test log of "Seamless redundancy test case"
Search instead for
hittzt
Hi Yiping,
It seems that the switch tsn test logs did not include the " Seamless redundancy test case".
Would you please help to check it?
And if the logs available, please help to send me the logs.
Zhantao
hittzt
The U-Boot: 2019.04-gce862bb2d2 (Oct 17 2019 - 16:58:26 +0800) version on my local is also geted from LSDK19.09,
I will check the outcomes by change uboot to U-Boot : 2019.04-13622-g596d193 (Sep 13 2019 - 17:22:15 +0800) .
Zhantao
yipingwang
Hello Zhantao,
Please refer to the attached test log for Seamless redundancy.
Yiping
hittzt
Hi Yiping,
I compare the log you gave to my local. I see that,  you used
Board Version: C
and
while my local environment is
Board Version: A
and
My concern is that
 1, the difference between board version A and C
 2, to make the tsn work normal, if it has to use U-Boot : 2019.04-13622-g596d193 (Sep 13 2019 - 17:22:15 +0800)
Zhantao
yipingwang
LSDK 19.09 can run on both Rev A and Rev C board.
Please use u-boot from LSDK 19.09 to make TSN working normally.
hittzt
OK, Thanks for your reply.
I will check it.
Zhantao
