GPU on the LS1028A
GPU on the LS1028A
1,453件の閲覧回数
rhaas
I am using an LS1028A processor on an avoinics product. We do not need the GPU for the current project. I plan on turning off the GPU using a PBI command.
My question is about verifying if the GPU is actually off. Can you suggest a mechanism I can use to verify the GPU is actually off. This is needed for certification.
1,419件の閲覧回数
Oswalag
There isn't a status flag in hardware but you can disable the GPU by the
Device Disable Register 6 (DEVDISR6)
It is a R/W register so you can read it to verify that it is disabled.
