LS1043 CPLD READ
LS1043 CPLD READ
carlos-m-ribeiro
Good afternoon, we are using an u-boot for ls1043 in QSPI with our custom board but if we read from address 0x7fb00000 where we have our cpld, the value read is always 0xff:
=> md.b 0x7fb00000 1
7fb00000: ff .
7fb00000: ff .
=> md.b 0x7fb00000 2
7fb00000: ff ff
We verify all configurations and we did many tests since many weaks ago. If possible, with your experience, could you review quickly our IFC configurations in attached files.
Thank you
ufedor
How exactly the RCW[IFC_MODE] value is altered?
Have you edited the ".rcw" file and rebuild the composite firmware image?
Please provide SPI firmware binary images operational and with altered RCW for inspection.
carlos-m-ribeiro
Good morning,
I am programming the swapped QSPI RCW binary file (see file) with the RCW[IFC_MODE] value altered in QSPI address 0x0 and after I am programming the u-boot.bin file in QSPI address 0x100000.
Thank you
ufedor
Which exactly method you are using to modify the RCW field value?
carlos-m-ribeiro
Changing only the IFC mode using code warrior and maintaining the rest of RCW equal.
Thank you
ufedor
Please note that there is CRC which has to be re-calculated after the RCW change.
carlos-m-ribeiro
Thank you for your advise. Now, we can boot from QSPI but all CPLD reads from 0x7fb00000 are 0xff.
