Reference Board Availability LS1046ARDB-PB
743件の閲覧回数
smiller2
I am working on a new design with the LS1046A.  The LS1046ARDB-PB is the closest to the configuration.   Unfortunately, there appears to be none of these boards available.   Every vendor has no stock and a long lead time.   This maybe due to the silicon shortage of the AQR107.  However, we designed that out due to the shortage issues.
Is there any scratch and dent, broken or partially working boards available?    We only need the processor, DIMM, QSPI, and SFP+ connector working.   I really concerned about booting this stripped down configuration over the network and would like to test the concept on the reference board before submitting the design.    The Boss bought the FRWY board as a substitute, but it does not have any of the critical HW.
Thank you.
0 返答(返信)
