How to boot LS1088A from spi nor flash
Jackie19
Dear NXP support,
I am developing my ls1088a board based on the LS1088ARDB.
My board worked if boot from sdcard. So, I want to boot from nor flash.
I followed the link: https://community.nxp.com/t5/Layerscape-Knowledge-Base/LS1088ARDB-LS1088ARDB-PB-How-to-update-compos... by the steps:
1. Download composite firmware
2. Built-in the composite firmware into firmware that was flashed to sdcard
3. Boot my board from sdcard and enter the u-boot
4. In u-boot console, load composite firmware from sdcard to nor flash 0
5. Change switches to select boot the board from QSPI. But it has not any boot log in minicom, ...
Please help me verify the above steps.
Best Regards
Jackie19
Hi Oswalag,
I resolved the problem by using the kernel 5.15.
As I understand it, the reason is that the first blocks on my spi nor flash chip have a size of 32KB, while if using the erasing command on the old 5.4 kernel, it only supports erasing blocks of size 256KB.
Oswalag
The steps are correct, if you have any issues please let me know.
Jackie19
Hi Oswalag,
After step 5, I can't see any log.
Do you have an idea to debug this issue?
Oswalag
Maybe you had an issue in step 4,
please share a detailed explanation of all the steps you followed there.
Jackie19
Hi Oswalag,
%3CLINGO-SUB%20id%3D%22lingo-sub-2179112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20boot%20LS1088A%20from%20spi%20nor%20flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP%20support%2C%3CBR%20%2F%3EI%20am%20developing%20my%20ls1088a%20board%20based%20on%20the%20LS1088ARDB.%3CBR%20%2F%3EMy%20board%20worked%20if%20boot%20from%20sdcard.%20So%2C%20I%20want%20to%20boot%20from%20nor%20flash.%3CBR%20%2F%3EI%20followed%20the%20link%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape-Knowledge-Base%2FLS1088ARDB-LS1088ARDB-PB-How-to-update-composite-firmware-image%2Fta-p%2F1103848%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape-Knowledge-Base%2FLS1088ARDB-LS1088ARDB-PB-How-to-update-composite-firmware-image%2Fta-p%2F1103848%3C%2FA%3E%20by%20the%20steps%3A%3CBR%20%2F%3E1.%20Download%20composite%20firmware%3CBR%20%2F%3E2.%20Built-in%20the%20composite%20firmware%20into%20firmware%20that%20was%20flashed%20to%20sdcard%3CBR%20%2F%3E3.%20Boot%20my%20board%20from%20sdcard%20and%20enter%20the%20u-boot%3CBR%20%2F%3E4.%20In%20u-boot%20console%2C%20load%20composite%20firmware%20from%20sdcard%20to%20nor%20flash%200%3CBR%20%2F%3E5.%20Change%20switches%20to%20select%20boot%20the%20board%20from%20QSPI.%20But%20it%20has%20not%20any%20boot%20log%20in%20minicom%2C%20...%3C%2FP%3E%3CP%3EPlease%20help%20me%20verify%20the%20above%20steps.%3C%2FP%3E%3CP%3EBest%20Regards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20boot%20LS1088A%20from%20spi%20nor%20flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Oswalag%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI%20resolved%20the%20problem%20by%20using%20the%20kernel%205.15.%3CBR%20%2F%3EAs%20I%20understand%20it%2C%20the%20reason%20is%20that%20the%20first%20blocks%20on%20my%20spi%20nor%20flash%20chip%20have%20a%20size%20of%2032KB%2C%20while%20if%20using%20the%20erasing%20command%20on%20the%20old%205.4%20kernel%2C%20it%20only%20supports%20erasing%20blocks%20of%20size%20256KB.%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%2C%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20boot%20LS1088A%20from%20spi%20nor%20flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EMaybe%20you%20had%20an%20issue%20in%20step%204%2C%3C%2FP%3E%0A%3CP%3Eplease%20share%20a%20detailed%20explanation%20of%20all%20the%20steps%20you%20followed%20there.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2179691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20boot%20LS1088A%20from%20spi%20nor%20flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Oswalag%2C%3CBR%20%2F%3E%3CBR%20%2F%3EAfter%20step%205%2C%20I%20can't%20see%20any%20log.%3CBR%20%2F%3EDo%20you%20have%20an%20idea%20to%20debug%20this%20issue%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2179523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20boot%20LS1088A%20from%20spi%20nor%20flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThe%20steps%20are%20correct%2C%20if%20you%20have%20any%20issues%20please%20let%20me%20know.%3C%2FP%3E%3C%2FLINGO-BODY%3E
