Good moorning,
I built an image with yocto real time edge project.
My goal is to make a bootable sd card, so I want to start the board ls1046ardb-pb in SD boot mode.
I can see in my /deploy/images/ls1046ardb folder that I have a .wic image. However that image contains only device tree, kernel and rootfs. How can I add rcw firmware and u-boot.
Otherwise, Is there another method to format the SD card and deploy the different elements.
Thank you
已解决! 转到解答。
I finally resolve my problem.
It was only a problem of DIP switch ( see doc RTEDGEYOCTOUG_v2.7 chap 7.1).
The image .wic generated by yocto real time edge contains already RCW and u-boot image.
Please refer to Real-time Edge Software User Guide
7.2 Building eMMC images for Layerscape platform
7.4 Deploying eMMC images with separate images on Layerscape Platform
You will find the path of RCW, U-boot and how to flash them.
