LA9310 LLCP external interface signal description and AC timing table,
712件の閲覧回数
komitsudo
Trying to interface ADRV9002 with LA9310. Needs LA9310 LLCP external interface signal description and AC timing table,
LA9310 material does not provide enough detail to map:
  • LLCP lane count
  • exact serial word format
  • I/Q bit ordering
  • whether ADC/DAC samples are raw streams or encapsulated transactions
OR
Can we bypass or power down ADC and DAC.
or
how can we configure LA9310 interface with SSI LVDS compatible with ADRV9002
2 返答(返信)
652件の閲覧回数
Bio_TICFSL
No, the available LA9310 documentation does not provide enough information to directly map ADRV9002 SSI/LVDS onto the LA9310 LLCP interface. LA9310 documents do define the LLCP pins, link style, transaction types, and electrical/timing characteristics, and they also show that the internal ADC/DAC can be put into low-power modes. But I could not find documentation that specifies the LLCP details you asked for at the level needed for an ADRV9002 interoperability design: lane count beyond the single data+strobe pair per direction, exact end-to-end serial sample word format for I/Q streaming, explicit I/Q bit ordering on the LLCP pins, or any statement that LLCP is SSI-compatible
601件の閲覧回数
komitsudo
further if you can recommend any compatible zero IF or near zero IF RFIC for frequency 240 to 360MHz. . I am exploring LMS7002 but it becomes less useful without TSP. Or if you recommend without TSP then can I use LA9310 .
With LMS7002 internal TSP you normally get:
  • Digital upconversion/downconversion
  • Interpolation/decimation filtering
  • IQ correction
  • DC offset correction
  • Some gain control functions
  • Digital frequency shifting
  • Digital waveform shaping
or
I found CMX998 if other stuff as above mentioned possible inside LA9310 to achieve BPSK/QPSK/8PSK for low bandwidth channels like 5KHz and 25KHz for tx rx data rate 2.4 KB/s to 64KB/s only.
%3CLINGO-SUB%20id%3D%22lingo-sub-2382563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELA9310%20LLCP%E5%A4%96%E9%83%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%8A%E3%82%88%E3%81%B3AC%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A1%A8%E3%80%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELA9310%E3%81%A8ADRV9002%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3ELA9310%20LLCP%E5%A4%96%E9%83%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%A8AC%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A1%A8%3C%2FSPAN%3E%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELA9310%E7%B4%A0%E6%9D%90%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%E5%9C%B0%E5%9B%B3%E4%BD%9C%E6%88%90%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3ELLCP%E3%83%AC%E3%83%BC%E3%83%B3%E6%95%B0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E6%AD%A3%E7%A2%BA%E3%81%AA%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%AF%E3%83%BC%E3%83%89%E5%BD%A2%E5%BC%8F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EI%2FQ%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%81%94%E6%B3%A8%E6%96%87%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EADC%2FDAC%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%8C%E7%94%9F%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%8B%E3%82%AB%E3%83%97%E3%82%BB%E3%83%AB%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADC%E3%82%84DAC%E3%82%92%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%97%E3%81%9F%E3%82%8A%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%81%A3%E3%81%9F%E3%82%8A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EADRV9002%E5%AF%BE%E5%BF%9C%E3%81%AESSI%20LVDS%E3%81%A8LA9310%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%8B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LA9310%20LLCP%20external%20interface%20signal%20description%20and%20AC%20timing%20table%2C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20LA9310%20%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%AB%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ESSI%2FLVDS%20%E3%82%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E7%9B%B4%E6%8E%A5LA9310%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20LLCP%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%81%AB%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%99%E3%82%8BADRV9002%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%8D%81%E5%88%86%E3%81%AA%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%81%8C%E6%8F%90%E4%BE%9B%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ELA9310%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%81%AE%E6%96%87%E6%9B%B8%20%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20LLCP%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%83%94%E3%83%B3%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%83%AA%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%AB%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%82%BF%E3%82%A4%E3%83%97%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E9%9B%BB%E6%B0%97%E7%9A%84%E3%83%BB%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E7%89%B9%E6%80%A7%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%82%92%E5%AE%9A%E7%BE%A9%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%20%E5%86%85%E9%83%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%81%AEADC%2FDAC%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%82%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%83%A2%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%20%E3%82%8B%E3%81%93%E3%81%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E3%82%82%E7%A4%BA%20%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%97%E3%81%8B%E3%81%97%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EADRV9002%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%AE%E7%9B%B8%E4%BA%92%E9%81%8B%E7%94%A8%E6%80%A7%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%A8%AD%E8%A8%88%3C%2FSPAN%3E%20%20%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%20%20%E3%83%AC%E3%83%99%E3%83%AB%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%E5%8D%98%E4%B8%80%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%2B%E3%82%B9%E3%83%88%E3%83%AD%E3%83%9C%E3%82%92%E8%B6%85%E3%81%88%E3%81%9F%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%83%AC%E3%83%BC%E3%83%B3%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%95%B0%3C%2FSPAN%3E%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%9F%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ELLCP%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%AE%E8%A9%B3%E7%B4%B0%3C%2FSPAN%3E%E3%82%92%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%98%8E%E8%A8%98%E3%81%97%E3%81%9F%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%96%B9%E5%90%91%20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%94%E3%81%A8%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%83%9A%E3%82%A2%E3%80%81I%2FQ%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E7%94%A8%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%AD%A3%E7%A2%BA%E3%81%AA%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%83%84%E3%83%BC%E3%82%A8%E3%83%B3%E3%83%89%3C%2FSPAN%3E%E3%81%AE%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%83%AF%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%98%8E%E7%A4%BA%3C%2FSPAN%3E%E7%9A%84%E3%81%AA%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EI%2FQ%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%83%93%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E9%A0%86%E5%BA%8F%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ELLCP%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%83%94%E3%83%B3%3C%2FSPAN%3E%E3%80%81%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ELLCP%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ESSI%E4%BA%92%E6%8F%9B%3C%2FSPAN%3Ee%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%A7%E3%81%82%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E3%81%A8%E3%81%84%E3%81%86%E4%BB%BB%E6%84%8F%E3%81%AE%E6%96%87%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LA9310%20LLCP%20external%20interface%20signal%20description%20and%20AC%20timing%20table%2C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E5%91%A8%E6%B3%A2%E6%95%B0240%E3%80%9C360MHz%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%9F%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%82%BC%E3%83%ADIF%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%BB%E3%81%BC%E3%82%BC%E3%83%ADIF%E3%81%AERFIC%E3%82%92%E3%81%8A%E3%81%99%E3%81%99%E3%82%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%82%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82.LMS7002%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81TSP%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%81%82%E3%81%BE%E3%82%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%82%E3%82%8B%E3%81%84%E3%81%AFTSP%E3%81%AA%E3%81%97%E3%81%A7%E4%BD%BF%E3%81%86%E3%81%AE%E3%81%8C%E3%81%8A%E3%81%99%E3%81%99%E3%82%81%E3%81%AA%E3%82%89LA9310%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%82%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%3ELMS7002%E3%81%AE%E5%86%85%E9%83%A8TSP%E3%81%A7%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%EF%BC%8F%E3%83%80%E3%82%A6%E3%83%B3%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E8%A3%9C%E9%96%93%2F%E9%96%93%E5%BC%95%E3%81%8D%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EIQ%E8%A3%9C%E6%AD%A3%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EDC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E8%A3%9C%E6%AD%A3%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%B2%E3%82%A4%E3%83%B3%E5%88%B6%E5%BE%A1%E6%A9%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%B7%E3%83%95%E3%83%88%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E6%B3%A2%E5%BD%A2%E6%95%B4%E5%BD%A2%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%BB%96%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81LA9310%E5%86%85%E3%81%A75KHz%E3%82%8425KHz%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%BD%8E%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E5%90%91%E3%81%91%E3%81%AB%E3%80%81%E5%8F%97%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%EF%BC%882.4KB%2Fs%E3%81%8B%E3%82%8964KB%2Fs%E3%81%AE%E3%81%BF%EF%BC%89%E3%81%A7BPSK%2FQPSK%2F8PSK%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
