Typical current consumption values requiredcfor LX2160XE72232B
Aathi1122000
We are need of the typical current consumption of each I/O rails for calculating the typical power budget.We are already having maximum current consumption but we are required the typical current consumption.Could you please share the what are all the things needs to be considered for calculating the typical current consumption
yipingwang
We only provide the I/O power numbers for the worst conditions to assist in selecting the appropriate power supply design. The customer will have to do their own analysis depending on their use case for I/O switching and thermal solution.
