LSDK20.04-isc-19 Memory Error
2,667 次查看
Chidananda22
Hi All,
Previously I was using LSDK20.04-isc-09 . All running fine.
Now compiling my application with LSDK20.04-isc-19. Getting issue while pool creation .
It hangs . in GDB i can see stack corrupted .
compared . config and config/defconfig_arm64-dpaa-linuxapp-gcc.
Disabled :
CONFIG_RTE_LA12XX_SOCKET_ID=0
CONFIG_RTE_LA12XX_SOCKET_MAX_SEG=0
Any memory and pool related changes I need to take care in my application.
Please suggest
标记 (1)
2,590 次查看
Chidananda22
Thanks @LFGP .
Resolved after migrating to isc-23 . All application are up and running .
6 回复数
2,627 次查看
Chidananda22
Hi @LFGP
Verified with LSDK 21.08 . Same result. Stuck in memory allocation  .
Currently our application working fine with isc-09 . But while migrating to isc-19 it is stuck in memory allocation .
Working Logs
  • fslmc: fslmc_get_container_group(): Container: dprc.2 has VFIO iommu group id = 11
  • fslmc: fslmc_vfio_setup_group(): VFIO Container FD is [0x1D]
  • fslmc: fslmc_map_dma(): --> Map address: 0x140000000, size: 1073741824
  • fslmc: rte_fslmc_vfio_dmamap(): Installed memory callback handler
  • fslmc: rte_fslmc_vfio_dmamap(): Total 1 segments found.
  • fslmc: Unable to map region (errno = 22)
  • fslmc: dpaa2_get_qbman_swp(): New Portal 0x17ffec3c0 (2) affined thread - 2340
  • fslmc: dpaa2_configure_stashing(): Portal= 2  CPU= 3 SDEST= 1
  • fslmc: DPAA Portal=0x17ffec3c0 (2) is affined to thread 2340
  • fslmc: dpaa2_get_qbman_swp(): New Portal 0x17ffe4dc0 (3) affined thread - 2341
  • fslmc: dpaa2_configure_stashing(): Portal= 3  CPU= 2 SDEST= 1
  • fslmc: DPAA Portal=0x17ffe4dc0 (3) is affined to thread 2341
  • fslmc: fslmc_memevent_cb(): Request for alloc, va=0x1c0000000, virt_addr=0x1c0000000, iova=0x1c0000000, map_len=1073741824
  • fslmc: fslmc_map_dma(): --> Map address: 0x1c0000000, size: 1073741824
  • fslmc: fslmc_memevent_cb(): Total Mapped: addr=0x1c0000000, len=1073741824
  • fslmc: dpaa2_get_qbman_swp(): New Portal 0x17ffdd7c0 (4) affined thread - 2338
  • fslmc: dpaa2_configure_stashing(): Portal= 4  CPU= 1 SDEST= 0
  • fslmc: DPAA Portal=0x17ffdd7c0 (4) is affined for eth rx to thread 2338
  • fslmc: fslmc_memevent_cb(): Request for alloc, va=0x200000000, virt_addr=0x200000000, iova=0x200000000, map_len=1073741824
Not working Logs
  • fslmc: fslmc_get_group_id(): GROUP(dprc.2) has VFIO iommu group id = 11
  • fslmc: fslmc_vfio_setup_group(): VFIO GROUP FD is 28
  • fslmc: fslmc_map_dma(): DMA MEM map size(40000000): VA(140000000):IOVA(140000000):PHY(2700000000)
  • fslmc NOTICE: DMA MEM map size(40000000): VA(140000000):IOVA(140000000):PHY(2700000000)
Stuck Here
  • fslmc: fslmc_memevent_cb(): alloc, va=0x180000000, virt=180000000, iova=180000000, len=1073741824
  • fslmc: fslmc_map_dma(): DMA MEM map size(40000000): VA(180000000):IOVA(180000000):PHY(26c0000000)
recompiled again with
No success . If any quick help based on above logs .
2,614 次查看
LFGP
dear @Chidananda22
please be sure regarding the free space to allocate the DMA.
On the other hand, please set the CONFIG_DEBUG_FS, CONFIG_DMA_API_DEBUG in the Kernel, in order to get out more info about the issue.
could you please share the complete logs for isc-09 and isc-19 as a compressed file.
2,591 次查看
Chidananda22
Thanks @LFGP .
2,578 次查看
LFGP
Dear @Chidananda22,
that is a great new, thanks for share your findings.
LFGP
2,627 次查看
Chidananda22
 thanks @LFGP  for your quick response . I will use 21.08 LSDK and update you ,
2,641 次查看
LFGP
dear @Chidananda22 ,
there were several updates between  both releases (LSDK20.04-isc-09-Ubuntu 18 and  LSDK20.04-isc-19-Ubuntu20).
You need to upgrade your developer environment. Please considere to use the LSDK21.08 release.
LFGP
%3CLINGO-SUB%20id%3D%22lingo-sub-2161509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELSDK20.04-isc-19%20%E5%86%85%E5%AD%98%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B9%8B%E5%89%8D%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%3CSPAN%3ELSDK20.04-isc-09%E3%80%82%E4%B8%80%E5%88%87%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%8E%B0%E5%9C%A8%E7%94%A8%20LSDK20.04-isc-19%20%E7%BC%96%E8%AF%91%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E6%B1%A0%E5%88%9B%E5%BB%BA%E6%97%B6%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%20.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9C%A8%20GDB%20%E4%B8%AD%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E5%A0%86%E6%A0%88%E5%B7%B2%E6%8D%9F%E5%9D%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%9B%B8%E6%AF%94%E4%B9%8B%E4%B8%8Bconfig%20%E5%92%8C%20config%2Fdefconfig_arm64-dpaa-linuxapp-gcc%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AE%8B%E7%96%BE%E4%BA%BA%20%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Econfig_rte_la12xx_socket_id%3D0%3C%2FP%3E%3CP%3Econfig_rte_la12xx_socket_max_seg%3D0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%B3%A8%E6%84%8F%E4%BB%BB%E4%BD%95%E4%B8%8E%E5%86%85%E5%AD%98%E5%92%8C%E6%B1%A0%E7%9B%B8%E5%85%B3%E7%9A%84%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%8F%90%E5%87%BA%E5%BB%BA%E8%AE%AE%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224905%22%20target%3D%22_blank%22%3E%40Chidananda22%3C%2FA%3E%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E4%BC%9F%E5%A4%A7%E7%9A%84%E6%96%B0%E5%8F%91%E7%8E%B0%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E5%88%86%E4%BA%AB%E6%82%A8%E7%9A%84%E5%8F%91%E7%8E%B0%E3%80%82%3CBR%20%2F%3EBR%3CBR%20%2F%3ELFGP%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203371%22%20target%3D%22_blank%22%3E%40LFGP%3C%2FA%3E.%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%81%E7%A7%BB%E5%88%B0%20isc-23%20%E5%90%8E%E5%B7%B2%E8%A7%A3%E5%86%B3%E3%80%82%E6%89%80%E6%9C%89%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%9D%87%E5%B7%B2%E5%90%AF%E5%8A%A8%E5%B9%B6%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224905%22%20target%3D%22_blank%22%3E%40Chidananda22%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E8%AF%B7%E7%A1%AE%E5%AE%9A%E5%88%86%E9%85%8D%20DMA%20%E7%9A%84%E5%8F%AF%E7%94%A8%E7%A9%BA%E9%97%B4%E3%80%82%3CBR%20%2F%3E%E5%8F%A6%E4%B8%80%E6%96%B9%E9%9D%A2%EF%BC%8C%E8%AF%B7%E5%9C%A8%E5%86%85%E6%A0%B8%E4%B8%AD%E8%AE%BE%E7%BD%AE%20CONFIG_DEBUG_FS%E3%80%81CONFIG_DMA_API_DEBUG%EF%BC%8C%E4%BB%A5%E4%BE%BF%E8%8E%B7%E5%BE%97%E6%9C%89%E5%85%B3%E8%AF%A5%E9%97%AE%E9%A2%98%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E4%BB%A5%E5%8E%8B%E7%BC%A9%E6%96%87%E4%BB%B6%E5%BD%A2%E5%BC%8F%E5%85%B1%E4%BA%AB%20isc-09%20%E5%92%8C%20isc-19%20%E7%9A%84%E5%AE%8C%E6%95%B4%E6%97%A5%E5%BF%97%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203371%22%20target%3D%22_blank%22%3E%40LFGP%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20LSDK%2021.08%20%E9%AA%8C%E8%AF%81%E3%80%82%E7%BB%93%E6%9E%9C%E4%B8%80%E6%A0%B7%E3%80%82%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%E5%8D%A1%E4%BD%8F%20.%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E4%BD%BF%E7%94%A8%20isc-09%20%E6%97%B6%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%E4%BD%86%E5%9C%A8%E8%BF%81%E7%A7%BB%E5%88%B0%20isc-19%20%E6%97%B6%EF%BC%8C%E5%AE%83%E5%8D%A1%E5%9C%A8%E4%BA%86%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%E4%B8%8A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%B7%A5%E4%BD%9C%E6%97%A5%E5%BF%97%3C%2FP%3E%3CUL%3E%3CLI%3Efslmc%EF%BC%9Afslmc_get_container_group()%EF%BC%9AContainer%3A%20dprc.2%20has%20VFIO%20iommu%20group%20id%20%3D%2011%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Afslmc_vfio_setup_group()%EF%BC%9AVFIO%20%E5%AE%B9%E5%99%A8%20FD%20%E4%B8%BA%20%5B0x1D%5D%20%E3%80%82%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Afslmc_map_dma()%EF%BC%9A--%26gt%3B%20Map%20address%EF%BC%9A0x140000000%EF%BC%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A1073741824%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9A%20rte_fslmc_vfio_dmamap()%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E5%86%85%E5%AD%98%E5%9B%9E%E8%B0%83%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Arte_fslmc_vfio_dmamap()%EF%BC%9A%E5%85%B1%E6%89%BE%E5%88%B0%201%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E6%AE%B5%E3%80%82%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9A%E6%97%A0%E6%B3%95%E6%98%A0%E5%B0%84%E5%8C%BA%E5%9F%9F%EF%BC%88errno%20%3D%2022%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3Efslmc%EF%BC%9A%20dpaa2_get_qbman_swp()%EF%BC%9A%E6%96%B0%E5%85%A5%E5%8F%A3%200x17ffec3c0%20(2)%20%E4%BA%B2%E5%92%8C%E7%BA%BF%E7%A8%8B%20-%202340%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9A%20dpaa2_configure_stashing()%EF%BC%9APortal%3D%202%20CPU%3D%203%20SDEST%3D%201%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9ADPAA%20Portal%3D0x17ffec3c0%20(2)%20%E4%B8%8E%E7%BA%BF%E7%A8%8B%202340%20%E5%85%B3%E8%81%94%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9A%20dpaa2_get_qbman_swp()%EF%BC%9A%E6%96%B0%E5%85%A5%E5%8F%A3%200x17ffe4dc0%20(3)%20%E4%BA%B2%E5%92%8C%E7%BA%BF%E7%A8%8B%20-%202341%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9A%20dpaa2_configure_stashing()%EF%BC%9APortal%3D%203%20CPU%3D%202%20SDEST%3D%201%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9ADPAA%20Portal%3D0x17ffe4dc0%20(3)%20%E4%B8%8E%E7%BA%BF%E7%A8%8B%202341%20%E5%85%B3%E8%81%94%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Afslmc_memevent_cb()%EF%BC%9A%E8%AF%B7%E6%B1%82%E5%88%86%E9%85%8D%2C%20va%3D0x1c0000000%2C%20virt_addr%3D0x1c0000000%2C%20iova%3D0x1c0000000%2C%20map_len%3D1073741824%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Afslmc_map_dma()%EF%BC%9A--%26gt%3B%20Map%20address%EF%BC%9A0x1c0000000%EF%BC%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A1073741824%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Afslmc_memevent_cb()%EF%BC%9A%E6%80%BB%E6%98%A0%E5%B0%84%EF%BC%9Aaddr%3D0x1c0000000%EF%BC%8Clen%3D1073741824%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9A%20dpaa2_get_qbman_swp()%EF%BC%9A%E6%96%B0%E5%85%A5%E5%8F%A3%200x17ffdd7c0%20(4)%20%E4%BA%B2%E5%92%8C%E7%BA%BF%E7%A8%8B%20-%202338%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9A%20dpaa2_configure_stashing%EF%BC%88%EF%BC%89%EF%BC%9APortal%3D%204%20CPU%3D%201%20SDEST%3D%200%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9ADPAA%20Portal%3D0x17ffdd7c0%20(4)%20%E4%B8%8E%E7%BA%BF%E7%A8%8B%202338%20%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%20rx%20%E5%85%B3%E8%81%94%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Afslmc_memevent_cb()%EF%BC%9A%E8%AF%B7%E6%B1%82%E5%88%86%E9%85%8D%2C%20va%3D0x200000000%2C%20virt_addr%3D0x200000000%2C%20iova%3D0x200000000%2C%20map_len%3D1073741824%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8D%E5%B7%A5%E4%BD%9C%20%E6%97%A5%E5%BF%97%3C%2FP%3E%3CUL%3E%3CLI%3Efslmc%EF%BC%9Afslmc_get_group_id()%EF%BC%9AGROUP(dprc.2)%20%E6%9C%89%20VFIO%20iommu%20%E7%BB%84%20ID%20%3D%2011%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Afslmc_vfio_setup_group()%EF%BC%9AVFIO%20GROUP%20FD%20%E4%B8%BA%2028%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Afslmc_map_dma()%EF%BC%9ADMA%20MEM%20%E6%98%A0%E5%B0%84%E5%A4%A7%E5%B0%8F%EF%BC%8840000000%EF%BC%89%EF%BC%9AVA(140000000)%3AIOVA(140000000)%3APHY(2700000000)%3C%2FLI%3E%3CLI%3Efslmc%20NOTICE%3A%20DMA%20MEM%20%E6%98%A0%E5%B0%84%E5%A4%A7%E5%B0%8F%EF%BC%8840000000%EF%BC%89%EF%BC%9AVA(140000000)%3AIOVA(140000000)%3APHY(2700000000)%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9A%20rte_fslmc_vfio_dmamap()%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E5%86%85%E5%AD%98%E5%9B%9E%E8%B0%83%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Arte_fslmc_vfio_dmamap()%EF%BC%9A%E5%85%B1%E6%89%BE%E5%88%B0%201%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E6%AE%B5%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%3CU%3E%E5%9B%B0%E5%9C%A8%E8%BF%99%E9%87%8C%20%3C%2FU%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3Efslmc%3A%20fslmc_memevent_cb()%3A%20alloc%2C%20va%3D0x180000000%2C%20virt%3D180000000%2C%20iova%3D180000000%2C%20len%3D1073741824%3C%2FLI%3E%3CLI%3Efslmc%EF%BC%9Afslmc_map_dma()%EF%BC%9ADMA%20MEM%20%E6%98%A0%E5%B0%84%E5%A4%A7%E5%B0%8F%EF%BC%8840000000%EF%BC%89%EF%BC%9AVA(180000000)%3AIOVA(180000000)%3APHY(26c0000000)%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E9%87%8D%E6%96%B0%E7%BC%96%E8%AF%91%3C%2FP%3E%3CP%3Econfig_rte_la12xx_socket_id%3D0%3C%2FP%3E%3CP%3Econfig_rte_la12xx_socket_max_seg%3D0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%20.%E8%AF%B7%E6%A0%B9%E6%8D%AE%E4%B8%8A%E8%BF%B0%E6%97%A5%E5%BF%97%E6%8F%90%E4%BE%9B%E5%BF%AB%E9%80%9F%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203371%22%20target%3D%22_blank%22%3E%40LFGP%3C%2FA%3E%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E5%B0%86%E4%BD%BF%E7%94%A8%2021.08%20LSDK%20%E5%B9%B6%E5%90%91%E6%82%A8%E6%9B%B4%E6%96%B0%E3%80%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224905%22%20target%3D%22_blank%22%3E%40Chidananda22%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%B8%A4%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B9%8B%E9%97%B4%E9%83%BD%E6%9C%89%E5%87%A0%E6%AC%A1%E6%9B%B4%E6%96%B0%EF%BC%88%3CSPAN%3Elsdk20.04-isc-09-Ubuntu%2018%20%E5%92%8C%20lsdk20.04-is%3C%2FSPAN%3E%20c-19-ubuntu20%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%82%A8%E9%9C%80%E8%A6%81%E5%8D%87%E7%BA%A7%E6%82%A8%E7%9A%84%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E7%8E%AF%E5%A2%83%E3%80%82%E8%AF%B7%E8%80%83%E8%99%91%E4%BD%BF%E7%94%A8%20LSDK21.08%20%E7%89%88%E6%9C%AC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ELFGP%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
