LS1046A L1 and L2 cache ECC
已解决
跳至解决方案
2,381 次查看
DaT63
Is ECC enabled by default for L1 and L2 caches on the LS1046A?
I know that this information is contained in register L2CTLR_EL1 , but I wonder if it is possible by program to access this register
Thanks in advance
标记 (4)
1 解答
2,273 次查看
Hector_Villarruel
Hello @DaT63
Hope this post finds you well,
Yes, that is right.
As I inform you on my last reply:
L1 instruction, L1 data, and L2 caches, a Single-bit ECC correction is always enabled and is handled siliently.
Have a great day.
BR,
Hector V
在原帖中查看解决方案
3 回复数
2,317 次查看
Hector_Villarruel
Hello @DaT63
Hope this email finds you well,
I apologize for the short delay regarding this case.
I would like to inform you that So for L1 instruction, L1 data, and L2 caches, a Single-bit ECC correction is always enabled and is handled siliently.
Regarding the L2CTLR_EL1,  in order to avoid any kind of confusion and keep the information as clear as possible, could you please let us know the register location in our LS1046A documentation?
Have a great day.
Hector Villarruel
2,307 次查看
DaT63
Hi @Hector_Villarruel ,
thank you for the reply. The L2CTLR_EL1 register is indicated in the ARM® Cortex®-A72 MPCore Processor TRM  that is accompanying the LS1046A Reference Manual. In any case if you state that ECC is always enabled  I do not need to check such a register and I can accept your  reply as solution
KInd Regards
标记 (4)
2,274 次查看
Hector_Villarruel
Hello @DaT63
Yes, that is right.
Have a great day.
BR,
Hector V
%3CLINGO-SUB%20id%3D%22lingo-sub-2004402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046A%20L1%20%E5%92%8C%20L2%20%E7%BC%93%E5%AD%98%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2004402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELS1046A%20%E4%B8%8A%E7%9A%84%20L1%20%E5%92%8C%20L2%20%E7%BC%93%E5%AD%98%E6%98%AF%E5%90%A6%E9%BB%98%E8%AE%A4%E5%90%AF%E7%94%A8%20ECC%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%E8%AF%A5%E4%BF%A1%E6%81%AF%E5%8C%85%E5%90%AB%E5%9C%A8%E5%AF%84%E5%AD%98%E5%99%A8%20L2CTLR_EL1%20%E4%B8%AD%EF%BC%8C%E4%BD%86%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E7%A8%8B%E5%BA%8F%E8%AE%BF%E9%97%AE%E8%AF%A5%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALS1046A%20L1%20%E5%92%8C%20L2%20%E7%BC%93%E5%AD%98%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200047%22%20target%3D%22_blank%22%3E%40Hector_Villarruel%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82L2CTLR_EL1%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%9C%A8%20LS1046A%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E9%99%84%E5%B8%A6%E7%9A%84%20ARM%20%C2%AE%20Cortex%20%C2%AE%20-A72%20MPCore%20%E5%A4%84%E7%90%86%E5%99%A8%20TRM%20%E4%B8%AD%E6%9C%89%E6%89%80%E8%AF%B4%E6%98%8E%E3%80%82%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E5%A3%B0%E6%98%8E%20ECC%20%E5%A7%8B%E7%BB%88%E5%A4%84%E4%BA%8E%E5%90%AF%E7%94%A8%E7%8A%B6%E6%80%81%EF%BC%8C%E6%88%91%E4%B8%8D%E9%9C%80%E8%A6%81%E6%A3%80%E6%9F%A5%E8%BF%99%E6%A0%B7%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8E%A5%E5%8F%97%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E4%BD%9C%E4%B8%BA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FP%3E%3CP%3E%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
