problems building
problems building
martinleisner
I'm building yocto releases for L1012A freeway.
Is there a document which entails "what's in different images" (or is this an exercise for the interested reader).
Building both scarthgap and styhead, when I attempt to create
fsl-image-network-full-cmdline
pktgen-dpdk (21.11.0) had a number of compile problems.
I fixed some, added some ignore warnings flags (and before tried to fix the missing prototypes problems (mostly stdlib.h), then I got "undefined symbols" I couldn't find.
I tried some "howtos" about removing recipes, but none worked....Is there a good way to remove recipes (or do I need to remove a containing recipe)
Marty
Marty
Oswalag
Please try to build your image with the mickledore branch, it should work without any issue.
martinleisner
mickledore does the same as a few other recent yocto releases.
fail the same way.
When I removed some of the compiling errors, others (undefined symbols) appears....
Following a few posts on how to remove recipes from yocto failed....
Oswalag
I didn't have the errors you mentioned on mickledore, please follow the LLDPUG, install all the dependencies and try again.
