[LX2160A] SEC return error when run dpdk application
2,447件の閲覧回数
Jeffrey_Lai
Hi NXP,
We have an issue when run our dpdk application on LX2160A.
After run our dpak application after few hours, we get "SEC returned Error - 400000f1" message.
We try to trace dpdk source and find out if increase dpaa2_dpcp_ctxt struct hfn_threshold value, the issue has been postponed.
Do you get any similar issues and how to solve it ?
Could you tell us hfn_threshold is used for ?
Thank you,
Jeffrey Lai
3 返答(返信)
2,402件の閲覧回数
yipingwang
Please refer to app/test/test_cryptodev.c in DPDK source code, there are some unite test cases containing the section how to use Scatter Gather buffers which are supported in DPAA_SEC driver.
Would you please check whether you used Scatter Gather buffers similar as this test case.
                TEST_CASE_ST(ut_setup, ut_teardown,
                             test_AES_chain_dpaa_sec_all),
                             test_3DES_chain_dpaa_sec_all),
                             test_AES_cipheronly_dpaa_sec_all),
                             test_3DES_cipheronly_dpaa_sec_all),
                             test_authonly_dpaa_sec_all),
                /** Scatter-Gather */
                        test_AES_GCM_auth_encrypt_SGL_in_place_1500B),
                        test_AES_GCM_auth_encrypt_SGL_out_of_place_400B_400B),
                        test_AES_GCM_auth_encrypt_SGL_out_of_place_400B_1seg),
                        test_AES_GCM_auth_encrypt_SGL_out_of_place_1500B_2000B),
2,432件の閲覧回数
yipingwang
Which version LSDK are your using?
2,413件の閲覧回数
Jeffrey_Lai
Hi Yiping,
We use LSDK 20.04
Jeffrey
