Vmcore cannot be decoded
zwg132883
I'm unable to decode the vmcore using "crash vmlinux vmcore" when booting with an embedded initramfs in the kernel. However, the vmcore.dmesg output is fine. I tested with both the original vmlinux and the vmlinux containing initramfs, but both returned "crash: vmlinux: no debugging data available."
Could you advise on how to troubleshoot this issue? Thanks.
The vmcore decode log and kernel configuration are attached.
June_Lu
Would you kindly share you CPU part number and SW version?
%3CLINGO-SUB%20id%3D%22lingo-sub-2203118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EVmcore%20cannot%20be%20decoded%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20unable%20to%20decode%20the%20vmcore%20using%20%22crash%20vmlinux%20vmcore%22%20when%20booting%20with%20an%20embedded%20initramfs%20in%20the%20kernel.%20However%2C%20the%20vmcore.dmesg%20output%20is%20fine.%20I%20tested%20with%20both%20the%20original%20vmlinux%20and%20the%20vmlinux%20containing%20initramfs%2C%20but%20both%20returned%20%22crash%3A%20vmlinux%3A%20no%20debugging%20data%20available.%22%3C%2FP%3E%3CP%3ECould%20you%20advise%20on%20how%20to%20troubleshoot%20this%20issue%3F%20Thanks.%3C%2FP%3E%3CP%3EThe%20vmcore%20decode%20log%20and%20kernel%20configuration%20are%20attached.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Vmcore%20cannot%20be%20decoded%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EWould%20you%20kindly%20share%20you%20CPU%20part%20number%20and%20SW%20version%3F%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E
