prebuilt toolchain for LS1043ardb
dibyarekha
Hi All,
I am working on LS1043ardb, I am following the guide available at https://www.nxp.com/docs/en/user-guide/LSDKYOCTOUG.pdf
as source.codeaurora.org is unable to access, I have downloaded the repository from
repo init -u https://github.com/nxp-qoriq/yocto-sdk -b kirkstone -m ls-5.15.71-2.2.0_distro.xml
_________________________________________________________________________________
For this repo, which prebuilt toolchain I should use for cross-compiling the application program.
Right now I have downloaded the prebuilt toolchain from https://www.nxp.com/lgfiles/sdk/lsdk2004-yocto31/fsl-qoriq-glibc-x86_64-fsl-toolchain-aarch64-toolch... ,
but it is giving library linking errors while compiling my application
Please tell me, where can I get the latest prebuilt toolchain
dibyarekha
prebuilt toolchain fsl-qoriq-distro version 4.0.4 need to be used
June_Lu
Please download Layerscape Software Development Kit – Updated to download from GitHub instead of CodeAurora when source.codeaurora.org is unable to access.
dibyarekha
Hi @June_Lu,
already I have downloaded from github, as I mentioned in my question. But My question is ,which prebuilt toolchain I have to use for compiling the application program?
dibyarekha
