Uboot debugging in code warrior
2,253件の閲覧回数
rashmikj
I am trying to debug uboot using code warrior in LS1046ardb Kit. I followed the steps mentioned in CodeWarrior for ARMv8 Using in u.pdf.
It always stops at Break at address "0x100000d0" with no debug information available, or outside of program code.
When i fuse the corresponding fip_uboot.bin file in qspi flash , uboot comes up and i can see in uart logs.
2,227件の閲覧回数
Pavel
Do you use the AN4876 for u-boot debugging? See the following document:
https://www.nxp.com/docs/en/application-note/AN4876.pdf
