LS1012A DDR3L support list
2,035件の閲覧回数
AlanYL
The ddr chip used on the LS1012A development board are MICRON MT41K512M16HA-125
But our case will uses Winbond W638GU6QB series or ISSI IS43TR16512BL series.
How can I check the DDR chips supported with 1GB?
And how to support new DDR chips?
Thanks!
4 返答(返信)
1,999件の閲覧回数
yipingwang
Since the DRAM configuration is the same between the DRAM part numbers you have listed (Micron, Winbond, and ISSI), it should simply work with the existing board and existing setting/SW. no change is needed.
1,988件の閲覧回数
AlanYL
Hi Yipingwang,
Do we need to tune the DDR parameter and does LS1012A have the DDR tuning utility for reference?
Thanks!
1,970件の閲覧回数
yipingwang
You could use QCVS DDRv tool provided in CodeWarrior to do DDR optimization and validation.
1,945件の閲覧回数
AlanYL
Hi Yipingwang,
Got it! Thanks!
