How to configure transmission selection algorithm in ls1028ardb
yyu2
I need to check and configure the transmission selection algorithm on ls1028ardb board. Is there any command to check the current setting or to change the setting? What is the default setting (is it Strict Priority)?
thanks,
-Yi
yipingwang
Hello Yi Yu,
The default setting is Strict Priority.
You could use qbv to set based on time schedule, also could use qav to set credit.
No method to check directly.
Yiping
