LX2160A get MP key failed
Jeffrey_Lai
Hi NXP,
We are building LX2160A secure boot system based on LLDP and verifying MP key function.
Install and start up the secure boot system on our LX2160A board are OK and so we think ITS bit value is 1, but get "Device is not initiated" error after execute "mp_app -p" command.
Do you have any advice to check this issue ?
Thank you,
Jeffrey 
yipingwang
Did customer follow LLDP document section 6.4.4?
Such as
  1. Run tee-supplicant & command from the Linux prompt.
  2. Depending on the Linux kernel version used insmod securekeydev.ko from right folder
Please also let customer enable kernel printk when run 'mp_app', and share their log.
echo 8 > /proc/sys/kernel/printk
dmesg
Jeffrey_Lai
Hi yipingwang,
Yes, we start tee-supplicant and load securekeydev.ko before execute mp_app command.
The following is dmesg information.
Jeffrey
yipingwang
Please refer to the following update from the AE team.
From customer's feedback, I can see "error: caam_submit_mp_get_pub_key_op: submit_job", it indicates send job to SEC failed.
Please ask customer do below test in their Linux system,
1. run xtest, to see any error report?
2. please run "modprobe caam" to install caam module for LX2160, if install module failed, please update modules compatible with your kernel version.
3. If also report error, apply below patch to check SEC return result to identify the error type, and share their full log.
diff --git a/securekeydev/securekey_caam.c b/securekeydev/securekey_caam.c
index b82acd3..d657742 100644
--- a/securekeydev/securekey_caam.c
+++ b/securekeydev/securekey_caam.c
@@ -59,12 +59,14 @@ static int submit_job(struct device *jrdev, uint32_t *desc)
        /* Call caam_jr_enqueue function for Enqueue a job descriptor head. */
        ret = caam_jr_enqueue(jrdev, desc, caam_op_done, NULL);
+       pr_err("caam_jr_enqueue ret (%d)\n", ret);
        if (!ret)
                wait_for_completion_interruptible(&comp);
        else
                return ret;
        ret = job_comp_status;
+       pr_err("job_comp_status ret (%d)\n", ret);
        return ret;
Jeffrey_Lai
About your comments,
Please refer to attached xtest log.
We built caam module in kernel already.
The dmesg about caam and mp_app return as below.
截圖 2026-07-29 16.03.42.png截圖 2026-07-29 16.03.42.png截圖 2026-07-29 15.53.07.png截圖 2026-07-29 15.53.07.png
Thank you.
yipingwang
1. Please make sure caam job ring work well in Linux kernel, please run below command to check caam jr interrupt increase or not
root@localhost:~# cat /proc/interrupts | grep jr
378:         41          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0     GICv3 172 Level     8010000.jr
379:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0     GICv3 173 Level     8020000.jr
380:          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0     GICv3 174 Level     fsl-jr0
root@localhost:~#
root@localhost:~#
root@localhost:~# dd if=/dev/hwrng of=/tmp/random.dat bs=1 count=16
16+0 records in
16+0 records out
16 bytes copied, 0.000420759 s, 38.0 kB/s
root@localhost:~#
root@localhost:~#
378:         42          0          0          0          0          0          0          0          0          0          0          0          0          0          0          0     GICv3 172 Level     8010000.jr
root@localhost:~#
2. In submit_job() the called function caam_jr_enqueue() return (-EINPROGRESS = -115) on success. Please try apply below patch to check caam enqueue return result.
https://github.com/nxp-qoriq/linux/commit/4d370a1036958d7df9f1492c345b4984a4eba7f6#diff-8acc41c53445...
index b82acd3..808e8da 100644
-       if (!ret)
+       if (ret == -EINPROGRESS)
        else
                return ret;
        return ret;
Jeffrey_Lai
Ans: Yes
Ans: Our system uses Linux kernel v5.15.71-rt51 and it seems need not do any additional patches.
3. In addition, after run mp_app -p command, the process stops at wait_for_completion_interruptible() and it is waiting the return so far.
yipingwang
Please double check your kernel source code.
caam_jr_enqueue() has update return value in this brach.
https://github.com/nxp-qoriq/linux/blob/95448dd0dc9b621ae027cbefedaaa7c3d0d3ad2d/drivers/crypto/caam...
Jeffrey_Lai
We checked all drivers/crypto/caam source files and they are the same.
We enable ITS by uboot scripts as below
mw.l 0x1e80200 0x4
mw.l 0x1e80020 0x2
Do you think the ITS activation process is incomplete ?
yipingwang
Customer can check whether ITS bit enabled by u-boot 'md' command.
md 0x1e80200
Can customer share caam_jr_enqueue() function source code? The source code path is "linux/drivers/crypto/caam/jr.c".
Or they can share us their source code link.
Jeffrey_Lai
Register value please see below and jr.c source code please see attached file .
yipingwang
ITS bit has been blown.
Check your jr.c source code, you need to apply the patch for submit_job.
-       if (!ret)
        else
                return ret;
        return ret;
Jeffrey_Lai
We have patched submit_job() as you mentioned before and the result is stops at  "wait_for_completion_interruptible" after run "mp_app -p".
According to the description from LSDK and LLDP user manual, security applications are fully validated and verified on LS1046ARDB platform, we verify this issue on our LS1046 board with LSDK and it's working.
Verify our another LX2160 product with LSDK and it also stops at "wait_for_completion_interruptible".
Whether use LSDK or LLDP, we get the some issue on LX2160A platform.
Did NXP do security applications validation on LX2160A platform ?
yipingwang
1. Team confirms that this feature just be performed on LS1046A board as LSDK document mentioned.
2. From customer running log for LX2160 and LS1046, both run with LSDK20.04, kernel version 4.19, caam_jr_enqueue() return 0 in this version, not need apply my patch.
https://github.com/nxp-qoriq/linux/blob/94e0473db2feed7ed6b84848c8d227faf72297c2/drivers/crypto/caam...
3. I need further test on my side.
Will update when get findings.
%3CLINGO-SUB%20id%3D%22lingo-sub-2397586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%2C%3C%2FP%3E%3CP%3EWe%20are%20building%20LX2160A%20secure%20boot%20system%20based%20on%20LLDP%20and%20verifying%20MP%20key%20function.%3C%2FP%3E%3CP%3EInstall%20and%20start%20up%20the%20secure%20boot%20system%20on%20our%20LX2160A%20board%20are%20OK%20and%20so%20we%20think%20ITS%20bit%20value%20is%201%2C%20but%20get%20%22Device%20is%20not%20initiated%22%20error%20after%20execute%20%22mp_app%20-p%22%20command.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392878i85CE58FA86B90E53%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20alt%3D%22%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E6%88%AA%E5%9C%96%202026-07-22%2015.50.34.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDo%20you%20have%20any%20advice%20to%20check%20this%20issue%20%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%2C%3C%2FP%3E%3CP%3EJeffrey%E2%80%83%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDid%20customer%20follow%20LLDP%20document%20section%206.4.4%3F%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditoryipingwang_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22screenshot-1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393027iF5898213BC9C9235%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22screenshot-1.png%22%20alt%3D%22screenshot-1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Escreenshot-1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3ESuch%20as%3C%2FP%3E%0A%3COL%20start%3D%223%22%3E%0A%3CLI%3E%3CEM%3E%20Run%20tee-supplicant%20%26amp%3B%20command%20from%20the%20Linux%20prompt.%3C%2FEM%3E%3C%2FLI%3E%0A%3CLI%3E%3CEM%3E%20Depending%20on%20the%20Linux%20kernel%20version%20used%20insmod%20securekeydev.ko%20from%20right%20folder%3C%2FEM%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3EPlease%20also%20let%20customer%20enable%20kernel%20printk%20when%20run%20'mp_app'%2C%20and%20share%20their%20log.%3C%2FP%3E%0A%3CP%3E%3CEM%3Eecho%208%20%26gt%3B%20%2Fproc%2Fsys%2Fkernel%2Fprintk%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3Edmesg%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3Eyipingwang%3C%2FA%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EYes%2C%20we%20start%20tee-supplicant%20and%20load%26nbsp%3B%3CEM%3Esecurekeydev.ko%20before%20execute%20mp_app%20command.%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-left%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20style%3D%22width%3A%20837px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393132i4C82B2D4DB715748%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E6%88%AA%E5%9C%96%202026-07-24%2014.22.00.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EThe%20following%20is%20dmesg%20information.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393133i6D7703B19AF79BD5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20alt%3D%22%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E6%88%AA%E5%9C%96%202026-07-24%2014.22.27.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EJeffrey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20refer%20to%20the%20following%20update%20from%20the%20AE%20team.%3C%2FP%3E%0A%3CP%3EFrom%20customer's%20feedback%2C%20I%20can%20see%20%22error%3A%20caam_submit_mp_get_pub_key_op%3A%20submit_job%22%2C%20it%20indicates%20send%20job%20to%20SEC%20failed.%3C%2FP%3E%0A%3CP%3EPlease%20ask%20customer%20do%20below%20test%20in%20their%20Linux%20system%2C%3CBR%20%2F%3E1.%20run%20xtest%2C%20to%20see%20any%20error%20report%3F%3CBR%20%2F%3E2.%20please%20run%20%22modprobe%20caam%22%20to%20install%20caam%20module%20for%20LX2160%2C%20if%20install%20module%20failed%2C%20please%20update%20modules%20compatible%20with%20your%20kernel%20version.%3CBR%20%2F%3E3.%20If%20also%20report%20error%2C%20apply%20below%20patch%20to%20check%20SEC%20return%20result%20to%20identify%20the%20error%20type%2C%20and%20share%20their%20full%20log.%3C%2FP%3E%0A%3CDIV%20class%3D%22code%20panel%22%3E%0A%3CDIV%20class%3D%22codeContent%20panelContent%22%3E%0A%3CPRE%20class%3D%22code-java%22%3Ediff%20--git%20a%2Fsecurekeydev%2Fsecurekey_caam.c%20b%2Fsecurekeydev%2Fsecurekey_caam.c%0Aindex%20b82acd3..d657742%20100644%0A---%20a%2Fsecurekeydev%2Fsecurekey_caam.c%0A%2B%2B%2B%20b%2Fsecurekeydev%2Fsecurekey_caam.c%0A%40%40%20-59%2C12%20%2B59%2C14%20%40%40%20%3CSPAN%20class%3D%22code-keyword%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22code-object%22%3Eint%3C%2FSPAN%3E%20submit_job(struct%20device%20*jrdev%2C%20uint32_t%20*desc)%0A%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-comment%22%3E%2F*%20Call%20caam_jr_enqueue%20function%20%3CSPAN%20class%3D%22code-keyword%22%3Efor%3C%2FSPAN%3E%20Enqueue%20a%20job%20descriptor%20head.%20*%2F%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20ret%20%3D%20caam_jr_enqueue(jrdev%2C%20desc%2C%20caam_op_done%2C%20NULL)%3B%0A%2B%20%20%20%20%20%20%20pr_err(%3CSPAN%20class%3D%22code-quote%22%3E%22caam_jr_enqueue%20ret%20(%25d)%5Cn%22%3C%2FSPAN%3E%2C%20ret)%3B%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Eif%3C%2FSPAN%3E%20(!ret)%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20wait_for_completion_interruptible(%26amp%3Bcomp)%3B%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Eelse%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Ereturn%3C%2FSPAN%3E%20ret%3B%0A%0A%20%20%20%20%20%20%20%20ret%20%3D%20job_comp_status%3B%0A%2B%20%20%20%20%20%20%20pr_err(%3CSPAN%20class%3D%22code-quote%22%3E%22job_comp_status%20ret%20(%25d)%5Cn%22%3C%2FSPAN%3E%2C%20ret)%3B%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Ereturn%3C%2FSPAN%3E%20ret%3B%0A%20%7D%0A%0A%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAbout%20your%20comments%2C%3C%2FP%3E%3CP%3E1.%20run%20xtest%2C%20to%20see%20any%20error%20report%3F%3C%2FP%3E%3CP%3EPlease%20refer%20to%20attached%20xtest%20log.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20please%20run%20%22modprobe%20caam%22%20to%20install%20caam%20module%20for%20LX2160%2C%20if%20install%20module%20failed%2C%20please%20update%20modules%20compatible%20with%20your%20kernel%20version.%3C%2FP%3E%3CP%3EWe%20built%20caam%20module%20in%20kernel%20already.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E3.%20If%20also%20report%20error%2C%20apply%20below%20patch%20to%20check%20SEC%20return%20result%20to%20identify%20the%20error%20type%2C%20and%20share%20their%20full%20log.%3C%2FP%3E%3CP%3EThe%20dmesg%20about%20caam%20and%20mp_app%20return%20as%20below.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393365iE9F202FAA33916BC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E6%88%AA%E5%9C%96%202026-07-29%2016.03.42.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20style%3D%22width%3A%20630px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393366iE59B314DA33370CF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20alt%3D%22%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E6%88%AA%E5%9C%96%202026-07-29%2015.53.07.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EThank%20you.%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2400375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2400375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.%20Please%20make%20sure%20caam%20job%20ring%20work%20well%20in%20Linux%20kernel%2C%20please%20run%20below%20command%20to%20check%20caam%20jr%20interrupt%20increase%20or%20not%3C%2FP%3E%0A%3CDIV%20class%3D%22code%20panel%22%3E%0A%3CDIV%20class%3D%22codeContent%20panelContent%22%3E%0A%3CPRE%20class%3D%22code-java%22%3Eroot%40localhost%3A~%23%20cat%20%2Fproc%2Finterrupts%20%7C%20grep%20jr%0A378%3A%20%20%20%20%20%20%20%20%2041%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20172%20Level%20%20%20%20%208010000.jr%0A379%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20173%20Level%20%20%20%20%208020000.jr%0A380%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20174%20Level%20%20%20%20%20fsl-jr0%0Aroot%40localhost%3A~%23%0Aroot%40localhost%3A~%23%0Aroot%40localhost%3A~%23%20dd%20%3CSPAN%20class%3D%22code-keyword%22%3Eif%3C%2FSPAN%3E%3D%2Fdev%2Fhwrng%20of%3D%2Ftmp%2Frandom.dat%20bs%3D1%20count%3D16%0A16%2B0%20records%20in%0A16%2B0%20records%20out%0A16%20bytes%20copied%2C%200.000420759%20s%2C%2038.0%20kB%2Fs%0Aroot%40localhost%3A~%23%0Aroot%40localhost%3A~%23%0Aroot%40localhost%3A~%23%20cat%20%2Fproc%2Finterrupts%20%7C%20grep%20jr%0A378%3A%20%20%20%20%20%20%20%20%2042%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20172%20Level%20%20%20%20%208010000.jr%0A379%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20173%20Level%20%20%20%20%208020000.jr%0A380%3A%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20%20%20%20%20%200%20%20%20%20%20GICv3%20174%20Level%20%20%20%20%20fsl-jr0%0Aroot%40localhost%3A~%23%0A%0A%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3E2.%20In%20submit_job()%20the%20called%20function%20caam_jr_enqueue()%20return%20(-EINPROGRESS%20%3D%20-115)%20on%20success.%20Please%20try%20apply%20below%20patch%20to%20check%20caam%20enqueue%20return%20result.%3CBR%20%2F%3E%3CA%20class%3D%22external-link%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Flinux%2Fcommit%2F4d370a1036958d7df9f1492c345b4984a4eba7f6%23diff-8acc41c534456288daba59a125ddb3f779635dc493ff4888545adbf1dd0a17c1R327%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Flinux%2Fcommit%2F4d370a1036958d7df9f1492c345b4984a4eba7f6%23diff-8acc41c534456288daba59a125ddb3f779635dc493ff4888545adbf1dd0a17c1R327%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22code%20panel%22%3E%0A%3CDIV%20class%3D%22codeContent%20panelContent%22%3E%0A%3CPRE%20class%3D%22code-java%22%3Ediff%20--git%20a%2Fsecurekeydev%2Fsecurekey_caam.c%20b%2Fsecurekeydev%2Fsecurekey_caam.c%0Aindex%20b82acd3..808e8da%20100644%0A---%20a%2Fsecurekeydev%2Fsecurekey_caam.c%0A%2B%2B%2B%20b%2Fsecurekeydev%2Fsecurekey_caam.c%0A%40%40%20-59%2C12%20%2B59%2C14%20%40%40%20%3CSPAN%20class%3D%22code-keyword%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22code-object%22%3Eint%3C%2FSPAN%3E%20submit_job(struct%20device%20*jrdev%2C%20uint32_t%20*desc)%0A%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-comment%22%3E%2F*%20Call%20caam_jr_enqueue%20function%20%3CSPAN%20class%3D%22code-keyword%22%3Efor%3C%2FSPAN%3E%20Enqueue%20a%20job%20descriptor%20head.%20*%2F%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20ret%20%3D%20caam_jr_enqueue(jrdev%2C%20desc%2C%20caam_op_done%2C%20NULL)%3B%0A-%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Eif%3C%2FSPAN%3E%20(!ret)%0A%2B%20%20%20%20%20%20%20pr_err(%3CSPAN%20class%3D%22code-quote%22%3E%22caam_jr_enqueue%20ret%20(%25d)%5Cn%22%3C%2FSPAN%3E%2C%20ret)%3B%0A%2B%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Eif%3C%2FSPAN%3E%20(ret%20%3D%3D%20-EINPROGRESS)%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20wait_for_completion_interruptible(%26amp%3Bcomp)%3B%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Eelse%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Ereturn%3C%2FSPAN%3E%20ret%3B%0A%0A%20%20%20%20%20%20%20%20ret%20%3D%20job_comp_status%3B%0A%2B%20%20%20%20%20%20%20pr_err(%3CSPAN%20class%3D%22code-quote%22%3E%22job_comp_status%20ret%20(%25d)%5Cn%22%3C%2FSPAN%3E%2C%20ret)%3B%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Ereturn%3C%2FSPAN%3E%20ret%3B%0A%20%7D%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2400827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2400827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E1.%20Please%20make%20sure%20caam%20job%20ring%20work%20well%20in%20Linux%20kernel%2C%20please%20run%20below%20command%20to%20check%20caam%20jr%20interrupt%20increase%20or%20not%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAns%3A%20Yes%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393511i1EBD1BBA245B343C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E6%88%AA%E5%9C%96%202026-07-31%2017.33.06.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%20In%20submit_job()%20the%20called%20function%20caam_jr_enqueue()%20return%20(-EINPROGRESS%20%3D%20-115)%20on%20success.%20Please%20try%20apply%20below%20patch%20to%20check%20caam%20enqueue%20return%20result.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAns%3A%20Our%20system%20uses%20Linux%20kernel%20v5.15.71-rt51%20and%20it%20seems%20need%20not%20do%20any%20additional%20patches.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E3.%20In%20addition%2C%20after%20run%20mp_app%20-p%20command%2C%20the%20process%20stops%20at%20wait_for_completion_interruptible()%20and%20it%20is%20waiting%20the%20return%20so%20far.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393513i3D728F46AD48B801%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20alt%3D%22%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E6%88%AA%E5%9C%96%202026-07-31%2017.33.36.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EPlease%20double%20check%20your%20kernel%20source%20code.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Ecaam_jr_enqueue()%20has%20update%20return%20value%20in%20this%20brach.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CA%20class%3D%22external-link%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Flinux%2Fblob%2F95448dd0dc9b621ae027cbefedaaa7c3d0d3ad2d%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L565%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Flinux%2Fblob%2F95448dd0dc9b621ae027cbefedaaa7c3d0d3ad2d%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L565%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20refer%20to%20the%20following%20update%20from%20the%20AE%20team.%3C%2FP%3E%0A%3CP%3ECustomer%20can%20check%20whether%20ITS%20bit%20enabled%20by%20u-boot%20'md'%20command.%3CBR%20%2F%3Emd%200x1e80200%3C%2FP%3E%0A%3CP%3ECan%20customer%20share%20caam_jr_enqueue()%20function%20source%20code%3F%20The%20source%20code%20path%20is%20%22linux%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%22.%3CBR%20%2F%3EOr%20they%20can%20share%20us%20their%20source%20code%20link.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20checked%20all%20drivers%2Fcrypto%2Fcaam%20source%20files%20and%20they%20are%20the%20same.%3C%2FP%3E%3CP%3EWe%20enable%20ITS%20by%20uboot%20scripts%20as%20below%3C%2FP%3E%3CP%3Emw.l%200x1e80200%200x4%3C%2FP%3E%3CP%3Emw.l%200x1e80020%200x2%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDo%20you%20think%20the%20ITS%20activation%20process%20is%20incomplete%20%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ERegister%20value%20please%20see%20below%20and%20jr.c%20source%20code%20please%20see%20attached%20file%20.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22list_register.png%22%20style%3D%22width%3A%20637px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22list_register.png%22%20style%3D%22width%3A%20637px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22list_register.png%22%20style%3D%22width%3A%20637px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22list_register.png%22%20style%3D%22width%3A%20637px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22list_register.png%22%20style%3D%22width%3A%20637px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393745i487A78912760A296%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22list_register.png%22%20alt%3D%22list_register.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elist_register.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2402080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2402080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20have%20patched%26nbsp%3B%3CSPAN%3Esubmit_job()%20as%20you%20mentioned%26nbsp%3Bbefore%20and%20the%20result%20is%20stops%20at%20%26nbsp%3B%22wait_for_completion_interruptible%22%20after%20run%20%22mp_app%20-p%22.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAccording%20to%20the%20description%20from%20LSDK%20and%20LLDP%20user%20manual%2C%20security%20applications%20%3C%2FSPAN%3Eare%20fully%20validated%20and%20verified%20on%20LS1046ARDB%20platform%2C%20we%20verify%20this%20issue%20on%20our%20LS1046%20board%20with%20LSDK%20and%20it's%20working.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lx1046_mp_key.png%22%20style%3D%22width%3A%20872px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lx1046_mp_key.png%22%20style%3D%22width%3A%20872px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lx1046_mp_key.png%22%20style%3D%22width%3A%20872px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lx1046_mp_key.png%22%20style%3D%22width%3A%20872px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393757i2F0EFB7190C85896%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22lx1046_mp_key.png%22%20alt%3D%22lx1046_mp_key.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elx1046_mp_key.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EVerify%20our%20another%20LX2160%20product%20with%20LSDK%20and%20it%20also%20stops%20at%26nbsp%3B%3CSPAN%3E%22wait_for_completion_interruptible%22.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lx2160_lsdk.png%22%20style%3D%22width%3A%20572px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lx2160_lsdk.png%22%20style%3D%22width%3A%20572px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lx2160_lsdk.png%22%20style%3D%22width%3A%20572px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lx2160_lsdk.png%22%20style%3D%22width%3A%20572px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393758i58BCD333B70687E0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22lx2160_lsdk.png%22%20alt%3D%22lx2160_lsdk.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elx2160_lsdk.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EWhether%20use%20LSDK%20or%20LLDP%2C%20we%20get%20the%20some%20issue%20on%20LX2160A%20platform.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDid%20NXP%20do%20security%20applications%20validation%20on%20LX2160A%20platform%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EITS%20bit%20has%20been%20blown.%3CBR%20%2F%3ECheck%20your%20jr.c%20source%20code%2C%20you%20need%20to%20apply%20the%20patch%20for%20submit_job.%3C%2FP%3E%0A%3CDIV%20class%3D%22code%20panel%22%3E%0A%3CDIV%20class%3D%22codeContent%20panelContent%22%3E%0A%3CPRE%20class%3D%22code-java%22%3Ediff%20--git%20a%2Fsecurekeydev%2Fsecurekey_caam.c%20b%2Fsecurekeydev%2Fsecurekey_caam.c%0Aindex%20b82acd3..808e8da%20100644%0A---%20a%2Fsecurekeydev%2Fsecurekey_caam.c%0A%2B%2B%2B%20b%2Fsecurekeydev%2Fsecurekey_caam.c%0A%40%40%20-59%2C12%20%2B59%2C14%20%40%40%20%3CSPAN%20class%3D%22code-keyword%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22code-object%22%3Eint%3C%2FSPAN%3E%20submit_job(struct%20device%20*jrdev%2C%20uint32_t%20*desc)%0A%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-comment%22%3E%2F*%20Call%20caam_jr_enqueue%20function%20%3CSPAN%20class%3D%22code-keyword%22%3Efor%3C%2FSPAN%3E%20Enqueue%20a%20job%20descriptor%20head.%20*%2F%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20ret%20%3D%20caam_jr_enqueue(jrdev%2C%20desc%2C%20caam_op_done%2C%20NULL)%3B%0A-%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Eif%3C%2FSPAN%3E%20(!ret)%0A%2B%20%20%20%20%20%20%20pr_err(%3CSPAN%20class%3D%22code-quote%22%3E%22caam_jr_enqueue%20ret%20(%25d)%5Cn%22%3C%2FSPAN%3E%2C%20ret)%3B%0A%2B%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Eif%3C%2FSPAN%3E%20(ret%20%3D%3D%20-EINPROGRESS)%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20wait_for_completion_interruptible(%26amp%3Bcomp)%3B%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Eelse%3C%2FSPAN%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Ereturn%3C%2FSPAN%3E%20ret%3B%0A%0A%20%20%20%20%20%20%20%20ret%20%3D%20job_comp_status%3B%0A%2B%20%20%20%20%20%20%20pr_err(%3CSPAN%20class%3D%22code-quote%22%3E%22job_comp_status%20ret%20(%25d)%5Cn%22%3C%2FSPAN%3E%2C%20ret)%3B%0A%20%20%20%20%20%20%20%20%3CSPAN%20class%3D%22code-keyword%22%3Ereturn%3C%2FSPAN%3E%20ret%3B%0A%20%7D%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2403203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2160A%20get%20MP%20key%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20refer%20to%20the%20following%20update%20from%20the%20AE%20team.%3C%2FP%3E%0A%3CTABLE%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%3E1.%20Team%20confirms%20that%20this%20feature%20just%20be%20performed%20on%20LS1046A%20board%20as%20LSDK%20document%20mentioned.%3CBR%20%2F%3E2.%20From%20customer%20running%20log%20for%20LX2160%20and%20LS1046%2C%20both%20run%20with%20LSDK20.04%2C%20kernel%20version%204.19%2C%20caam_jr_enqueue()%20return%200%20in%20this%20version%2C%20not%20need%20apply%20my%20patch.%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Feur01.safelinks.protection.outlook.com%2F%3Furl%3Dhttps%253A%252F%252Fgithub.com%252Fnxp-qoriq%252Flinux%252Fblob%252F94e0473db2feed7ed6b84848c8d227faf72297c2%252Fdrivers%252Fcrypto%252Fcaam%252Fjr.c%2523L408%26amp%3Bdata%3D05%257C02%257Cyiping.wang%2540nxp.com%257C5acc47330e5b461864d408def6b36c85%257C686ea1d3bc2b4c6fa92cd99c5c301635%257C0%257C0%257C639219447658850167%257CUnknown%257CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%253D%253D%257C0%257C%257C%257C%26amp%3Bsdata%3D1LkfZ4F%252FAH4jBewzzRRpvmhqpY%252BSa%252FpL4z1mmuKtnqw%253D%26amp%3Breserved%3D0%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Flinux%2Fblob%2F94e0473db2feed7ed6b84848c8d227faf72297c2%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L408%3C%2FA%3E%3CBR%20%2F%3E3.%20I%20need%20further%20test%20on%20my%20side.%3C%2FP%3E%0A%3CP%3EWill%20update%20when%20get%20findings.%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E
