LS1046A app component problem
1,247件の閲覧回数
rashmikj
I am trying to include simple hello.c example program in generic app component without git repository in KDK 20.04 and compiling using flex builder. It is not building . I have attached the source file, make file and error shown. Kindly help.
4 返答(返信)
1,237件の閲覧回数
yipingwang
Please put attached generic folder in packages/apps/ folder, then add "CONFIG_APP_HELLO=y" in file configs/build_lsdk.cfg.
After running command "flex-builder -c hello -m ls1046ardb", you will find HELLO in folder flexbuild_lsdk2004/build/apps/components_LS_arm64_ubuntu/usr/bin/.
1,227件の閲覧回数
rashmikj
Thanks for the solution. I ran the following commands to build the qspi image
flex-builder -i merge-component -a arm64
flex-builder -i mkfw -m ls1046ardb -b qspi
I downloaded the image in the kit and logged in as root, but am unable to find the HELLO.
Where will i find the HELLO in the kit and how to run it in the kit.
Kindly help.
1,220件の閲覧回数
yipingwang
Then execute the following commands
$ flex-builder -i clean-apps
$ flex-builder  -c hello -r yocto:tiny
$ flex-builder -i merge-component -r yocto:tiny
$ flex-builder -i mkrfs -r yocto:tiny (generate rootfs_lsdk2004_yocto_tiny_arm64.cpio.gz,~22M)
$ flex-builder -i mklinux -r yocto:tiny (generate lsdk2004_yocto_tiny_LS_arm64.itb)
$ flex-builder -i mkfw -m ls1046ardb -b qspi
1,203件の閲覧回数
yipingwang
Please replace  packages/apps/generic/generic.mk with the attached file.
