Request for Application Note AN3638
leavs
I'm using my custom LS1046A board.
I want to use EEPROM to store MAC address.
From the source code
uboot/board/freescale/common/sys_eeprom.c
I know there is one application note AN3638 to know the detail of EEPROM layout for CCID or NXID formats.
Can you share it with me?
And is there one Userland Application source code to access the EEPROM to write this EEPROM by using the CCID or NXID formats.
Thanks.
June_Lu
Please find https://www.nxp.com.cn/docs/en/application-note/AN3638.pdf
In the uboot use the command "i2c md 0x53 0x40 0x100" in LS1046ARDB, you could read the inform.
You could use uboot i2c command to change the IDs.
June_Lu
Sorry, could not find the Userland Application source code.
June_Lu
leavs
Thanks for your link.
Do you have one userland application to access this EEPROM?
