How to run uboot in NOR flash over uboot running from SD?
2,714件の閲覧回数
emras
I have t1024rdb without uboot and anything else..
I have done (sudo dd if=u-boot-with-spl-pbl.bin of=/dev/sdc seek=8 bs=512) and managed to start uboot from SD card, with proper switch configuration. How can I copy the uboot which runs in SD card to nor flash over uboot which runs in SD card ? After all, I want to get uboot run in nor flash.. Could you guide me ? exact solution will be appreciated.
Best Regards
0 返答(返信)
