Xenomai support LS1046
2,066件の閲覧回数
LeoBriand
Hello everyone!
Has anyone successfully enabled Xenomai support on the LS1046ARDB? I noticed that someone managed to do this on the LS1043, so I’m wondering if there are any tips or guidance for achieving the same on the LS1046.
I’m fairly new to dual-kernel concepts and would appreciate any advice or resources you could share.
Thanks in advance!
Léo
タグ(2)
3 返答(返信)
2,016件の閲覧回数
yipingwang
Please refer to "Chapter 9 Xenomai" in
https://www.nxp.com.cn/docs/en/user-guide/OpenILUG-1.11.pdf
2,013件の閲覧回数
LeoBriand
Hello, thank you for your message. Unfortunately, I can't find the place that explains how to create the Xenomai Cobalt image.
1,966件の閲覧回数
yipingwang
Xenomai is officially supported by NXP in Industrial IoT Solution Customer Release.The dual kernel core is codenamed Cobalt, the native Linux implementation is called Mercury.Both Mercury and Cobalt are supported. For details, please refer to "Chapter 9 Xenomai". You need to get the OpenIL source code to build the platform related images, the release tarballs are available at "https://github.com/openil/openil", for details please refer to "Chapter 3 Getting started" section in https://www.nxp.com.cn/docs/en/user-guide/OpenILUG-1.11.pdf.
Please try whether you could use the following method to build your own Xenomai application in OpenIL.
Please go to Xenomai build folder openil/output/build/xenomai-2.6.4, please refer to the test program clocktest in src/testsuite/clocktest/ as an example.
After add your app code in Xenomai source code folder, please run make xenomai-reconfigure, followed by make or make xenomai, it will restart the configuration, compilation and installation of the package.
For details please refer to "8.3. Understanding how to rebuild packages" in https://buildroot.org/downloads/manual/manual.html#getting-buildroot.
