LS1012A Yocto Ubuntu root fs modules not loading by name
1,817 次查看
epoletaev
I'm compiling Yocto on kirkstone branch
repo init -u https://github.com/nxp-qoriq/yocto-sdk -b kirkstone -m ls-5.15.71-2.2.0_distro.xml
All seems working well except of kernel modules which I can load only by providing full file path to insmod command.
Is there a way to fix it?
4 回复数
1,796 次查看
khushbur
Hi @epoletaev
Can you please elaborate more which kernel module you want to load?
Please change your kernel configuration file accordingly.
Khsuhbu
1,789 次查看
epoletaev
Every module that listed in /boot/modules are not loading by name and only loading by full path
insmod any
Not found
insmod /boot/modules/full/path/any.ko
Loaded
Lets say for example usbserial.ko
1,763 次查看
khushbur
Hi @epoletaev
Can you please try with modprobe
Please run below command
sudo ln -s /path/to/module_name.ko /lib/modules/`uname -r`
sudo depmod -a
sudo modprobe module_name
Khushbu
1,753 次查看
epoletaev
That would work, but it is just workaround is there real fix for the issue?
