LX2080
LX2080
889件の閲覧回数
YY2410
During the LX2080 processor's uboot startup phase, it occasionally gets stuck at the following print position:
“Loading Environment from SPIFlash... SF: Detected mx25uw51245g with page size 256 Bytes, erase size 64 KiB, total 64 MiB
OK
EEPROM: Read failed.
In: serial_pl01x
Out: serial_pl01x
Err: serial_pl01x
Net: Could not get PHY for mdio@8b97000: addr 15”
It should be an MDIO initialization exception that directly causes the system to hang. I want to implement a timeout retry. How can this be done in the device tree?
タグ(2)
831件の閲覧回数
yipingwang
In u-boot dts file arch/arm/dts/fsl-lx2160a-rdb.dts, please modify "reg" value as the real PHY address on MDIO bus.
&emdio1 {
status = "okay";
cortina_phy: ethernet-phy@0 {
reg = <0x0>;//modify as you real PHY address.
rgmii_phy1: ethernet-phy@1 {
/* AR8035 PHY - "compatible" property not strictly needed */
compatible = "ethernet-phy-id004d.d072";
reg = <0x1>;//modify as you real PHY address.
/* Poll mode - no "interrupts" property defined */
rgmii_phy2: ethernet-phy@2 {
reg = <0x2>;//modify as you real PHY address.
aquantia_phy1: ethernet-phy@4 {
/* AQR107 PHY - "compatible" property not strictly needed */
compatible = "ethernet-phy-ieee802.3-c45";
interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
reg = <0x4>;//modify as you real PHY address.
aquantia_phy2: ethernet-phy@5 {
interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>;
reg = <0x5>;//modify as you real PHY address.
%3CLINGO-SUB%20id%3D%22lingo-sub-2326261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ELX2080%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%20uboot%20%E8%B5%B7%E5%8B%95%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E4%B8%AD%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E5%8D%B0%E5%88%B7%E4%BD%8D%E7%BD%AE%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E%E3%80%8CSPIFlash%E3%81%8B%E3%82%89%E7%92%B0%E5%A2%83%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20SF%3A%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA256%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E6%B6%88%E5%8E%BB%E3%82%B5%E3%82%A4%E3%82%BA64%20KiB%E3%80%81%E5%90%88%E8%A8%8864%20MiB%E3%81%AEmx25uw51245g%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EEEPROM%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%85%A5%E5%8A%9B%3A%20serial_pl01x%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%87%BA%E5%8A%9B%3A%20serial_pl01x%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20serial_pl01x%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3ENet%3A%20mdio%408b97000%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%2015%20%E3%81%AE%20PHY%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%8F%E3%83%B3%E3%82%B0%E3%82%92%E7%9B%B4%E6%8E%A5%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%99%E3%81%AE%E3%81%AF%E3%80%81MDIO%20%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BE%8B%E5%A4%96%E3%81%AE%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%9F%E3%81%84%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LX2080%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eu-boot%20dts%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABarch%2Farm%2Fdts%2Ffsl-lx2160a-rdb.dts%E3%81%A7%E3%81%AF%E3%80%81MDIO%20%E3%83%90%E3%82%B9%E4%B8%8A%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%20PHY%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E3%80%8Creg%E3%80%8D%E5%80%A4%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%26amp%3Bemdio1%20%7B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%0A%3CP%3Ecortina_phy%3A%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%400%20%7B%3CBR%20%2F%3E%20reg%20%3D%20%26lt%3B0x0%26gt%3B%3B%20%3CSTRONG%3E%2F%2F%E5%AE%9F%E9%9A%9B%E3%81%AEPHY%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3Ergmii_phy1%3A%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%401%20%7B%3CBR%20%2F%3E%20%2F*%20AR8035%20PHY%20-%20%E3%80%8C%E4%BA%92%E6%8F%9B%E6%80%A7%E3%80%8D%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AF%E5%8E%B3%E5%AF%86%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20*%2F%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22ethernet-phy-id004d.d072%22%3B%3CBR%20%2F%3E%20reg%20%3D%20%26lt%3B0x1%26gt%3B%3B%20%3CSTRONG%3E%2F%2F%E5%AE%9F%E9%9A%9B%E3%81%AEPHY%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%7D%3B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%2F*%20%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%20-%20%E3%80%8C%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%80%8D%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AF%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20*%2F%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20rgmii_phy2%3A%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%402%20%7B%3CBR%20%2F%3E%20%2F*%20AR8035%20PHY%20-%20%E3%80%8C%E4%BA%92%E6%8F%9B%E6%80%A7%E3%80%8D%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AF%E5%8E%B3%E5%AF%86%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20*%2F%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22ethernet-phy-id004d.d072%22%3B%3CBR%20%2F%3E%20reg%20%3D%20%26lt%3B0x2%26gt%3B%3B%20%3CSTRONG%3E%2F%2F%E5%AE%9F%E9%9A%9B%E3%81%AEPHY%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%7D%3B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%2F*%20%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%20-%20%E3%80%8C%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%80%8D%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AF%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20*%2F%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20aquantia_phy1%3A%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%404%20%7B%3CBR%20%2F%3E%20%2F*%20AQR107%20PHY%20-%20%E3%80%8C%E4%BA%92%E6%8F%9B%E6%80%A7%E3%80%8D%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AF%E5%8E%B3%E5%AF%86%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20*%2F%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy-ieee802.3-c45%22%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20%3D%20%3CGIC_SPI%202%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%3CBR%20%2F%3E%20reg%20%3D%20%26lt%3B0x4%26gt%3B%3B%20%3CSTRONG%3E%2F%2F%E5%AE%9F%E9%9A%9B%E3%81%AEPHY%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%7D%3B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20aquantia_phy2%3A%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%405%20%7B%3CBR%20%2F%3E%20%2F*%20AQR107%20PHY%20-%20%E3%80%8C%E4%BA%92%E6%8F%9B%E6%80%A7%E3%80%8D%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AF%E5%8E%B3%E5%AF%86%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20*%2F%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy-ieee802.3-c45%22%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20%3D%20%3CGIC_SPI%203%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%3CBR%20%2F%3E%20reg%20%3D%20%26lt%3B0x5%26gt%3B%3B%20%3CSTRONG%3E%2F%2F%E5%AE%9F%E9%9A%9B%E3%81%AEPHY%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%7D%3B%3C%2FSTRONG%3E%3C%2FGIC_SPI%3E%3C%2FGIC_SPI%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
