some error when testing dpdk on LS1043ARDB
joeqiao
I have a question in using DPDK  on LS1043ARDB ,the SDK is QorIQ-SDK-2.0-1703
i deployed the usdpaa image on  SD card;  flow the SDK document doing DPDK test ,flowing is the  error log:
ls1043ardb login: root
root@ls1043ardb:~# cd /usr/bin/dpdk-example
root@ls1043ardb:/usr/bin/dpdk-example# export DPAA_NUM_RX_QUEUES=1
root@ls1043ardb:/usr/bin/dpdk-example# fmc -c /usr/bin/dpdk-example/extras/usdpaa_config_ls1043.xml -p /usr/bin/dpdk-example/extras/usdpaa_policy_hash_ipv4_1queue.xml -a
root@ls1043ardb:/usr/bin/dpdk-example# mkdir /mnt/hugepages
mkdir: cannot create directory '/mnt/hugepages': File exists
root@ls1043ardb:/usr/bin/dpdk-example# mount -t hugetlbfs none /mnt/hugepages
root@ls1043ardb:/usr/bin/dpdk-example# cd /mnt/hugepages
root@ls1043ardb:/mnt/hugepages# ls
root@ls1043ardb:/mnt/hugepages# /usr/bin/dpdk-example/l2fwd -c 0x2 -n 1 -- -p 0x1 -q 1
EAL: Detected 4 lcore(s)
EAL: No free hugepages reported in hugepages-2048kB
PANIC in rte_eal_init():
Cannot get hugepage information
1: [/usr/bin/dpdk-example/l2fwd(rte_dump_stack+0x20) [0x454938]]
Aborted
