LS1046 RESET_REQ and RSTRQSR
SimonRo
We are seeing RESET_REQ_B asserted on our custom LS1046 hardware. When we read RSTRQSR we get the following:
md 1ee00C8
01ee00c8: 00480000 00000000 00000000 00000000
If I'm ordering my bytes correctly that means:
MBEE_RR (Multi-bit ECC reset request) and
SRDS_RST_RR (SerDes reset event. Occurs if any enabled SerDes PLL does not lock.)
Can anyone confirm that my decoding of this is correct, and suggest what might cause MBEE_RR? I'm unsure where to start looking with this.
Tags (2)
SimonRo
We fixed the issue - we had got our values for SRDS_PLL_PD_S1 and SRDS_PLL_PD_S2 wrong - the reference manual is a bit confusing for these. Once we sorted that out the error went away.
SimonRo
SimonRo
I've powered down SERDES by setting SRDS_PLL_PD_S1 and SRDS_PLL_PD_S2 to 0.
My RCW now looks like this:
       00000000: 0c150010 10000000 00000000 00000000
       00000010: 11330559 40000012 60040000 c1000000
       00000020: 00000000 00000000 00000000 10038ffe
       00000030: 20124000 04261301 00000096 00000001
But still RESET_REQ_B is asserted:
=> md 1ee0000
01ee0000: 7f7f7720 0000004f 00000000 00000000     w..O...........
01ee0010: 00000000 00000000 00000000 00000000    ................
01ee0020: 00000000 00000000 00000000 00000000    ................
01ee0030: 00000000 00000000 00000000 00000000    ................
01ee0040: 00000000 00000000 00000000 00000000    ................
01ee0050: 00000000 00000000 00000000 00000000    ................
01ee0060: 00000000 00000000 00000000 00000000    ................
01ee0070: 00000000 00000000 00000000 00000000    ................
01ee0080: 00000000 00000000 00000000 00000000    ................
01ee0090: 00000000 00000000 00000000 00000000    ................
01ee00a0: 00000000 10010787 40000000 00000000    ...........@....
01ee00b0: 00000000 00000000 00000000 00000000    ................
01ee00c0: 00400000 00000000 00480000 00000000    [email protected].....
01ee00d0: 00000000 00000000 00000000 00000000    ................
01ee00e0: 00000000 00000000 00000000 00000000    ................
01ee00f0: 00000000 00000000 00000000 00000000    ................
Which I think is: SRDS_RST_RR (SerDes reset event. Occurs if any enabled SerDes PLL does not lock.)
I'm wondering why I see this if SERDES is powered down?
LFGP
Dear @SimonRo,
could you please appoint in what step of the "4.4.1 Power-on reset sequence " you are seeing the issue?
or is it happening after booting up ends?
I need more info in order to understood what could be happening.
%3CLINGO-SUB%20id%3D%22lingo-sub-2050777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046%20RESET_REQ%20and%20RSTRQSR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2050777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20are%20seeing%20RESET_REQ_B%20asserted%20on%20our%20custom%20LS1046%20hardware.%20When%20we%20read%20RSTRQSR%20we%20get%20the%20following%3A%3C%2FP%3E%3CP%3Emd%201ee00C8%3C%2FP%3E%3CP%3E01ee00c8%3A%2000480000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3EIf%20I'm%20ordering%20my%20bytes%20correctly%20that%20means%3A%3C%2FP%3E%3CP%3EMBEE_RR%20(Multi-bit%20ECC%20reset%20request)%20and%3C%2FP%3E%3CP%3ESRDS_RST_RR%20(SerDes%20reset%20event.%20Occurs%20if%20any%20enabled%20SerDes%20PLL%20does%20not%20lock.)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECan%20anyone%20confirm%20that%20my%20decoding%20of%20this%20is%20correct%2C%20and%20suggest%20what%20might%20cause%20MBEE_RR%3F%20I'm%20unsure%20where%20to%20start%20looking%20with%20this.%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046%20RESET_REQ%20and%20RSTRQSR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20fixed%20the%20issue%20-%20we%20had%20got%20our%20values%20for%26nbsp%3BSRDS_PLL_PD_S1%20and%26nbsp%3BSRDS_PLL_PD_S2%20wrong%20-%20the%20reference%20manual%20is%20a%20bit%20confusing%20for%20these.%20Once%20we%20sorted%20that%20out%20the%20error%20went%20away.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046%20RESET_REQ%20and%20RSTRQSR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDear%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244524%22%20target%3D%22_blank%22%3E%40SimonRo%3C%2FA%3E%2C%3CBR%20%2F%3Ecould%20you%20please%20appoint%20in%20what%20step%20of%20the%20%224.4.1%20Power-on%20reset%20sequence%20%22%20you%20are%20seeing%20the%20issue%3F%3CBR%20%2F%3Eor%20%20is%20it%20happening%20after%20booting%20up%20ends%3F%3CBR%20%2F%3EI%20need%20more%20info%20in%20order%20to%20understood%20what%20could%20be%20happening.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2053711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046%20RESET_REQ%20and%20RSTRQSR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2053711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20powered%20down%20SERDES%20by%20setting%26nbsp%3BSRDS_PLL_PD_S1%20and%26nbsp%3BSRDS_PLL_PD_S2%20to%200.%3C%2FP%3E%3CP%3EMy%20RCW%20now%20looks%20like%20this%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%20%20%20%20%20%20%2000000000%3A%200c150010%2010000000%2000000000%2000000000%0A%20%20%20%20%20%20%2000000010%3A%2011330559%2040000012%2060040000%20c1000000%0A%20%20%20%20%20%20%2000000020%3A%2000000000%2000000000%2000000000%2010038ffe%0A%20%20%20%20%20%20%2000000030%3A%2020124000%2004261301%2000000096%2000000001%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EBut%20still%26nbsp%3B%3CSPAN%3ERESET_REQ_B%20is%20asserted%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%3D%26gt%3B%20md%201ee0000%0A01ee0000%3A%207f7f7720%200000004f%2000000000%2000000000%20%20%20%20%20w..O...........%0A01ee0010%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee0020%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee0030%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee0040%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee0050%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee0060%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee0070%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee0080%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee0090%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee00a0%3A%2000000000%2010010787%2040000000%2000000000%20%20%20%20...........%40....%0A01ee00b0%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee00c0%3A%2000400000%2000000000%2000480000%2000000000%20%20%20%20..%40.......H.....%0A01ee00d0%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee00e0%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%0A01ee00f0%3A%2000000000%2000000000%2000000000%2000000000%20%20%20%20................%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EWhich%20I%20think%20is%3A%26nbsp%3B%3CSPAN%3ESRDS_RST_RR%20(SerDes%20reset%20event.%20Occurs%20if%20any%20enabled%20SerDes%20PLL%20does%20not%20lock.)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI'm%20wondering%20why%20I%20see%20this%20if%20SERDES%20is%20powered%20down%3F%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
