LS1046ARDB RTIC Throttle value
已解决
跳至解决方案
3,405 次查看
Faizanbaig
Hi ,
I am trying to configure RTIC(Run time integrity Checker) on LS1046ARDB board. I want to set RTIC throttle register but I did not find any reference values for setting the Throttle value . Is there any additional document other than Trust2.1 and SECRM manual that can help us in  deciding the throttle value?
Any suggestions would be appreciated.
Faizanbaig
标签 (1)
1 解答
3,392 次查看
yipingwang
RTIC throttle register is to define how many SEC engine clocks to wait to launch the next descriptor to hash the next block of data. This is used to keep RTIC from using too much bus bandwidth.
So it depends on your use case and whether you are using the SEC engine for other operations (e.g. IPsec, VPN, TLS, etc).
I will suggest initially set RTIC Throttle (RTHR) at 0x176001c to 0xff000000, and adjust the value accordingly to your use case.
在原帖中查看解决方案
3 回复数
3,393 次查看
yipingwang
2,608 次查看
Faizanbaig
In this  "set RTIC Throttle (RTHR) at 0x176001c to 0xff000000"  what does 0xff000000 means?
3,380 次查看
Faizanbaig
