment
4,847件の閲覧回数
fgd455464199
 Is there a way to get data directly from CSI?I write my own graphic algorithm, and I write my own Framebuffer output.I just want to get the image data a little bit easier
2 返答(返信)
3,790件の閲覧回数
Nanettebreaux
S32 Design studio for Arm/Power/Vision installer pops up the "S32DS Activation" dialog where you first enter your activation ID and select activation type as offline. The Offline process will require to save an activation request file -"request.  Home Bargains Portal
4,792件の閲覧回数
paulvlase
Hello 国栋 范,
This community space do not cover the topic you need assistance on.
Please create new NXP support case according to following procedure:https://community.nxp.com/docs/DOC-329745
Hope this helps,
Paul
