How to set SCHED_IDLE threading task in Linux ls1021a
2,727件の閲覧回数
jiye
Contributor V
I want to set a daily task(fstrim) with lowest priority, I am deciding to use SCHED_IDLE thread to trigger this task.
As I am using a tiny image in my distro and i dont have cron in the linux user space.
How am I able to implement this and where (should it be in the linux kernel?)
How can i trigger it on a daily basis.
ラベル(2)
タグ(2)
3 返答(返信)
2,645件の閲覧回数
yipingwang
2,645件の閲覧回数
jiye
Contributor V
2,645件の閲覧回数
yipingwang
You could download cron source code, cross compile it and copy to the target board.
