LS1046ardb Boot from SD Card
1,739件の閲覧回数
rashmikj
I am trying download bootpartition into SD card . When i run the command
flex-installer -b bootpartition_LS_arm64_lts_5.4.tgz -r rootfs_lsdk2004_ubuntu_main_arm64.tgz -
d /dev/sdc
sdc is my sd card,
following error crops up
"Not found bootpartition_LS_arm64_lts_5.4.tgz"
I have attached the screenshot of the error.
Kindly help.
1,734件の閲覧回数
yipingwang
You could download default LSDK images for LS1046ARDB: rootfs_lsdk2004_ubuntu_main_arm64.tgz,
firmware_ls1046ardb_uboot_sdboot.img, and bootpartition_LS_arm64_lts_5.4.tgz with the following command.
$ flex-installer -i download -m ls1046ardb
Or only download bootpartition_LS_arm64_lts_5.4.tgz with the following command.
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2004/bootpartition_LS_arm64_lts_5.4.tgz
