ls1028ardb yocto-sdk build problems
793件の閲覧回数
mclifford
I'm trying to follow the instructions here:
https://github.com/nxp-qoriq/yocto-sdk
to build the OS and SDK images for the LS1028ARDB
It appears that walnascar is the default branch, but the build fails if i use the instructions at the link above.
mkdir yocto-sdk
cd yocto-sdk
repo init -u https://github.com/nxp-qoriq/yocto-sdk -b walnascar
repo sync --force-sync
. ./setup-env -m ls1028ardb
bitbake fsl-image-networking
this fails with 3 errors:
- sysvinit installation errors
- dtc-native compile errors
- util-linux-native compile errors
I've also tried the instructions from this document which fail in a different way even if you work around the incorrect instructions (the specified "ls-image-desktop" does not exist):
https://docs.nxp.com/bundle/UG10081_LLDP_L6.1.55_2.2.0/page/topics/how_to_download_flexbuild.html
I also found the flexbuild option, and followed the instructions here:
https://github.com/nxp/flexbuild
git clone https://github.com/NXP/flexbuild.git
cd flexbuild
make docker
make ls1028ardb_defconfig
make all
this also fails with the error:
W: binfmt_misc not found in /proc/mounts -- not mounted
What are the correct instructions for building the OS image and SDK?
Matt
5 返答(返信)
636件の閲覧回数
mclifford
Thanks for the input but the walnascar-lsdk branch fails with similar errors as the walnascar branch i described above.
This is the output for
bitbake -k fsl-image-networking-full
Summary: 4 tasks failed:
~/walnascar-lsdk/sources/poky/meta/recipes-core/sysvinit/sysvinit-inittab_2.88dsf.bb:do_install
log: ~/walnascar-lsdk/build_ls1028ardb/tmp/work/ls1028ardb-fsl-linux/sysvinit-inittab/2.88dsf/temp/log.do_install.1267212
virtual:native:~/walnascar-lsdk/sources/poky/meta/recipes-core/util-linux/util-linux_2.40.4.bb:do_compile
log: ~/walnascar-lsdk/build_ls1028ardb/tmp/work/x86_64-linux/util-linux-native/2.40.4/temp/log.do_compile.1304034
virtual:native:~/walnascar-lsdk/sources/poky/meta/recipes-kernel/dtc/dtc_1.7.2.bb:do_compile
log: ~/walnascar-lsdk/build_ls1028ardb/tmp/work/x86_64-linux/dtc-native/1.7.2/temp/log.do_compile.1321834
~/walnascar-lsdk/sources/poky/meta/recipes-devtools/flex/flex_2.6.4.bb:do_compile
log: ~/walnascar-lsdk/build_ls1028ardb/tmp/work/aarch64-fsl-linux/flex/2.6.4/temp/log.do_compile.2409352
Summary: There were 17 WARNING messages.
Summary: There were 6 ERROR messages, returning a non-zero exit code.
Matt
619件の閲覧回数
yipingwang
Please install the host packages as the following.
sudo apt-get install build-essential chrpath cpio debianutils diffstat file gawk
gcc git iputils-ping libacl1 liblz4-tool locales python3 python3-git python3-
jinja2 python3-pexpect python3-pip python3-subunit socat texinfo unzip wget xzutils
zstd efitools
If your problem persists, please send the log file ~/walnascar-lsdk/build_ls1028ardb/tmp/work/ls1028ardb-fsl-linux/sysvinit-inittab/2.88dsf/temp/log.do_install.1267212 to me to do investigation.
605件の閲覧回数
mclifford
Thanks for the reply, it turns out it was my fault, I was using the wrong version of ubuntu and stupidly ignored the warning in the yocto output.
I switched to using a 24.04 dev container and following the instructions in:
  • Layerscape Software Development Kit User Guide for Yocto: UG10374.pdf
to do the build and that worked fine.
Matt
760件の閲覧回数
mclifford
after posting this, I discovered Debian Linux SDK User Guide which has some pre-requisites not listed in the flexbuild readme.md. This appears to allow me to generate a Debian based image for the LS1028ARDB.
What are the instructions for generating an SDK in a similar way to the Yocto environment? or do you recommend a standard cross-compiler?
Is the Debian solution now the recommended OS for this platform? Yocto feels more appropriate for an embedded system.
Matt
699件の閲覧回数
yipingwang
Please use the following latest Yocto Linux SDK release.
The release includes both source code and prebuilt images as listed below:
Branch: walnascar-lsdk
Name
Description
1
boot_ls1028ardb_lts_6.12.tgz
Bootpartition image for LS1028ARDB
2
boot_ls1043ardb_lts_6.12.tgz
Bootpartition image for LS1043ARDB
3
boot_ls1046ardb_lts_6.12.tgz
Bootpartition image for LS1046ARDB
4
boot_lx2160ardb-rev2_lts_6.12.tgz
Bootpartition image for LX2160ARDB
5
firmware_ls1028ardb_uboot_emmcboot.img
BSP firmware image for LS1028ARDB eMMC boot
6
firmware_ls1028ardb_uboot_sdboot.img
BSP firmware image for LS1028ARDB SD boot
7
firmware_ls1028ardb_uboot_xspiboot.img
BSP firmware image for LS1028ARDB XSPI boot
8
firmware_ls1043ardb_uboot_nandboot.img
BSP firmware image for LS1043ARDB NAND boot
9
firmware_ls1043ardb_uboot_norboot.img
BSP firmware image for LS1043ARDB NOR boot
10
firmware_ls1043ardb_uboot_sdboot.img
BSP firmware image for LS1043ARDB SD boot
11
firmware_ls1046ardb_uboot_emmcboot.img
BSP firmware image for LS1046ARDB eMMC boot
12
firmware_ls1046ardb_uboot_qspiboot.img
BSP firmware image for LS1046ARDB QSPI boot
13
firmware_ls1046ardb_uboot_sdboot.img
BSP firmware image for LS1046ARDB SD boot
14
firmware_lx2160ardb-rev2_uboot_emmcboot.img
BSP firmware image for LX2160ARDB eMMC boot
15
firmware_lx2160ardb-rev2_uboot_sdboot.img
BSP firmware image for LX2160ARDB SD boot
16
firmware_lx2160ardb-rev2_uboot_xspiboot.img
BSP firmware image for LX2160ARDB xSPI boot
17
fsl-image-networking-ls1028ardb.rootfs.tar.gz
Layerscape rootfs supports basic networking functionality on LS1028ARDB
18
fsl-image-networking-full-ls1028ardb.rootfs.tar.gz
Layerscape rootfs supports full networking functionality on LS1028ARDB
19
fsl-image-networking-ls1043ardb.rootfs.tar.gz
Layerscape rootfs supports basic networking functionality on LS1043ARDB
20
fsl-image-networking-full-ls1043ardb.rootfs.tar.gz
Layerscape rootfs supports full networking functionality on LS1043ARDB
21
fsl-image-networking-ls1046ardb.rootfs.tar.gz
Layerscape rootfs supports basic networking functionality on LS1046ARDB
22
fsl-image-networking-full-ls1046ardb.rootfs.tar.gz
Layerscape rootfs supports full networking functionality on LS1046ARDB
23
fsl-image-networking-lx2160ardb-rev2.rootfs.tar.gz
Layerscape rootfs supports basic networking functionality on LX2160ARDB
24
fsl-image-networking-full-lx2160ardbrev2.rootfs.tar.gz
Layerscape rootfs supports full networking functionality on LX2160ARDB
25
flex-installer
Deploy tools
Please refer to the User Guide document for the detailed steps of image deployment.
You also could use Debian flexbuilder Linux SDK to use Debian Linux OS.
%3CLINGO-SUB%20id%3D%22lingo-sub-2389035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1028ARDb%20Yocto-SDK%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%93%E3%81%AB%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%8A%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fyocto-sdk%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fyocto-sdk%3C%2FA%3E%3C%2FP%3E%3CP%3ELS1028ARDB%E3%81%AEOS%E3%81%8A%E3%82%88%E3%81%B3SDK%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%3C%2FP%3E%3CP%3Ewalnascar%E3%81%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E5%85%88%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%86%E3%81%A8%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMKDIR%20Yocto-SDK%3CBR%20%2F%3ECD%20YOCTO-SDK%3CBR%20%2F%3ERepo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fyocto-sdk%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fyocto-sdk%3C%2FA%3E-b%20%E3%83%AF%E3%83%AB%E3%83%8A%E3%82%B9%E3%82%AB%E3%83%BC%3CBR%20%2F%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%90%8C%E6%9C%9F%20--%E5%BC%B7%E5%88%B6%E5%90%8C%E6%9C%9F%3CBR%20%2F%3E%E3%80%82.%2Fsetup-env%20-m%20ls1028ardb%3CBR%20%2F%3E%20bitbake%20fsl-image-networking%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF3%E3%81%A4%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E-%20sysvinit%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E-%20DTC%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E-%20util-linux-native%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%82%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%AA%A4%E3%81%A3%E3%81%9F%E6%89%8B%E9%A0%86%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%97%E3%81%9F%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%80%8Cls-image-desktop%E3%80%8D%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUG10081_LLDP_L6.1.55_2.2.0%2Fpage%2Ftopics%2Fhow_to_download_flexbuild.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUG10081_LLDP_L6.1.55_2.2.0%2Fpage%2Ftopics%2Fhow_to_download_flexbuild.html%3C%2FA%3E%3C%2FP%3E%3CP%3Eflexbuild%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%82%E8%A6%8B%E3%81%A4%E3%81%91%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp%2Fflexbuild%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp%2Fflexbuild%3C%2FA%3E%3C%2FP%3E%3CP%3Egit%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fflexbuild.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fflexbuild.git%3C%2FA%3E%3CBR%20%2F%3ECD%E3%83%95%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%83%93%E3%83%AB%E3%83%89%3CBR%20%2F%3Emake%20docker%3CBR%20%2F%3E%20ls1028ardb_defconfig%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E4%BD%9C%E3%82%8B%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EW%3A%20binfmt_misc%20%E3%81%8C%20%2Fproc%2Fmounts%20%E3%81%AB%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20--%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EOS%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%84SDK%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E6%89%8B%E9%A0%86%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ls1028ardb%20yocto-sdk%20build%20problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AEYocto%20Linux%20SDK%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%8A%E5%9B%9E%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fyocto-sdk%2Ftree%2Fwalnascar-lsdk%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fyocto-sdk%2Ftree%2Fwalnascar-lsdk%3C%2FA%3E%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%3A%20%3CEM%3Ewalnascar-lsdk%3C%2FEM%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ELinux%20BSP%E5%AF%BE%E5%BF%9C%E3%81%AE%E5%9F%BA%E6%9D%BF%E3%80%81%E6%A9%9F%E8%83%BD%E3%80%81%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DRN00504%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%3C%2FA%3E%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLI%3E%0A%3CLI%3EYocto%E7%94%A8%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%97%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10374%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EUG10374.pdf%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3ELayerscape%20Linux%20SDK%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10381%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EUG10381.pdf%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%97%E3%83%AA%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fllsdk%2Fwalnascar%2F%253cpackage_name%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fllsdk%2Fwalnascar%2F%3C%2FA%3E%20%3CU%3E%3C%2FU%3E%E3%81%AB%E3%83%9B%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CU%3E%3C%2FU%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CTABLE%20width%3D%22925%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E%3CSTRONG%3E%E4%BB%B6%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3E%3CSTRONG%3E%E5%90%8D%E7%A7%B0%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3E%3CSTRONG%3E%E8%AA%AC%E6%98%8E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E1%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Eboot_ls1028ardb_lts_6.12.tgz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1028ARDB%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E2%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Eboot_ls1043ardb_lts_6.12.tgz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1043ARDB%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E3%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Eboot_ls1046ardb_lts_6.12.tgz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1046ARDB%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E4%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Eboot_lx2160ardb-rev2_lts_6.12.tgz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELX2160ARDB%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E5%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_ls1028ardb_uboot_emmcboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1028ARDB%20eMMC%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AEBSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E6%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_ls1028ardb_uboot_sdboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1028ARDB%20SD%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8BSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E7%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_ls1028ardb_uboot_xspiboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1028ARDB%20XSPI%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AEBSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_ls1043ardb_uboot_nandboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1043ARDB%20NAND%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AEBSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E9%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_ls1043ardb_uboot_norboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1043ARDB%20NOR%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8BSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E10%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_ls1043ardb_uboot_sdboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1043ARDB%20SD%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8BSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E11%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_ls1046ardb_uboot_emmcboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1046ARDB%20eMMC%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AEBSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E12%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_ls1046ardb_uboot_qspiboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1046ARDB%20QSPI%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AEBSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E13%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_ls1046ardb_uboot_sdboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELS1046ARDB%20SD%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8BSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E14%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_lx2160ardb-rev2_uboot_emmcboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELX2160ARDB%20eMMC%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8BSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E15%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_lx2160ardb-rev2_uboot_sdboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELX2160ARDB%20SD%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8BSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E16%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efirmware_lx2160ardb-rev2_uboot_xspiboot.img%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELX160ARDB%20xSPI%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8BSP%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E17%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efsl-image-networking-ls1028ardb.rootfs.tar.gz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELayerscape%20rootfs%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99LS1028ARDB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E18%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efsl-image-networking-full-ls1028ardb.rootfs.tar.gz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELayerscape%20rootfs%E3%81%AFLS1028ARDB%E4%B8%8A%E3%81%A7%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E19%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efsl-image-networking-ls1043ardb.rootfs.tar.gz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELayerscape%20rootfs%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99LS1043ARDB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E20%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efsl-image-networking-full-ls1043ardb.rootfs.tar.gz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELayerscape%20rootfs%E3%81%AFLS1043ARDB%E4%B8%8A%E3%81%A7%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E21%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efsl-image-networking-ls1046ardb.rootfs.tar.gz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELayerscape%20rootfs%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99LS1046ARDB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E22%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efsl-image-networking-full-ls1046ardb.rootfs.tar.gz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELayerscape%20rootfs%E3%81%AFLS1046ARDB%E4%B8%8A%E3%81%A7%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E23%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efsl-image-networking-lx2160ardb-rev2.rootfs.tar.gz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELayerscape%20rootfs%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99LX2160ARDB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E24%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3Efsl-image-networking-full-lx2160ardbrev2.rootfs.tar.gz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3ELayerscape%20rootfs%E3%81%AFLX2160ARDB%E4%B8%8A%E3%81%A7%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2249%22%3E%0A%3CP%3E25%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22354%22%3E%0A%3CP%3E%E3%83%95%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22522%22%3E%0A%3CP%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E5%B1%95%E9%96%8B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%94%BB%E5%83%8F%E5%B1%95%E9%96%8B%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E6%96%87%E6%9B%B8%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EDebian%20Flexbuilder%20Linux%20SDK%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6Debian%20Linux%20OS%E3%82%92%E4%BD%BF%E3%81%86%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ls1028ardb%20yocto-sdk%20build%20problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AE%E5%BE%8C%E3%80%81Flexbuild%20readme.md%20%E3%81%AB%E8%BC%89%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUG10155.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDebian%20Linux%20SDK%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3C%2FA%3E%E3%82%92%E7%99%BA%E8%A6%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81LS1028ARDB%E7%94%A8%E3%81%AEDebian%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EYocto%E7%92%B0%E5%A2%83%E3%81%AB%E4%BC%BC%E3%81%9F%E6%96%B9%E6%B3%95%E3%81%A7SDK%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%AA%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3EDebian%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E4%BB%8A%E3%82%84%E3%81%93%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AE%E6%8E%A8%E5%A5%A8OS%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3FYocto%E3%81%AF%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%82%88%E3%82%8A%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%84%9F%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ls1028ardb%20yocto-sdk%20build%20problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E6%84%8F%E8%A6%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81walnascar-lsdk%20%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9F%20walnascar%20%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%99%3CBR%20%2F%3Ebitbake%20-k%20fsl-image-networking-full%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A4%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20~%2Fwalnascar-lsdk%2Fsources%2Fpoky%2Fmeta%2Frecipes-core%2Fsysvinit%2Fsysvinit-inittab_2.88dsf.bb%3Ado_install%3CBR%20%2F%3Elog%3A%20~%2Fwalnascar-lsdk%2Fbuild_ls1028ardb%2Ftmp%2Fwork%2Fls1028ardb-FSL-Linux%2Fsysvinit-Inittab%2F2.88dsf%2Ftemp%2Flog.do_install.1267212%3CBR%20%2F%3EVirtual%3Anative%3A~%2FWalnascar-LSDK%2FSources%2FPoky%2FMeta%2FRecipes-Core%2FUtil-Linux%2FUtil-linux_2.40.4.bb%3Ado_compile%3CBR%20%2F%3Elog%3A%20~%2Fwalnascar-lsdk%2Fbuild_ls1028ardb%2Ftmp%2Fwork%2Fx86_64-linux%2Futil-linux-native%2F2.40.4%2Ftemp%2Flog.do_compile.1304034%3CBR%20%2F%3Evirtual%3Anative%3A~%2Fwalnascar-lsdk%2Fsources%2Fpoky%2Fmeta%2Frecipes-kernel%2FDTC%2Fdtc_1.7.2.bb%3Ado_compile%3CBR%20%2F%3Elog%3A%20~%2Fwalnascar-lsdk%2Fbuild_ls1028ardb%2Ftmp%2Fwork%2Fx86_64-linux%2Fdtc-native%2F1.7.2%2Ftemp%2Flog.do_compile.1321834%3CBR%20%2F%3E~%2Fwalnascar-lsdk%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fflex%2Fflex_2.6.4.bb%3Ado_compile%3CBR%20%2F%3Elog%3A%20~%2Fwalnascar-lsdk%2Fbuild_ls1028ardb%2Ftmp%2Fwork%2Faarch64-FSL-Linux%2FFlex%2F2.6.4%2Ftemp%2Flog.do_compile.2409352%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%EF%BC%9A%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C17%E4%BB%B6%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%EF%BC%9A6%E4%BB%B6%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%82%BC%E3%83%AD%E4%BB%A5%E5%A4%96%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%9E%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ls1028ardb%20yocto-sdk%20build%20problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%B5%90%E5%B1%80%E3%80%81%E7%A7%81%E3%81%AE%E3%83%9F%E3%82%B9%E3%81%A7%E3%80%81Ubuntu%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E9%96%93%E9%81%95%E3%81%88%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81Yocto%E5%87%BA%E5%8A%9B%E3%81%AE%E8%AD%A6%E5%91%8A%E3%82%92%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E24.04%E3%81%AE%E9%96%8B%E7%99%BA%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CUL%3E%3CLI%3EYocto%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E7%94%A8%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%97%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10374%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20target%3D%22_blank%22%3EUG10374.pdf%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ls1028ardb%20yocto-sdk%20build%20problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3Esudo%20apt-get%20install%20build-essential%20chrpath%20cpio%20debianutils%20diffstat%20file%20gawk%3C%2FP%3E%0A%3CP%3Egcc%20git%20iputils-ping%20libacl1%20liblz4-tool%20locales%20python3%20python3-git%20python3-%3C%2FP%3E%0A%3CP%3Ejinja2%20python3-pexpect%20python3-pip%20python3-subunit%20socat%20texinfo%20unzip%20wget%20xzutils%3C%2FP%3E%0A%3CP%3Ezstd%20efitools%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3CSPAN%3E~%2Fwalnascar-lsdk%2Fbuild_ls1028ardb%2Ftmp%2Fwork%2Fls1028ardb-fsl-linux%2Fsysvinit-inittab%2F2.88dsf%2Ftemp%2Flog.do_install.1267212%20%E3%82%92%E7%A7%81%E3%81%AB%E9%80%81%E3%81%A3%E3%81%A6%E8%AA%BF%E6%9F%BB%E3%82%92%E4%BE%9D%E9%A0%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
