LS1028ARM flex timer missing registers in reference manual
Choliver
Greetings, in the section 19.5.3.1 page 2588 from the LS1028A Reference Manual rev 0 , the next registers are missing:
  • FLTCTRL.
  • QUADCTL.
  • FLTPOL.
Do you have the offset table, function, diagram and the fields info of these registers?.
Best regards.
Chavira
Thank you for contacting NXP support!
On page 2589 you can see all registers of Flex Timer.
The registers that you mentioned do not exist.
In the register "FLTCTRL" do you refer to "Status And Control (SC)"?
I attached the block diagram of the Flex Timer (page 2587).
