LS1028 Pinmux
LS1028 Pinmux
nybwc
Seems PinMux tool in Codewarrior 11.5.0 for LS1028a is not correct?  several pins are different from the datasheet.
Hector_Villarruel
Hello @nybwc
Hope this post finds you well,
Could you please specify which pinouts are incorrect?
I have CodeWarrior version 11.5.0 and have verified several pins and they are correct.
I am using the QorIQ LS1028A/LS1018A, Rev. 0, 12/2019 datasheet.
Attached in the case there is an image in reference of one of the pins I have chosen.
Hector Villarruel
nybwc
Here are a few conflict I saw.  Not sure if this is all.  Basically I saw differences and I could trust the pinmux.
Hector_Villarruel
Hello @nybwc
This post is to inform you that we keep working on this case.
Regarding the "Analog" image in reference attached by you, this signal does not appear since they are  for internal use as signal Description section of the datasheet indicates " Internal Use Only ". This signal is related to the analog part of the PLL and the internal regulator of the device, I highly recommend you to follow their respective note for the FA_ANALOG_PIN  signal." 15. These pins must be pulled to ground (GND)."
I'll keep you informed.
Hector Villarruel Silvadoray
nybwc
no problem we are not using this pin I was just pointing out differences between datasheet and pinmux
Hector_Villarruel
Hello @nybwc
Apologies for delay.
SWITCH_S*_* signals are internal-only, not for showing in any customer documentation. Therefore, it is not present in data sheet and Reference manual.
The QCVS pin tool is not updated and shows these internal pins.
As per the tools team, it will not be updated.
Have a great day.
Hector Villarruel
%3CLINGO-SUB%20id%3D%22lingo-sub-1741452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1028%20Pinmux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1741452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESeems%20PinMux%20tool%20in%20Codewarrior%2011.5.0%20for%20LS1028a%20is%20not%20correct%3F%26nbsp%3B%20several%20pins%20are%20different%20from%20the%20datasheet.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1763438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028%20Pinmux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1763438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224496%22%20target%3D%22_blank%22%3E%40nybwc%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EHope%20this%20post%20finds%20you%20well%2C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EApologies%20for%20delay.%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3ESWITCH_S*_*%20signals%20are%20internal-only%2C%20not%20for%20showing%20in%20any%20customer%20documentation.%20%3C%2FSPAN%3E%3CSPAN%3ETherefore%2C%20it%20is%20not%20present%20in%20data%20sheet%20and%20Reference%20manual.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EThe%20QCVS%20pin%20tool%20is%20not%20updated%20and%20shows%20these%20internal%20pins.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EAs%20per%20the%20tools%20team%2C%20it%20will%20not%20be%20updated.%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EHave%20a%20great%20day.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBest%20Regards%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EHector%20Villarruel%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1752934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028%20Pinmux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1752934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eno%20problem%20we%20are%20not%20using%20this%20pin%20I%20was%20just%20pointing%20out%20differences%20between%20datasheet%20and%20pinmux%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1752222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028%20Pinmux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1752222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224496%22%20target%3D%22_blank%22%3E%40nybwc%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHope%20this%20post%20finds%20you%20well%2C%3C%2FP%3E%0A%3CP%3EThis%20post%20is%20to%20inform%20you%20that%20we%20keep%20working%20on%20this%20case.%3C%2FP%3E%0A%3CP%3ERegarding%20the%20%22Analog%22%20image%20in%20reference%20attached%20by%20you%2C%26nbsp%3Bthis%20signal%20does%20not%20appear%20since%20they%20are%26nbsp%3B%20for%20internal%20use%20as%20signal%20Description%20section%20of%20the%20datasheet%20indicates%20%22%20Internal%20Use%20Only%20%22.%20This%20signal%20is%20related%20to%20the%20analog%20part%20of%20the%20PLL%20and%20the%20internal%20regulator%20of%20the%20device%2C%20I%20highly%20recommend%20you%20to%20follow%20their%20respective%20note%20for%20the%20FA_ANALOG_PIN%26nbsp%3B%20signal.%22%26nbsp%3B15.%20These%20pins%20must%20be%20pulled%20to%20ground%20(GND).%22%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI'll%20keep%20you%20informed.%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3EHector%20Villarruel%20Silvadoray%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1743153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028%20Pinmux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1743153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHere%20are%20a%20few%20conflict%20I%20saw.%26nbsp%3B%20Not%20sure%20if%20this%20is%20all.%26nbsp%3B%20Basically%20I%20saw%20differences%20and%20I%20could%20trust%20the%20pinmux.%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1743097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028%20Pinmux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1743097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224496%22%20target%3D%22_blank%22%3E%40nybwc%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHope%20this%20post%20finds%20you%20well%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20specify%20which%20pinouts%20are%20incorrect%3F%3C%2FP%3E%0A%3CP%3EI%20have%20CodeWarrior%20version%2011.5.0%20and%20have%20verified%20several%20pins%20and%20they%20are%20correct.%3C%2FP%3E%0A%3CP%3EI%20am%20using%20the%20QorIQ%20LS1028A%2FLS1018A%2C%20Rev.%200%2C%2012%2F2019%20datasheet.%3C%2FP%3E%0A%3CP%3EAttached%20in%20the%20case%20there%20is%20an%20image%20in%20reference%20of%20one%20of%20the%20pins%20I%20have%20chosen.%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3EHector%20Villarruel%3C%2FP%3E%3C%2FLINGO-BODY%3E
