How to configurate kernel and devicetree for g_serial?
byongkwankim
I am now in use the ls1021a-iot board. I wanted to use USB G_serial, modified the kernel and devicetree. But it had stopped during booting. Wondering take being done in order to use the g_serial?
     <kernel include Serial Gadget>
     <Devicetree>
U-Boot 2015.01+ls1+g3281947 (Apr 19 2016 - 14:59:34)
CPU:   Freescale LayerScape LS1021E, Version: 2.0, (0x87081120)
Clock Configuration:
       CPU0(ARMV7):1000 MHz,
       Bus:300  MHz, DDR:800  MHz (1600 MT/s data rate),
Reset Configuration Word (RCW):
       00000000: 0608000a 00000000 00000000 00000000
       00000010: 20000000 08407900 60025a00 21046000
       00000020: 00000000 00000000 00000000 20038000
       00000030: 20024800 881b1340 00000000 00000000
Board: LS1021AIOT
CPLD:  V2.3
I2C:   ready
DRAM:  1 GiB
Using SERDES1 Protocol: 32 (0x20)
MMC:   FSL_SDHC: 0
EEPROM: NXID v1
PCIe1: Root Complex no link, regs @ 0x3400000
PCIe2: Root Complex no link, regs @ 0x3500000
In:    serial
Out:   serial
Err:   serial
SEC0: RNG instantiated
SATA link 0 timeout.
AHCI 0001.0300 1 slots 1 ports ? Gbps 0x1 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc
scanning bus for devices...
Found 0 device(s).
SCSI:  Net:   eTSEC1 is in sgmii mode.
eTSEC2 is in sgmii mode.
Phy 4 not found
PHY reset timed out
eTSEC1 [PRIME], eTSEC2, eTSEC3
Hit any key to stop autoboot:  0
=> pri
baudrate=115200
bootargs=console=ttyLP0,115200 root=/dev/mmcblk0p1 rootfstype=ext4 rootwait
bootcmd=mmc rescan
bootdelay=3
eth1addr=00:04:9F:03:61:98
eth2addr=00:04:9F:03:61:99
ethact=eTSEC1
ethaddr=00:04:9F:03:61:97
ethprime=eTSEC1
fdt_high=0xffffffff
filesize=5620
initrd_high=0xffffffff
ipaddr=192.168.100.30
load_dtb=ext2load mmc :1 8f00000 boot/ls1021a-iot.dtb
load_kernel=ext2load mmc :1 82000000 boot/uImage
load_rootfs=ext2load mmc :1 88000000 rootfs_1_3
scsidevs=0
sdroot=setenv bootargs console=ttyS0,115200 root=/dev/mmcblk0p1 rootfstype=ext4 rootwait;setenv
bootcmd mmc rescan; run load_kernel load_dtb; bootm 82000000 - 8f000000
serverip=192.168.100.70
stderr=serial
stdin=serial
stdout=serial
Environment size: 752/131068 bytes
=> setenv load_dtb ext2load mmc :1 8f000000 boot/ls1021a-iot.dtb
=> setenv sdroot 'setenv bootargs console=ttyS0,115200 root=/dev/mmcblk0p1 rootfstype=ext4
rootwait;setenv bootcmd mmc rescan; run load_kernel load_dtb; bootm 82000000 - 8f000000'
=> saveenv
Saving Environment to MMC...
Writing to MMC(0)... done
=> run sdroot
4263832 bytes read in 292 ms (13.9 MiB/s)
21187 bytes read in 96 ms (214.8 KiB/s)
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-3.12.37-rt51+ls1+gaaa395f
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4263768 Bytes = 4.1 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 8f000000
   Booting using the fdt blob at 0x8f000000
   Loading Kernel Image ... OK
   Using Device Tree in place at 8f000000, end 8f0082c2
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Linux version 3.12.37-rt51+ls1+gaaa395f (kst@kst) (gcc version 4.8.3 20140401
(prerelease) (Linaro GCC 4.8-2014.04) ) #2 SMP Tue Apr 19 19:04:07 KST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=30c73c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Freescale LS1021A, model: LS1021A IOT Board
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] PERCPU: Embedded 8 pages/cpu @8107a000 s9344 r8192 d15232 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p1 rootfstype=ext4
rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1029272K/1048576K available (6017K kernel code, 306K rwdata, 1796K
rodata, 249K init, 210K bss, 19304K reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xc0800000 - 0xff000000   (1000 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .text : 0x80008000 - 0x807a99a8   (7815 kB)
[    0.000000]       .init : 0x807aa000 - 0x807e8480   ( 250 kB)
[    0.000000]       .data : 0x807ea000 - 0x808368e0   ( 307 kB)
[    0.000000]        .bss : 0x808368e8 - 0x8086b250   ( 211 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 12.50MHz (phys).
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: ARM arch timer >56 bits at 12500kHz, resolution 80ns
[    0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[    0.000000] Console: colour dummy device 80x30
[   57.505300] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00
BogoMIPS (lpj=125000)
[   57.505312] pid_max: default: 32768 minimum: 301
[   57.505501] Mount-cache hash table entries: 512
[   57.509851] CPU: Testing write buffer coherency: ok
[   57.510103] CPU0: update cpu_power 1024
[   57.510114] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[   57.510271] Setting up static identity map for 0x805b4b08 - 0x805b4b74
[   57.511202] CPU1: Booted secondary processor
[   57.511228] CPU1: update cpu_power 1024
[   57.511233] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[   57.511326] Brought up 2 CPUs
[   57.511345] SMP: Total of 2 processors activated (50.00 BogoMIPS).
[   57.511351] CPU: All CPU(s) started in HYP mode.
[   57.511357] CPU: Virtualization extensions available.
[   57.511969] devtmpfs: initialized
[   57.517727] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[   57.518100] regulator-dummy: no parameters
[   57.518344] NET: Registered protocol family 16
[   57.518821] DMA: preallocated 256 KiB pool for atomic coherent allocations
[   57.519133] cpuidle: using governor ladder
[   57.519141] cpuidle: using governor menu
[   57.519986] syscon 1570000.scfg: regmap [mem 0x01570000-0x0157ffff] registered
[   57.520689] irq: no irq domain found for /soc/uqe@2400000/qeic@80 !
[   57.520766] irq: no irq domain found for /soc/uqe@2400000/qeic@80 !
[   57.524162] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[   57.524171] hw-breakpoint: maximum watchpoint size is 8 bytes.
[   57.530234] bio: create slab <bio-0> at 0
[   57.532829] 3P3V: 3300 mV
[   57.533001] 2P5V: 2500 mV
[   57.533213] vgaarb: loaded
[   57.533462] SCSI subsystem initialized
[   57.533818] usbcore: registered new interface driver usbfs
[   57.533867] usbcore: registered new interface driver hub
[   57.533939] usbcore: registered new device driver usb
[   57.535744] i2c i2c-0: IMX I2C adapter registered
[   57.535931] pps_core: LinuxPPS API ver. 1 registered
[   57.535939] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
<giometti@linux.it>
[   57.535959] PTP clock support registered
[   57.536393] Advanced Linux Sound Architecture Driver Initialized.
[   57.537915] Switched to clocksource arch_sys_counter
[   57.537925] cfg80211: Calling CRDA to update world regulatory domain
[   57.537972] cfg80211: World regulatory domain updated:
[   57.537980] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   57.537988] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (2000 mBi, 0 mBm)
[   57.537996] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (2000 mBi, 0 mBm)
[   57.538004] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (2000 mBi, 0 mBm)
[   57.538013] cfg80211:   (5170000 KHz - 5250000 KHz @ 160000 KHz), (2000 mBi, 0 mBm)
[   57.538021] cfg80211:   (5250000 KHz - 5330000 KHz @ 160000 KHz), (2000 mBi, 0 mBm)
[   57.538029] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (2000 mBi, 0 mBm)
[   57.538037] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (2000 mBi, 0 mBm)
[   57.538044] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   57.543739] NET: Registered protocol family 2
[   57.544543] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[   57.544670] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[   57.544791] TCP: Hash tables configured (established 8192 bind 8192)
[   57.544888] TCP: reno registered
[   57.544900] UDP hash table entries: 512 (order: 2, 16384 bytes)
[   57.544945] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[   57.545209] NET: Registered protocol family 1
[   57.545432] RPC: Registered named UNIX socket transport module.
[   57.545442] RPC: Registered udp transport module.
[   57.545447] RPC: Registered tcp transport module.
[   57.545453] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   57.545782] hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
[   57.681813] NFS: Registering the id_resolver key type
[   57.681875] Key type id_resolver registered
[   57.681882] Key type id_legacy registered
[   57.681914] jffs2: version 2.2. (NAND) ⓒ 2001-2006 Red Hat, Inc.
[   57.682261] SGI XFS with security attributes, large block/inode numbers, no debug enabled
[   57.683460] msgmni has been set to 2010
[   57.684338] io scheduler noop registered
[   57.684348] io scheduler deadline registered
[   57.684377] io scheduler cfq registered (default)
[   57.884986] layerscape-pcie 3400000.pcie: phy link never came up
[   57.885114] layerscape-pcie 3400000.pcie: PCI host bridge to bus 0000:00
[   57.885128] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
[   57.885142] pci_bus 0000:00: root bus resource [mem 0x4040000000-0x407fffffff] (bus address
[0x40000000-0x7fffffff])
[   57.885154] pci_bus 0000:00: root bus resource [bus 00-ff]
[   57.885465] PCI: bus0: Fast back to back transfers disabled
[   57.885553] PCI: bus1: Fast back to back transfers enabled
[   57.885629] pci 0000:00:00.0: BAR 1: assigned [mem 0x4040000000-0x4043ffffff]
[   57.885645] pci 0000:00:00.0: BAR 0: assigned [mem 0x4044000000-0x4044ffffff]
[   57.885659] pci 0000:00:00.0: BAR 6: assigned [mem 0x4045000000-0x4045ffffff pref]
[   57.885670] pci 0000:00:00.0: PCI bridge to [bus 01]
[   58.085991] layerscape-pcie 3500000.pcie: phy link never came up
[   58.086091] layerscape-pcie 3500000.pcie: PCI host bridge to bus 0001:00
[   58.086105] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x0000-
0xffff])
[   58.086119] pci_bus 0001:00: root bus resource [mem 0x4840000000-0x487fffffff] (bus address
[   58.086130] pci_bus 0001:00: root bus resource [bus 00-ff]
[   58.086409] PCI: bus0: Fast back to back transfers disabled
[   58.086496] PCI: bus1: Fast back to back transfers enabled
[   58.086561] pci 0001:00:00.0: BAR 1: assigned [mem 0x4840000000-0x4843ffffff]
[   58.086576] pci 0001:00:00.0: BAR 0: assigned [mem 0x4844000000-0x4844ffffff]
[   58.086590] pci 0001:00:00.0: BAR 6: assigned [mem 0x4845000000-0x4845ffffff pref]
[   58.086600] pci 0001:00:00.0: PCI bridge to [bus 01]
[   58.086770] sii902x: probe of 0-0039 failed with error -1
[   58.086997] syscon 1570000.scfg: Failed to create debugfs directory
[   58.096553] Console: switching to colour frame buffer device 80x30
[   58.103117] fb0: fb device registered successfully.
[   58.103281] fb1: fb device registered successfully.
[   58.103427] fb2: fb device registered successfully.
[   58.103590] fb3: fb device registered successfully.
[   58.137328] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[   58.138710] 21c0500.serial: ttyS0 at MMIO 0x21c0500 (irq = 118, base_baud = 9375000) is a
16550A_FSL64
[   58.955566] console [ttyS0] enabled
[   58.959282] of_serial 2402200.ucc: clk or clock-frequency not defined
[   58.965694] of_serial: probe of 2402200.ucc failed with error -2
[   58.971955] serial: Freescale lpuart driver
[   58.976228] 2950000.serial: ttyLP0 at MMIO 0x2950000 (irq = 112, base_baud = 6250000) is a
FSL_LPUART
[   58.988588] brd: module loaded
[   58.994593] loop: module loaded
[   58.998076] ahci 3200000.sata: AHCI 0001.0300 1 slots 1 ports ? Gbps 0x1 impl platform mode
[   59.006390] ahci 3200000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc
[   59.014718] ahci 3200000.sata: port 0 is not capable of FBS
[   59.020791] scsi0 : ahci_platform
[   59.024274] ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x100 irq 133
[   59.034654] CAN device driver interface
[   59.039108] flexcan 2a70000.can: device registered (reg_base=c0834000, irq=158)
[   59.046818] flexcan 2a80000.can: device registered (reg_base=c0836000, irq=159)
[   59.054545] flexcan 2a90000.can: device registered (reg_base=c0838000, irq=160)
[   59.062268] flexcan 2aa0000.can: device registered (reg_base=c083a000, irq=161)
[   59.070155] libphy: Freescale PowerQUICC MII Bus: probed
[   59.075551] mdio_bus mdio@2d24000: cannot get PHY at address 0
[   59.081385] genirq: Setting trigger mode 8 for irq 197 failed (gic_set_type+0x0/0xfc)
[   59.089970] genirq: Setting trigger mode 8 for irq 197 failed (gic_set_type+0x0/0xfc)
[   59.098752] fsl-gianfar ethernet.4: enabled errata workarounds, flags: 0x4
[   59.116300] fsl-gianfar ethernet.4 eth0: mac: 00:04:9f:03:61:97
[   59.122204] fsl-gianfar ethernet.4 eth0: Running with NAPI enabled
[   59.128360] fsl-gianfar ethernet.4 eth0: RX BD ring size for Q[0]: 256
[   59.134852] fsl-gianfar ethernet.4 eth0: RX BD ring size for Q[1]: 256
[   59.141352] fsl-gianfar ethernet.4 eth0: TX BD ring size for Q[0]: 256
[   59.147845] fsl-gianfar ethernet.4 eth0: TX BD ring size for Q[1]: 256
[   59.154483] fsl-gianfar ethernet.5: enabled errata workarounds, flags: 0x4
[   59.171994] fsl-gianfar ethernet.5 eth1: mac: 00:04:9f:03:61:98
[   59.177884] fsl-gianfar ethernet.5 eth1: Running with NAPI enabled
[   59.184042] fsl-gianfar ethernet.5 eth1: RX BD ring size for Q[0]: 256
[   59.190542] fsl-gianfar ethernet.5 eth1: RX BD ring size for Q[1]: 256
[   59.197036] fsl-gianfar ethernet.5 eth1: TX BD ring size for Q[0]: 256
[   59.203538] fsl-gianfar ethernet.5 eth1: TX BD ring size for Q[1]: 256
[   59.210186] fsl-gianfar ethernet.6: enabled errata workarounds, flags: 0x4
[   59.227690] fsl-gianfar ethernet.6 eth2: mac: 00:04:9f:03:61:99
[   59.233595] fsl-gianfar ethernet.6 eth2: Running with NAPI enabled
[   59.239753] fsl-gianfar ethernet.6 eth2: RX BD ring size for Q[0]: 256
[   59.246246] fsl-gianfar ethernet.6 eth2: RX BD ring size for Q[1]: 256
[   59.252748] fsl-gianfar ethernet.6 eth2: TX BD ring size for Q[0]: 256
[   59.259253] fsl-gianfar ethernet.6 eth2: TX BD ring size for Q[1]: 256
[   59.265972] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[   59.272996] e1000: Copyright (c) 1999-2006 Intel Corporation.
[   59.278796] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[   59.284594] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
[   59.290538] PPP generic driver version 2.4.2
[   59.294915] PPP BSD Compression module registered
[   59.299612] PPP Deflate Compression module registered
[   59.304672] PPP MPPE Compression module registered
[   59.309450] NET: Registered protocol family 24
[   59.313904] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
[   59.320990] usbcore: registered new interface driver rtl8150
[   59.326668] usbcore: registered new interface driver asix
[   59.332077] usbcore: registered new interface driver ax88179_178a
[   59.338174] usbcore: registered new interface driver cdc_ether
[   59.344002] usbcore: registered new interface driver r815x
[   59.349499] usbcore: registered new interface driver net1080
[   59.355156] usbcore: registered new interface driver cdc_subset
[   59.361079] usbcore: registered new interface driver zaurus
[   59.366700] usbcore: registered new interface driver cdc_ncm
[   59.377938] ata1: SATA link down (SStatus 0 SControl 300)
[   59.572847] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   59.578349] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[   59.586138] xhci-hcd xhci-hcd.0.auto: irq 125, io mem 0x03100000
[   59.592258] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   59.599027] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   59.606211] usb usb1: Product: xHCI Host Controller
[   59.611071] usb usb1: Manufacturer: Linux 3.12.37-rt51+ls1+gaaa395f xhci-hcd
[   59.618090] usb usb1: SerialNumber: xhci-hcd.0.auto
[   59.623360] hub 1-0:1.0: USB hub found
[   59.627111] hub 1-0:1.0: 1 port detected
[   59.631201] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   59.636665] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[   59.644427] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[   59.651196] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   59.658386] usb usb2: Product: xHCI Host Controller
[   59.663237] usb usb2: Manufacturer: Linux 3.12.37-rt51+ls1+gaaa395f xhci-hcd
[   59.670254] usb usb2: SerialNumber: xhci-hcd.0.auto
[   59.675468] hub 2-0:1.0: USB hub found
[   59.679236] hub 2-0:1.0: 1 port detected
[   59.683613] usbcore: registered new interface driver cdc_acm
[   59.689253] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   59.697302] usbcore: registered new interface driver usb-storage
[   59.703459] usbcore: registered new interface driver usbserial
[   59.709311] usbcore: registered new interface driver usbserial_generic
[   59.715830] usbserial: USB Serial support registered for generic
[   59.721856] usbcore: registered new interface driver ftdi_sio
[   59.727596] usbserial: USB Serial support registered for FTDI USB Serial Device
[   59.735044] usbcore: registered new interface driver option
[   59.740624] usbserial: USB Serial support registered for GSM modem (1-port)
[   59.747656] usbcore: registered new interface driver zte_ev
[   59.753243] usbserial: USB Serial support registered for zte_ev
and freezing...
Tags (2)
