flex-builder building opencv with aruco libs
noahw
I am trying to build the libopencv-aruco, which typically comes with new version of OpenCV. When I run bld -c opencv, I don't see this libs being built.
Can anyone provide some guidance on how I could use flex-builder to build the aruco libs?
yipingwang
In your LSDK 21.08 host build environment, please execute the following command:
$ sudo chroot build/rfs/rootfs_lsdk2108_ubuntu_main_arm64/
Then run the following command.
/# apt-get install libopencv-dev
/# exit
You will get
build/rfs/rootfs_lsdk2108_ubuntu_main_arm64/usr/lib/aarch64-linux-gnu/libopencv_aruco.so.4.2.0
build/rfs/rootfs_lsdk2108_ubuntu_main_arm64/usr/lib/aarch64-linux-gnu/libopencv_aruco.a
yipingwang
/# exit
You will get
