How to install LX2160ARDB_rev2 application for DPAA2 on RFS compiled by myself
m_kei
We are currently running ubuntu using the RFS files for lx2160ardb_rev2 published by NXP.”rootfs_lsdk2108_ubuntu_main_arm64.tgz” distributed at the following.
https://lsdk.github.io/components.html
This RFS is supposed to have a driver for DPAA2 Ethernet in lx2160ardb_rev2 by default, so that the board's LAN is also recognized and bin for DPAA2 (ls-main, etc.) is also available. However, the drivers and bin for DPAA2 are not included when RFS is generated with "flex-builder -i mkrfs".
Is it correct to specify "cetm", "eth-config" and "flib", which are published as "LSDK application" on the same github, by "-c" when executing mkrfs?
Which one should I install? Or do I need another means?
yipingwang
$ flex-builder -i mkrfs
$ flex-builder -c ceetm
$ flex-builder -c eth-config
$ flex-builder -c flib
$ flex-builder -i merge-component
$ flex-builder -i packrfs
yipingwang
m_kei
The eth-config is listed as being a configuration for the DPAA 1.x LSDK platform, is there any problem with LX2160ardb_rev2 with DPAA2?
yipingwang
No problem to install more packages in rootfs.
