How can I change the default serial of the u-boot?
2,756 次查看
2838219522
I want change the default serial console in the u-boot,but I can't learn the source code of u-boot of ls1021atwr.
标记 (1)
2,431 次查看
Pavel
Look at the Section 4.4.4.11 of NXP SDK 2.0-1703 documentation:
https://www.nxp.com/docs/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
Find the "LPUART console setting" in this Section.
Pavel Chubakov
2,432 次查看
Pavel
Pavel Chubakov
2,431 次查看
2838219522
Thank you ,Pavel.
May I use other serials expect uart0 and lpuart0?
