LS1043A QSPI Serial Clock Configuration
2,274件の閲覧回数
j_wallace
Hi experts.
Looking at the LS1043AQDS rcw+pbi, there is PBI command to setup QSPI serial clock configuration (SCFG_QSPI_CFG).
0957015c 40100000
Fields description is:
0–3 (CLK_SEL) = 4 = 0100 Divide by 20
4–31(Reserved) = 0100000
Could you please describe the bit set in the reserved field?
Best Regards
タグ(2)
2 返答(返信)
2,122件の閲覧回数
ufedor
There is no customer-available description for the specific bit - it just must be set.
2,122件の閲覧回数
j_wallace
OK.
Thanks for your quick response. Unless I missed something, that sould have been documented somwhere...
Best regards.
