LS46ardb Kit
LS46ardb Kit
rashmikj
Using flex-builder , am able to compile openssl and cryptodev linux. How to generate qspi image for the same to load in LS1046ardb kit.
yipingwang
You could generate QSPI firmware image with the following command.
$ flex-builder -i mkfw -b qspi -m ls1046ardb
You could get firmware_ls1046ardb_uboot_qspiboot.img in <installtion_folder>/flexbuild_lsdk2004/build/images/.
