LS1046 INTERFACE WITH DDR4
4,469 次查看
Ellu24
Can I interface ls1046 with MT53D1024M32D4DT-046 DDR4.Datasheet is attached below. If possible, 1) 1) how data lines should be connected
2) can I connect this with ls1046 since it doesn't have ECC.
4,464 次查看
yipingwang
MT53D1024M32D4DT-046 is an LPDDR4/LPDDR4X SDRAM. LS1046A only supports DDR4 and does not support LPDDR4/4X.
4,460 次查看
Ellu24
Can you please suggest a DDR4 for me to use?
4,461 次查看
Ellu24
Thank you for the reply. So I am not able to use it, right?
4,465 次查看
yipingwang
