dpmac17 sgmii Problems
17,051件の閲覧回数
muaxi8
Contributor V
lx2160a custom board。
Using SERDES1 Protocol: 1 (0x1)
Using SERDES2 Protocol: 7 (0x7)
Using SERDES3 Protocol: 3 (0x3)
Now I am using dpMAC17 SGMII of SerDES2 as the debugging network port. The PHY chip is AR0833. Using MII command under uboot, I can see that the PHY is in link state, but ping my host is not working.。
RCW parameter EC1_PMUX[833-832] is changed to 0x01,  but the ping still fails
16,861件の閲覧回数
muaxi8
Contributor V
when the clock spread spectrum turned off, we can ping through, it is too hard
thank u
26 返答(返信)
13,652件の閲覧回数
yipingwang
Would you please provide your u-boot console log and the results of the following commands?
=> mdio list
FSL_MDIO0:
0 - Cortina CS4223 <--> DPMAC2@xlaui4
1 - AR8035 <--> DPMAC17@rgmii-id
2 - AR8035 <--> DPMAC18@rgmii-id
4 - Aquantia AQR107 <--> DPMAC3@xgmii
5 - Aquantia AQR107 <--> DPMAC4@xgmii
FSL_MDIO1:
0 - Inphi in112525_S03P <--> DPMAC6@25g-aui
=> mdio read DPMAC17@rgmii-id 1
Reading from bus FSL_MDIO0
PHY at address 1:
1 - 0x7949
Is your PHY chip AR8033? Have you enabled the following in configs/lx2160ardb_tfa_defconfig
CONFIG_PHYLIB=y
CONFIG_PHY_ATHEROS=y
13,642件の閲覧回数
muaxi8
Contributor V
=> ping 10.0.1.119
Using DPMAC17@sgmii device
ARP Retry count exceeded; starting again
ping failed; host 10.0.1.119 is not alive
yes my  PHY chip is AR8033。
i have enabled the following in configs/lx2160ardb_tfa_defconfig
13,631件の閲覧回数
yipingwang
In board/freescale/lx2160a/eth_lx2160ardb.c, please modify the following section according to your custom board.
for (i = WRIOP1_DPMAC17; i <= WRIOP1_DPMAC18; i++) {
          interface = wriop_get_enet_if(i);
          switch (interface) {
          case PHY_INTERFACE_MODE_RGMII:
          case PHY_INTERFACE_MODE_RGMII_ID:
                           dev = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME);
                            wriop_set_mdio(i, dev);
                            break;
          default:
                          break;
Modify to:
          case PHY_INTERFACE_MODE_SGMII:
                            break;
          default:
                          break;
13,626件の閲覧回数
muaxi8
Contributor V
Yes, we have modified this part code , The problem remains。Does the DPC need to be modified?  We have checked the content of the DPC and there seems to be no problem
13,618件の閲覧回数
yipingwang
You could use mdio read command to check the status of a SGMII link.
=> mdio list
FSL_MDIO0:
4 - AR8031/AR8033 <--> DPMAC17@sgmii
FSL_MDIO1:
=> mdio read DPMAC17@sgmii 1
PHY at address 4:
1 - 0x7969
The link partner link status bit is in Register #1 on the PHY. The 'Link Status' bit is bit #2 (from the left) of the last nibble. In your above result, the nibble of interest is "9" (d = b'1001'), and therefore the 'Link Status' = 0, which means 'link download'. If the link is up,  this bit would be a "1," and we would see 0x796d.
So on your custom board the SGMII link status is download, please check the probable hardware issue.
13,616件の閲覧回数
muaxi8
Contributor V
The second read was link.
13,601件の閲覧回数
yipingwang
Few clarifications:
  1. Do ping works on MAC18?
  2. Few strange observation in U-boot log:
      (a). Clock configuration shown in uboot is not as per the selected protocol.
      (b). PCA: failed to select proper channel
MAC17 and MAC18 is same so same issue should be with MAC 18.
  1. Can you share share schematic?
13,598件の閲覧回数
muaxi8
Contributor V
Re:
Dpmac18 (EC2) cannot be tested because it is not connected to any PHY.We only used mac17, our SERDES2's SGMII17 was connected to the AR8033, and our EC1 was connected to the KSZ9896 switch chip via RGMII.I think this might be a problem, so I'm just going to debug SGMII and leave RGMII alone for now
Re: The clock configuration is printed directly in the source code, we did not remove, serdes2 clock is actually 161.xxxMhz.
Re: Our custom board is not using PCA9547 (I2C MUX, level 1), so there is this error。
 schematic:
链接:https://pan.baidu.com/s/14edfW8yig7c-qZyYTLk7xQ
提取码:2345
13,585件の閲覧回数
yipingwang
What is the status of link status between MAC and PHY?
You can check this as detail below:
On U-boot prompt:
printenv elf_load
elf_load=dcache off; tftp 0x80300000 <location of mdio>/mdio.bin; dcache on;
run elf_load
go 0x80300000 read 0x8c47000 3 {0x8c47000: MAC 17 Base address}
a valid PCS link ix 0x00000004
bit 2 set
Please let us know .
13,582件の閲覧回数
muaxi8
Contributor V
I followed your prompts and programmed mdio.bin to 0x80300000, then read the MAC 17 Base address and got some values.
=> md 0x8c47000 4
08c47000: 00010200 00000000 00000810 00000000 ................
I looked at the manual "LX2160ADPAA2RM. PDF "and did not see the register about the MAC link status
13,577件の閲覧回数
yipingwang
Please read using below command
go 0x80300000
read 0x8c47000 3
13,575件の閲覧回数
muaxi8
Contributor V
the usage is a little wrong. One parameter missing?
=> go 0x80300000 read 0x8c47000 3
## Starting application at 0x80300000 ...
Example expects ABI version 9
Actual U-Boot ABI version 9
Internal MDIO read / write
argc = 4
operation = "read"
mac offset = "0x8c47000"
dev addr = "3"
Usage: go 0x80300000 <read|write> <mac offset> <mmd> <reg> [data]
## Application terminated, rc = 0x0
=> go 0x80300000 read 0x8c47000 3 0
argc = 5
operation = "read"
dev addr = "3"
reg addr = "0"
mdio_cfg bsy set
mdio_data bsy set
output data: 0x00000000
13,569件の閲覧回数
yipingwang
Sorry for typo, correct command is
go 0x80300000 read 0x8c0b000 3 1
13,564件の閲覧回数
muaxi8
Contributor V
MAC and PHY link status is not ok? We are using SGMII, DPL or DPC need configuration ?
=> go 0x80300000 read 0x8c0b000 3 1
argc = 5
operation = "read"
mac offset = "0x8c0b000"
dev addr = "3"
reg addr = "1"
mdio_cfg bsy set
mdio_data bsy set
=> go 0x80300000 read 0x8c47000 3 1
argc = 5
operation = "read"
dev addr = "3"
reg addr = "1"
mdio_cfg bsy set
mdio_data bsy set
13,559件の閲覧回数
yipingwang
Thanks for update. Can you please view more registers to check if read is working correctly?
Please refer register details in LX2160ARM Rev0 07/2020 section 26.9.2 SGMII Registers (Please read register 0,2,3 also)
13,552件の閲覧回数
muaxi8
Contributor V
A little problem
=> mdio list
FSL_MDIO0:
FSL_MDIO1:
PHY at address 4:
1 - 0x796d
=> go 0x80300000 read 0x8c0b000 3 2
argc = 5
operation = "read"
dev addr = "3"
reg addr = "2"
mdio_cfg bsy set
mdio_data bsy set
=> go 0x80300000 read 0x8c0b000 3 3
argc = 5
operation = "read"
dev addr = "3"
reg addr = "3"
mdio_cfg bsy set
mdio_data bsy set
=> go 0x80300000 read 0x8c0b000 3 0
argc = 5
operation = "read"
dev addr = "3"
reg addr = "0"
mdio_cfg bsy set
mdio_data bsy set
13,546件の閲覧回数
yipingwang
Please refer "Table 51 MAC Capabilities" This table shows different MAC address and there capability.
I understand customer is using MAC 17 hence to reading all the register customer needs to use address "8C4_7000h"
Syntax for Clause 45: (Please read status register multiple times)
go 0x80300000 read <mac address> <MMD device> <register>
0x8c0b000= MAC address
3->  Device: PCS address  (Table 287. Device Address Overview)
1-> PCS status register
Syntax for Clause 22: (Please read status register multiple times)
read <mac_addr> <mmd always 0>  <reg addr>  <any value: e.g. 0 this is a switch that tells its clause 22>
For example to read control register
go 0x80300000 read 0x8c47000 0 0 0
To Read status register
go 0x80300000 read 0x8c47000 0 1 0
Do customer is able to boot linux on board?
does ping don't work on Linux?
Can you detail about your setup?
Please use MAC17 address "8C4_7000" instead of 0x8c0b000.
13,513件の閲覧回数
muaxi8
Contributor V
Dear Yiping,
Could you help give a demo for mac loopback code in u-boot.
Such as mac17 mac loopback. Many thanks.
13,505件の閲覧回数
yipingwang
1. Please first update your mc firmware (attached)
As per the boot log your mc firmware version is "version: 10.24.0"
2. Please share dump of PHY register 5 (partner ability) using MDIO command on uboot
3. what is the clock frequency of CLK_SD2_F_P/N ?
13,498件の閲覧回数
muaxi8
Contributor V
hi yipingWang
1:
crc32+
fsl-mc: Booting Management Complex ... SUCCESS
fsl-mc: Management Complex booted (version: 10.24.0, boot status: 0x1)
Hit any key to stop autoboot: 0
2:
=> mdio list
FSL_MDIO0:
FSL_MDIO1:
=> mii read 4 5
CDE1
=> mii read 4 5
CDE1
=> mii dump
5. (cde1) -- Autonegotiation partner abilities register --
(8000:8000) 5.15 = 1 next page able
(4000:4000) 5.14 = 1 acknowledge
(2000:0000) 5.13 = 0 remote fault
(1000:0000) 5.12 = 0 (reserved)
(0800:0800) 5.11 = 1 asymmetric pause able
(0400:0400) 5.10 = 1 pause able
(0200:0000) 5. 9 = 0 100BASE-T4 able
(0100:0100) 5. 8 = 1 100BASE-X full duplex able
(0080:0080) 5. 7 = 1 100BASE-TX able
(0040:0040) 5. 6 = 1 10BASE-T full duplex able
(0020:0020) 5. 5 = 1 10BASE-T able
(001f:0001) 5. 4- 0 = 1 partner selector = IEEE 802.3 CSMA/CD
3:
CLK_SD2_F_P/N is 100Mhz
can you provide a demo of dpmac17 sgmii disable auto-negotiation ?
%3CLINGO-SUB%20id%3D%22lingo-sub-1323833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Edpmac17%20sgmii%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1323833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Elx2160a%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%80%82%3C%2FP%3E%3CP%3ESERDES1%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%3A%201%20(0x1)%3CBR%20%2F%3E%20SERDES2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%3A%207%20(0x7)%3CBR%20%2F%3E%20SERDES3%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%EF%BC%9A3%EF%BC%880x3%EF%BC%89%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E7%94%A8%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6SerDES2%E3%81%AEdpMAC17%20SGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82PHY%E3%83%81%E3%83%83%E3%83%97%E3%81%AFAR0833%E3%81%A7%E3%81%99%E3%80%82uboot%E4%B8%8A%E3%81%A7MII%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81PHY%E3%81%8C%E3%83%AA%E3%83%B3%E3%82%AF%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%B8%E3%81%AEping%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ERCW%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BFEC1_PMUX%5B833-832%5D%E3%82%920x01%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ping%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355138%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355138%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E3%83%A9%E3%83%A0%E6%8B%A1%E6%95%A3%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E5%A0%B4%E6%89%80%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1334692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1334692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E3%83%A9%E3%83%A0%E6%8B%A1%E6%95%A3%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ping%20%E3%82%92%E9%80%9A%E9%81%8E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%9B%B0%E9%9B%A3%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1334439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1334439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EMC%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E6%B8%88%E3%81%BF%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%81%8B%E3%82%89%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E7%B5%8C%E8%B7%AF%E3%81%AF%E8%89%AF%E5%A5%BD%E3%81%AA%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAR8033%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81PHY%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%94%E3%82%A2%E3%83%84%E3%83%BC%E3%83%94%E3%82%A2%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%EF%BC%88PHY%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE2.5.3%E9%A0%85%E5%8F%82%E7%85%A7%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81PHY%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1333839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1333839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Emac17%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%3CSPAN%3E%E5%8D%B0%E5%88%B7%E3%82%92%E8%A6%8B%E3%82%8B%E9%99%90%E3%82%8A%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%95%E3%81%9D%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%82%E3%82%8B%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%E5%A4%A7%E5%A4%89%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eping%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9B%E3%82%B9%E3%83%88192.168.0.119%E3%81%AF%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%20%3D%26gt%3B%3CBR%20%2F%3E%20ldpaa_dpmac_bind%E3%80%81DPMAC%E3%82%BF%E3%82%A4%E3%83%97%3Ddpmac%3CBR%20%2F%3E%20ldpaa_dpmac_bind%E3%80%81DPMAC%20ID%3D17%3CBR%20%2F%3E%20ldpaa_dpmac_bind%E3%80%81DPMAC%E7%8A%B6%E6%85%8B%3D0%3CBR%20%2F%3E%20ldpaa_dpmac_bind%E3%80%81DPNI%E3%82%BF%E3%82%A4%E3%83%97%3Ddpni%3CBR%20%2F%3E%20ldpaa_dpmac_bind%E3%80%81DPNI%20ID%3D0%3CBR%20%2F%3E%20ldpaa_dpmac_bind%E3%80%81DPNI%E7%8A%B6%E6%85%8B%3D0%3CBR%20%2F%3E%20DPMAC%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%EF%BC%9A1%20-%20%E3%82%A2%E3%83%83%E3%83%97%3CBR%20%2F%3EDPNI%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%EF%BC%9A1%20-%20%E3%82%A2%E3%83%83%E3%83%97%3CBR%20%2F%3EDPMAC17%40sgmii%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EDPNI%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC...%3CBR%20%2F%3E%20DPNI_CNT_ING_ALL_FRAMES%3D%201%3CBR%20%2F%3E%20DPNI_CNT_ING_ALL_BYTES%3D60%3CBR%20%2F%3E%20DPNI_CNT_ING_MCAST_FRAMES%3D%200%3CBR%20%2F%3E%20DPNI_CNT_ING_MCAST_BYTES%3D%200%3CBR%20%2F%3E%20DPNI_CNT_ING_BCAST_FRAMES%3D%201%3CBR%20%2F%3E%20DPNI_CNT_ING_BCAST_BYTES%3D60%3CBR%20%2F%3E%20DPNI_CNT_EGR_ALL_FRAMES%3D%201%3CBR%20%2F%3E%20DPNI_CNT_EGR_ALL_BYTES%3D%2042%3CBR%20%2F%3E%20DPNI_CNT_EGR_MCAST_FRAMES%3D%200%3CBR%20%2F%3E%20DPNI_CNT_EGR_MCAST_BYTES%3D%200%3CBR%20%2F%3E%20DPNI_CNT_EGR_BCAST_FRAMES%3D%201%3CBR%20%2F%3E%20DPNI_CNT_EGR_BCAST_BYTES%3D42%3CBR%20%2F%3E%20DPNI_CNT_ING_FILTERED_FRAMES%3D%200%3CBR%20%2F%3E%20DPNI_CNT_ING_DISCARDED_FRAMES%3D%200%3CBR%20%2F%3E%20DPNI_CNT_ING_NOBUFFER_DISCARDS%3D%200%3CBR%20%2F%3E%20DPNI_CNT_EGR_DISCARDED_FRAMES%3D%200%3CBR%20%2F%3E%20DPNI_CNT_EGR_CNF_FRAMES%3D%200%3C%2FP%3E%3CP%3EDPMAC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC...%3CBR%20%2F%3E%20DPMAC_CNT_ING_BYTE%3D15%3CBR%20%2F%3E%20DPMAC_CNT_ING_FRAME_DISCARD%3D9%3CBR%20%2F%3E%20DPMAC_CNT_ING_ALIGN_ERR%20%3D%2011%3CBR%20%2F%3E%20DPMAC_CNT_ING_BYTE%3D15%3CBR%20%2F%3E%20DPMAC_CNT_ING_ERR_FRAME%3D21%3CBR%20%2F%3E%20DPMAC_CNT_EGR_BYTE%20%3D%2021%3CBR%20%2F%3E%20DPMAC_CNT_EGR_ERR_FRAME%20%3D%2025%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%88%3CBR%20%2F%3Eping%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9B%E3%82%B9%E3%83%88192.168.0.119%E3%81%AF%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1333712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1333712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EAE%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8B%E3%82%89%E3%81%AE%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EQ1%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8B%E3%82%89%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81MC%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E9%A1%A7%E5%AE%A2%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1333711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1333711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAE%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8B%E3%82%89%E3%81%AE%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%A1%A7%E5%AE%A2%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%ABMAC%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eu-boot%20%E3%81%AE%20MAC%20%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E9%A1%A7%E5%AE%A2%E3%81%AF%20codewarrior%20ccs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20ping%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%BE%E3%81%9F%E3%81%AF%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eu-boot%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%8B%E3%82%89ping%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%80%81MAC%E3%81%8C%E5%86%8D%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81MAC%E3%81%A7%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AFping%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81ccs%E3%81%8B%E3%82%89%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9F%E6%96%87%E6%9B%B8%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8B%95%E4%BD%9C%E7%A2%BA%E8%AA%8D%E3%82%92%E3%81%97%E3%81%A6%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1333097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1333097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%AF%E3%83%B3%E3%83%BB%E3%82%A4%E3%83%BC%E3%83%94%E3%83%B3%3C%2FP%3E%3CP%3E1%3A%3C%2FP%3E%3CP%3Ecrc32%2B%3CBR%20%2F%3E%20fsl-mc%3A%20%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E8%A4%87%E5%90%88%E4%BD%93%E3%81%AE%E8%B5%B7%E5%8B%95%E4%B8%AD...%E6%88%90%E5%8A%9F%3CBR%20%2F%3Efsl-mc%3A%20%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E8%A4%87%E5%90%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(%3CFONT%20color%3D%22%23FF0000%22%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2010.24.0%3C%2FFONT%3E%20%E3%80%81%E8%B5%B7%E5%8B%95%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x1)%3CBR%20%2F%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%200%3C%2FP%3E%3CP%3E2%EF%BC%9A%3C%2FP%3E%3CP%3E%3D%26gt%3B%20mdio%E3%83%AA%E3%82%B9%E3%83%88%3CBR%20%2F%3EFSL_MDIO0%3A%3CBR%20%2F%3E%204%20-%20AR8031%2FAR8033%20%26lt%3B--%26gt%3B%20DPMAC17%40sgmii%3CBR%20%2F%3E%20FSL_MDIO1%3A%3CBR%20%2F%3E%20%3D%26gt%3B%20mii%204%205%20%E3%82%92%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ECDE1%3CBR%20%2F%3E%20%3D%26gt%3B%20mii%204%205%20%E3%82%92%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ECDE1%3CBR%20%2F%3E%20%3D%26gt%3B%20%3CFONT%20color%3D%22%23FF0000%22%3Emii%20%E3%83%80%E3%83%B3%E3%83%97%3C%2FFONT%3E%3CBR%20%2F%3E5.%20(cde1)%20--%20%E8%87%AA%E5%8B%95%E4%BA%A4%E6%B8%89%E3%83%91%E3%83%BC%E3%83%88%E3%83%8A%E3%83%BC%E3%81%AE%E8%83%BD%E5%8A%9B%E7%99%BB%E9%8C%B2%20--%3CBR%20%2F%3E%20(8000%3A8000)%205.15%20%3D%201%20%E6%AC%A1%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3E(4000%3A4000)%205.14%20%3D%201%20%E6%89%BF%E8%AA%8D%3CBR%20%2F%3E(2000%3A0000)%205.13%20%3D%200%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E9%9A%9C%E5%AE%B3%3CBR%20%2F%3E(1000%3A0000)%205.12%20%3D%200%20(%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF)%3CBR%20%2F%3E%20(0800%3A0800)%205.11%20%3D%201%20%E9%9D%9E%E5%AF%BE%E7%A7%B0%E3%83%9D%E3%83%BC%E3%82%BA%E5%8F%AF%E8%83%BD%3CBR%20%2F%3E(0400%3A0400)%205.10%20%3D%201%20%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E5%8F%AF%E8%83%BD%3CBR%20%2F%3E(0200%3A0000)%205.%209%20%3D%200%20100BASE-T4%E5%AF%BE%E5%BF%9C%3CBR%20%2F%3E(0100%3A0100)%205.%208%20%3D%201%20100BASE-X%20%E5%85%A8%E4%BA%8C%E9%87%8D%E5%AF%BE%E5%BF%9C%3CBR%20%2F%3E(0080%3A0080)%205.%207%20%3D%201%20100BASE-TX%E5%AF%BE%E5%BF%9C%3CBR%20%2F%3E(0040%3A0040)%205.%206%20%3D%201%2010BASE-T%20%E5%85%A8%E4%BA%8C%E9%87%8D%E5%AF%BE%E5%BF%9C%3CBR%20%2F%3E(0020%3A0020)%205.5%20%3D%201%2010BASE-T%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3CBR%20%2F%3E(001f%3A0001)%205.%204-0%20%3D%201%20%E3%83%91%E3%83%BC%E3%83%88%E3%83%8A%E3%83%BC%E3%82%BB%E3%83%AC%E3%82%AF%E3%82%BF%20%3D%20IEEE%20802.3%20CSMA%2FCD%3C%2FP%3E%3CP%3E3%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3ECLK_SD2_F_P%2FN%E3%81%AF%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3E100MHz%3C%2FFONT%3E%E3%81%A7%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Edpmac17%20sgmii%20%E3%81%AE%E8%87%AA%E5%8B%95%E3%83%8D%E3%82%B4%E3%82%B7%E3%82%A8%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%83%87%E3%83%A2%3CSPAN%3E%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%3C%2FSPAN%3E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22muaxi8_0-1630546466148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22muaxi8_0-1630546466148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F154856i6853B6ABFBEAC79C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22muaxi8_0-1630546466148.png%22%20alt%3D%22muaxi8_0-1630546466148.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1331638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1331638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E1.%20%E3%81%BE%E3%81%9A%E3%80%81MC%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%8F%82%E7%85%A7%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AEMC%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%8C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2010.24.0%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%3E2.%20uboot%E3%81%A7MDIO%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6PHY%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF5%EF%BC%88%E3%83%91%E3%83%BC%E3%83%88%E3%83%8A%E3%83%BC%E6%A9%9F%E8%83%BD%EF%BC%89%E3%81%AE%E3%83%80%E3%83%B3%E3%83%97%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%3E3.%20CLK_SD2_F_P%2FN%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1331505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1331505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%82%A4%E3%83%BC%E3%83%94%E3%83%B3%E6%A7%98%3C%2FP%3E%3CP%3EU-Boot%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BMac%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%83%A2%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81mac17%20mac%20%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%81%AA%E3%81%A9%E3%80%82%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1330825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1330825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%80%8C%E8%A1%A851%20MAC%E6%A9%9F%E8%83%BD%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E8%A1%A8%E3%81%AB%E3%81%AF%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AAMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E3%81%9D%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AFMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B917%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%AB%E3%81%AF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%8C8C4_7000h%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%AC%AC45%E6%9D%A1%E3%81%AE%E6%A7%8B%E6%96%87%EF%BC%9A%EF%BC%88%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%92%E8%A4%87%E6%95%B0%E5%9B%9E%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E0x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3CMAC%20address%3D%22%22%3E%3CMMD%20device%3D%22%22%3E%3CREGISTER%3E%20%3C%2FREGISTER%3E%3C%2FMMD%3E%3C%2FMAC%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E0x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%200x8c0b000%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%203%201%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E0x8c0b000%3D%20MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3-%26gt%3B%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%20PCS%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20(%E8%A1%A8%20287)%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E6%A6%82%E8%A6%81%EF%BC%89%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1-%26gt%3B%20PCS%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E7%99%BB%E9%8C%B2%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%AC%AC22%E6%9D%A1%E3%81%AE%E6%A7%8B%E6%96%87%EF%BC%9A%EF%BC%88%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%92%E8%A4%87%E6%95%B0%E5%9B%9E%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CMAC_ADDR%3E%20%3CMMD%20always%3D%22%22%200%3D%22%22%3E%20%3CREG%20addr%3D%22%22%3E%20%26lt%3B%E4%BB%BB%E6%84%8F%E3%81%AE%E5%80%A4%3A%20%E4%BE%8B0%20%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E6%9D%A1%E9%A0%8522%26gt%3B%E3%82%92%E4%BC%9D%E3%81%88%E3%82%8B%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%A7%E3%81%99%3C%2FREG%3E%3C%2FMMD%3E%3C%2FMAC_ADDR%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E5%88%B6%E5%BE%A1%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E5%A0%B4%E5%90%88%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E0x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%200x8c47000%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%200%200%200%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%AB%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E0x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%200x8c47000%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%200%201%200%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7Linux%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ELinux%E3%81%A7%E3%81%AFping%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%A7%8B%E6%88%90%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A9%B3%E3%81%97%E3%81%8F%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMAC17%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%8C8C4_7000%E3%80%8D%E3%82%920x8c0b000%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1330678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1330678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%A1%E3%82%87%E3%81%A3%E3%81%A8%E3%81%97%E3%81%9F%E5%95%8F%E9%A1%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3D%26gt%3B%20mdio%E3%83%AA%E3%82%B9%E3%83%88%3CBR%20%2F%3EFSL_MDIO0%3A%3CBR%20%2F%3E%204%20-%20AR8031%2FAR8033%20%26lt%3B--%26gt%3B%20DPMAC17%40sgmii%3CBR%20%2F%3E%20FSL_MDIO1%3A%3CBR%20%2F%3E%20%3D%26gt%3B%20mdio%20read%20DPMAC17%40sgmii%201%3CBR%20%2F%3E%20FSL_MDIO0%E3%83%90%E3%82%B9%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B94%E3%81%AEPHY%3A%3CBR%20%2F%3E%201%20-%200x796d%3CBR%20%2F%3E%20%3D%26gt%3B%200x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%3CFONT%20color%3D%22%23FF6600%22%3E0x8c0b000%3C%2FFONT%3E%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%203%202%3CBR%20%2F%3E%20%23%23%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%920x80300000%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81ABI%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%209%20%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%AE%9F%E9%9A%9B%E3%81%AEU-Boot%20ABI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B39%3CBR%20%2F%3E%E5%86%85%E9%83%A8MDIO%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%3CBR%20%2F%3Eargc%20%3D%205%3CBR%20%2F%3E%E6%93%8D%E4%BD%9C%20%3D%20%22%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%22%3CBR%20%2F%3E%20MAC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%3D%20%220x8c0b000%22%3CBR%20%2F%3E%20dev%20addr%20%3D%20%223%22%3CBR%20%2F%3E%20reg%20addr%20%3D%20%222%22%3CBR%20%2F%3E%20mdio_cfg%20bsy%20%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3Emdio_data%20bsy%20%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%3A%200x00000000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%23%20Application%20terminated%2C%20rc%20%3D%200x0%3CBR%20%2F%3E%3D%26gt%3B%20go%200x80300000%20read%20%3CFONT%20color%3D%22%23FF6600%22%3E0x8c0b000%3C%2FFONT%3E%203%203%3CBR%20%2F%3E%23%23%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%920x80300000%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81ABI%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%209%20%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%AE%9F%E9%9A%9B%E3%81%AEU-Boot%20ABI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B39%3CBR%20%2F%3E%E5%86%85%E9%83%A8MDIO%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%3CBR%20%2F%3Eargc%20%3D%205%3CBR%20%2F%3E%E6%93%8D%E4%BD%9C%20%3D%20%22%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%22%3CBR%20%2F%3E%20MAC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%3D%20%220x8c0b000%22%3CBR%20%2F%3E%20dev%20addr%20%3D%20%223%22%3CBR%20%2F%3E%20reg%20addr%20%3D%20%223%22%3CBR%20%2F%3E%20mdio_cfg%20bsy%20%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3Emdio_data%20bsy%20%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%3A%200x00000000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%23%20Application%20terminated%2C%20rc%20%3D%200x0%3CBR%20%2F%3E%3D%26gt%3B%20go%200x80300000%20read%200x8c0b000%203%200%3CBR%20%2F%3E%23%23%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%920x80300000%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81ABI%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%209%20%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%AE%9F%E9%9A%9B%E3%81%AEU-Boot%20ABI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B39%3CBR%20%2F%3E%E5%86%85%E9%83%A8MDIO%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%3CBR%20%2F%3Eargc%20%3D%205%3CBR%20%2F%3E%E6%93%8D%E4%BD%9C%20%3D%20%22%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%22%3CBR%20%2F%3E%20MAC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%3D%20%220x8c0b000%22%3CBR%20%2F%3E%20dev%20addr%20%3D%20%223%22%3CBR%20%2F%3E%20reg%20addr%20%3D%20%220%22%3CBR%20%2F%3E%20mdio_cfg%20bsy%20%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3Emdio_data%20bsy%20%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%3A%200x00000000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%23%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82rc%20%3D%200x0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1330086%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1330086%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81LX2160ARM%20Rev0%2007%2F2020%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B326.9.2%E3%80%8CSGMII%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF0%E3%80%812%E3%80%813%E3%82%82%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1330063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1330063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EMAC%E3%81%A8PHY%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9FSGMII%E3%80%81DPL%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFDPC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3D%26gt%3B%200x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%3CFONT%20color%3D%22%23FF6600%22%3E0x8c0b000%3C%2FFONT%3E%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%203%201%3CBR%20%2F%3E%20%23%23%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%920x80300000%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81ABI%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%209%20%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%AE%9F%E9%9A%9B%E3%81%AEU-Boot%20ABI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B39%3CBR%20%2F%3E%E5%86%85%E9%83%A8MDIO%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%3CBR%20%2F%3Eargc%20%3D%205%3CBR%20%2F%3E%E6%93%8D%E4%BD%9C%20%3D%20%22%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%22%3CBR%20%2F%3E%20MAC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%3D%20%220x8c0b000%22%3CBR%20%2F%3E%20dev%20addr%20%3D%20%223%22%3CBR%20%2F%3E%20reg%20addr%20%3D%20%221%22%3CBR%20%2F%3E%20mdio_cfg%20bsy%20%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3Emdio_data%20bsy%20%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%3A%200x00000000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%23%20Application%20terminated%2C%20rc%20%3D%200x0%3CBR%20%2F%3E%3D%26gt%3B%20go%200x80300000%20read%20%3CFONT%20color%3D%22%23FF6600%22%3E0x8c47000%3C%2FFONT%3E%203%201%3CBR%20%2F%3E%23%23%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%920x80300000%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AFABI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B39%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%AE%9F%E9%9A%9B%E3%81%AEU-Boot%20ABI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B39%3CBR%20%2F%3E%E5%86%85%E9%83%A8MDIO%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%3CBR%20%2F%3Eargc%20%3D%205%3CBR%20%2F%3E%E6%93%8D%E4%BD%9C%20%3D%20%22%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%22%3CBR%20%2F%3E%20MAC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%3D%20%220x8c47000%22%3CBR%20%2F%3E%20dev%20addr%20%3D%20%223%22%3CBR%20%2F%3E%20reg%20addr%20%3D%20%221%22%3CBR%20%2F%3E%20mdio_cfg%20bsy%20%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3Emdio_data%20bsy%20%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%3A%200x00000000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%23%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82rc%20%3D%200x0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1330050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1330050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%97%E3%83%9F%E3%82%B9%E3%81%A7%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%AD%A3%E3%81%97%E3%81%84%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E0x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%200x8c0b000%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%203%201%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1330019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1330019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BD%BF%E3%81%84%E6%96%B9%E3%81%8C%E5%B0%91%E3%81%97%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C1%E3%81%A4%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3D%26gt%3B%200x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%200x8c47000%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%203%3CBR%20%2F%3E%20%23%23%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%920x80300000%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81ABI%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%209%20%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%AE%9F%E9%9A%9B%E3%81%AEU-Boot%20ABI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B39%3CBR%20%2F%3E%E5%86%85%E9%83%A8MDIO%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%3CBR%20%2F%3Eargc%20%3D%204%3CBR%20%2F%3E%E6%93%8D%E4%BD%9C%20%3D%20%22%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%22%3CBR%20%2F%3E%20MAC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%3D%20%220x8c47000%22%3CBR%20%2F%3E%20dev%20addr%20%3D%20%223%22%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3A%20go%200x80300000%20%3CREAD%3E%20%3CMAC%20offset%3D%22%22%3E%20%3CMMD%3E%20%3CREG%3E%20%5Bdata%5D%3C%2FREG%3E%3C%2FMMD%3E%3C%2FMAC%3E%3C%2FREAD%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%23%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82rc%20%3D%200x0%3C%2FP%3E%3CP%3E%E2%80%94%E2%80%94------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3D%26gt%3B%200x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%200x8c47000%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%203%200%3CBR%20%2F%3E%20%23%23%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%920x80300000%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AFABI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B39%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%AE%9F%E9%9A%9B%E3%81%AEU-Boot%20ABI%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B39%3CBR%20%2F%3E%E5%86%85%E9%83%A8MDIO%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%3CBR%20%2F%3Eargc%20%3D%205%3CBR%20%2F%3E%E6%93%8D%E4%BD%9C%20%3D%20%22%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%22%3CBR%20%2F%3E%20MAC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%3D%20%220x8c47000%22%3CBR%20%2F%3E%20dev%20addr%20%3D%20%223%22%3CBR%20%2F%3E%20reg%20addr%20%3D%20%220%22%3CBR%20%2F%3E%20mdio_cfg%20bsy%20%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3Emdio_data%20bsy%20%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%3A%200x00000000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%23%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82rc%20%3D%200x0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1330005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1330005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E0x80300000%20%E3%81%B8%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E0x8c47000%203%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1329937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1329937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6mdio.bin%E3%82%920x80300000%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%80%81MAC%2017%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3D%26gt%3B%20md%200x8c47000%204%3CBR%20%2F%3E%2008c47000%3A%2000010200%2000000000%2000000810%2000000000%20...%3CBR%20%2F%3E%20%3D%26gt%3B%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%80%8CLX2160ADPAA2RM.PDF%E3%80%8D%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81MAC%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A8%98%E8%BF%B0%E3%81%AF%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22muaxi8_0-1629947381593.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22muaxi8_0-1629947381593.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F154148i45136B54BC9E2513%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22muaxi8_0-1629947381593.png%22%20alt%3D%22muaxi8_0-1629947381593.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1329916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1329916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EMAC%E3%81%A8PHY%E9%96%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E7%8A%B6%E6%85%8B%E3%81%AF%E3%81%A9%E3%81%86%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E8%A9%B3%E7%B4%B0%E3%81%AF%E4%B8%8B%E8%A8%98%E3%81%A7%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%20U-boot%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%A7%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%20printenv%20elf_load%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20elf_load%3Ddcache%20off%3B%20tftp%200x80300000%3CLOCATION%20of%3D%22%22%20mdio%3D%22%22%3E%20%2Fmdio.bin%3B%20dcache%20on%3B%3C%2FLOCATION%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20elf_load%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%200x80300000%20%E3%81%B8%E7%A7%BB%E5%8B%95%200x8c47000%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%203%20%7B0x8c47000%3A%20MAC%2017%20%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%7D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E6%9C%89%E5%8A%B9%E3%81%AAPCS%E3%83%AA%E3%83%B3%E3%82%AF%20ix%200x00000004%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E3%83%93%E3%83%83%E3%83%882%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1327571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1327571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E1.%20MAC18%E3%81%A7ping%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22tgt%22%3ERe%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22tgt%22%3EDpmac18%20(EC2)%20%E3%81%AF%E3%81%A9%E3%81%AE%20PHY%20%E3%81%AB%E3%82%82%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82mac17%3C%2FSPAN%3E%3CSPAN%20class%3D%22tgt%22%3E%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81SERDES2%20%E3%81%AE%20SGMII17%20%E3%81%AF%20AR8033%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%80%81EC1%20%E3%81%AF%20RGMII%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%20KSZ9896%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%20%E3%83%81%E3%83%83%E3%83%97%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22tgt%22%3E%E3%81%93%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81SGMII%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E3%81%BF%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81RGMII%20%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8A%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22muaxi8_1-1629705006869.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22muaxi8_1-1629705006869.png%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F153676i1AAEFD2A060C1704%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22muaxi8_1-1629705006869.png%22%20alt%3D%22muaxi8_1-1629705006869.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%EF%BC%88a%EF%BC%89uboot%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ERe%3A%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E7%9B%B4%E6%8E%A5%E5%8D%B0%E5%88%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82serdes2%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%20161.xxxMhz%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22muaxi8_0-1629703300147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22muaxi8_0-1629703300147.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F153673iCFE9887E38EA3656%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22muaxi8_0-1629703300147.png%22%20alt%3D%22muaxi8_0-1629703300147.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%EF%BC%88b%EF%BC%89PCA%3A%20%E9%81%A9%E5%88%87%E3%81%AA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%B6%E5%90%8D%EF%BC%9A%3CSPAN%3E%E5%BC%8A%E7%A4%BE%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFPCA9547%EF%BC%88I2C%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%80%81%E3%83%AC%E3%83%99%E3%83%AB1%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%A6%82%E7%95%A5%E5%9B%B3%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%93%BE%E6%8E%A5%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fpan.baidu.com%2Fs%2F14edfW8yig7c-qZyYTLk7xQ%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fpan.baidu.com%2Fs%2F14edfW8yig7c-qZyYTLk7xQ%3C%2FA%3E%3CBR%20%2F%3E%E6%8A%9C%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%9A2345%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1327509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1327509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%A3%9C%E8%B6%B3%E8%AA%AC%E6%98%8E%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSPAN%3E%20MAC18%E3%81%A7ping%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%20U-boot%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E5%A5%87%E5%A6%99%E3%81%AA%E7%82%B9%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%3E%EF%BC%88a%EF%BC%89uboot%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%EF%BC%88b%EF%BC%89PCA%3A%20%E9%81%A9%E5%88%87%E3%81%AA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMAC17%E3%81%A8MAC18%E3%81%AF%E5%90%8C%E3%81%98%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81MAC18%E3%81%AB%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%20start%3D%223%22%3E%0A%3CLI%3E%3CSPAN%3E%20%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1326633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1326633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E2%E5%9B%9E%E7%9B%AE%E3%81%AE%E9%96%B2%E8%A6%A7%E3%81%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22muaxi8_0-1629436586753.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22muaxi8_0-1629436586753.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F153524i517C7F3ABDC9C504%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22muaxi8_0-1629436586753.png%22%20alt%3D%22muaxi8_0-1629436586753.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1326594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1326594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Emdio%20read%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81SGMII%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E7%8A%B6%E6%85%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3D%26gt%3B%20mdio%E3%83%AA%E3%82%B9%E3%83%88%3CBR%20%2F%3EFSL_MDIO0%3A%3CBR%20%2F%3E%204%20-%20AR8031%2FAR8033%20%26lt%3B--%26gt%3B%20DPMAC17%40sgmii%3CBR%20%2F%3E%20FSL_MDIO1%3A%3CBR%20%2F%3E%20%3D%26gt%3B%20mdio%20read%20DPMAC17%40sgmii%201%3CBR%20%2F%3E%20FSL_MDIO0%E3%83%90%E3%82%B9%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B94%E3%81%AEPHY%3A%3CBR%20%2F%3E%201%20-%200x7969%3CBR%20%2F%3E%20%3D%26gt%3B%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%91%E3%83%BC%E3%83%88%E3%83%8A%E3%83%BC%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%E3%80%81PHY%E4%B8%8A%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%231%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%80%8D%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%E3%80%81%E6%9C%80%E5%BE%8C%E3%81%AE%E3%83%8B%E3%83%96%E3%83%AB%E3%81%AE%E5%B7%A6%E3%81%8B%E3%82%892%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%AF%E3%80%81%E6%B3%A8%E7%9B%AE%E3%81%99%E3%81%B9%E3%81%8D%E3%83%8B%E3%83%96%E3%83%AB%E3%81%AF%E3%80%8C9%E3%80%8D%EF%BC%88d%20%3D%20b'1001'%EF%BC%89%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%8C%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%80%8D%E3%81%AF0%E3%81%A8%E3%81%AA%E3%82%8A%E3%80%81%E3%80%8C%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%80%8D%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%E3%80%8C1%E3%80%8D%E3%81%A8%E3%81%AA%E3%82%8A%E3%80%810x796d%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AESGMII%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1326185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1326185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%93%E3%81%AE%E9%83%A8%E5%93%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82DPC%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9FDPC%E3%81%AE%E5%86%85%E5%AE%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1326122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1326122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eboard%2Ffreescale%2Flx2160a%2Feth_lx2160ardb.c%20%E5%86%85%E3%81%AE%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%80%81%E3%81%94%E4%BD%BF%E7%94%A8%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3Efor%20(i%20%3D%20WRIOP1_DPMAC17%3B%20i%20%26lt%3B%3D%20WRIOP1_DPMAC18%3B%20i%2B%2B)%20%7B%3CBR%20%2F%3E%20interface%20%3D%20wriop_get_enet_if(i)%3B%3CBR%20%2F%3E%20switch%20(%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9)%20%7B%3CBR%20%2F%3ECASE%20PHY_INTERFACE_MODE_RGMII%3A%3CBR%20%2F%3ECASE%20PHY_INTERFACE_MODE_RGMII_ID%3A%3CBR%20%2F%3E%20dev%20%3D%20miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME)%3B%3CBR%20%2F%3E%20wriop_set_mdio(i%2C%20dev)%3B%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3CBR%20%2F%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%0A%3CP%3E%E5%A4%89%E6%9B%B4%E5%BE%8C%3A%3C%2FP%3E%0A%3CP%3Efor%20(i%20%3D%20WRIOP1_DPMAC17%3B%20i%20%26lt%3B%3D%20WRIOP1_DPMAC18%3B%20i%2B%2B)%20%7B%3CBR%20%2F%3E%20interface%20%3D%20wriop_get_enet_if(i)%3B%3CBR%20%2F%3E%20switch%20(%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9)%20%7B%3CBR%20%2F%3ECASE%20PHY_INTERFACE_MODE_SGMII%3A%3CBR%20%2F%3E%20dev%20%3D%20miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME)%3B%3CBR%20%2F%3E%20wriop_set_mdio(i%2C%20dev)%3B%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3CBR%20%2F%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%E5%A3%8A%E3%81%99%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1324548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1324548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3D%26gt%3B%20ping%2010.0.1.119%3CBR%20%2F%3EDPMAC17%40sgmii%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EARP%E5%86%8D%E8%A9%A6%E8%A1%8C%E5%9B%9E%E6%95%B0%E3%81%8C%E4%B8%8A%E9%99%90%E3%82%92%E8%B6%85%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E5%BA%A6%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20ping%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9B%E3%82%B9%E3%83%88%EF%BC%9A10.0.1.119%E7%94%9F%E3%81%8D%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E7%A7%81%E3%81%AE%3CSPAN%3EPHY%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3EAR8033%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Econfigs%2Flx2160ardb_tfa_defconfig%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22muaxi8_0-1629188185935.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22muaxi8_0-1629188185935.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F153159i259FC88510F428C4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22muaxi8_0-1629188185935.png%22%20alt%3D%22muaxi8_0-1629188185935.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1324505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpmac17%20sgmii%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1324505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EU-Boot%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3D%26gt%3B%20mdio%E3%83%AA%E3%82%B9%E3%83%88%3CBR%20%2F%3EFSL_MDIO0%3A%3CBR%20%2F%3E%200%20-%20Cortina%20CS4223%20%26lt%3B--%26gt%3B%20DPMAC2%40xlaui4%3CBR%20%2F%3E%201%20-%20AR8035%20%26lt%3B--%26gt%3B%20DPMAC17%40rgmii-id%3CBR%20%2F%3E%202%20-%20AR8035%20%26lt%3B--%26gt%3B%20DPMAC18%40rgmii-id%3CBR%20%2F%3E%204%20-%20Aquantia%20AQR107%20%26lt%3B--%26gt%3B%20DPMAC3%40xgmii%3CBR%20%2F%3E%205%20-%20Aquantia%20AQR107%20%26lt%3B--%26gt%3B%20DPMAC4%40xgmii%3CBR%20%2F%3E%20FSL_MDIO1%3A%3CBR%20%2F%3E%200%20-%20Inphi%20in112525_S03P%20%26lt%3B--%26gt%3B%20%3CA%20href%3D%22mailto%3ADPMAC6%4025g-aui%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDPMAC6%4025g-aui%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3D%26gt%3B%20mdio%20read%20DPMAC17%40rgmii-id%201%3CBR%20%2F%3E%20FSL_MDIO0%E3%83%90%E3%82%B9%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B91%E3%81%AEPHY%3A%3CBR%20%2F%3E%201%20-%200x7949%3CBR%20%2F%3E%20%3D%26gt%3B%3C%2FP%3E%3CP%3E%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AEPHY%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%3CSPAN%3EAR8033%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9Fconfigs%2Flx2160ardb_tfa_defconfig%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECONFIG_PHYLIB%3Dy%3CBR%20%2F%3E%20CONFIG_PHY_ATHEROS%3Dy%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
