LS1043 GPIO internal pull-up/pull-down
1,119件の閲覧回数
bhargavjayswal
I have read chapter 24 from technical reference manual  LS1043 ARDB, where I can not found any register to configure internal pull-up /pull-down for GPIO. So Just wanted to confirm that there is no option available to set internal pull-up/pull-down when we configure pin as GPIO. Request you to confirm this.
1,081件の閲覧回数
Oswalag
You are correct, due to GPIO signals are typically multiplexed with other signals there is no option available to set internal pull-up/pull-down when we configure pin as GPIO.
