Failure on DPDMUX default interface configured when external traffic is available
dunk
Following procedure will cause error message from MC:
[E, qbman_rec_isr:391, QBMAN] QBMAN recoverable event 0x1000000
[E, dpmng_dump_rerr_fqid:1335, QBMAN] REL_FQ (FQ[0]) has 1 messages, dumping up to 16:
[E, dpmng_dump_rerr_fqid:1361, QBMAN] Message:
0x00125340: 2f930000 000000ab 00000000 00000000
0x00125350: 00000000 00000000 00000000 00000000
0x00125360: 2f180280 18000000 8a030000 00000000
0x00125370: 00000000 00000000 00000000 00000000
This error message can be produced by enabling/configuring the default interface of dpdmux instance and external traffic is available.
Case 1: DPL enable default interface
With DPL of following setting with 'default_if = <0x1>;'
dpdmux@1 {
    compatible = "fsl,dpdmux";
    options = "DPDMUX_OPT_CLS_MASK_SUPPORT", "DPDMUX_OPT_AUTO_MAX_FRAME_LEN";
    method = "DPDMUX_METHOD_CUSTOM";
    manip = "DPDMUX_MANIP_NONE";
    num_ifs = <0x2>;
    default_if = <0x1>;
Case 2: DPL not to enable default interface of DPDMUX
Option 'default_if = <0x1>;' is not set. But using dpdk to configure the default interface.
API 'dpdmux_if_set_default' is used for this.
Any suggestion to avoid such error?
Tags (3)
Oswalag
Hello.
Please share the MC version, BSP and kernel version, Processor and board used.
Regards.
dunk
I'm using Kernel: 5.15.71 and MC version: 10.38.1. BSP is based on LSDK21.08.
Tags (3)
Oswalag
The issue could be due to a software version incompatibility , please take a look into the LLDPUG, there is where MC 10.38.0 was validated, this with Kernel v6.1.55.
I recommend you to test again using the LLDP mentioned before building the images with Yocto.
Regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2269891%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFailure%20on%20DPDMUX%20default%20interface%20configured%20when%20external%20traffic%20is%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269891%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EFollowing%20procedure%20will%20cause%20error%20message%20from%20MC%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%5BE%2C%20qbman_rec_isr%3A391%2C%20QBMAN%5D%20QBMAN%20recoverable%20event%200x1000000%3CBR%20%2F%3E%5BE%2C%20dpmng_dump_rerr_fqid%3A1335%2C%20QBMAN%5D%20REL_FQ%20(FQ%5B0%5D)%20has%201%20messages%2C%20dumping%20up%20to%2016%3A%3CBR%20%2F%3E%5BE%2C%20dpmng_dump_rerr_fqid%3A1361%2C%20QBMAN%5D%20Message%3A%3CBR%20%2F%3E0x00125340%3A%202f930000%20000000ab%2000000000%2000000000%3CBR%20%2F%3E0x00125350%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x00125360%3A%202f180280%2018000000%208a030000%2000000000%3CBR%20%2F%3E0x00125370%3A%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EThis%20error%20message%20can%20be%20produced%20by%20enabling%2Fconfiguring%20the%20default%20interface%20of%20dpdmux%20instance%20and%20external%20traffic%20is%20available.%3C%2FP%3E%3CP%3ECase%201%3A%20DPL%20enable%20default%20interface%3C%2FP%3E%3CP%3EWith%20DPL%20of%20following%20setting%20with%20'default_if%20%3D%20%26lt%3B0x1%26gt%3B%3B'%3C%2FP%3E%3CP%3E--%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Edpdmux%401%20%7B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20compatible%20%3D%20%22fsl%2Cdpdmux%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20options%20%3D%20%22DPDMUX_OPT_CLS_MASK_SUPPORT%22%2C%20%22DPDMUX_OPT_AUTO_MAX_FRAME_LEN%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20method%20%3D%20%22DPDMUX_METHOD_CUSTOM%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20manip%20%3D%20%22DPDMUX_MANIP_NONE%22%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20num_ifs%20%3D%20%26lt%3B0x2%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3Bdefault_if%20%3D%20%26lt%3B0x1%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E--%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECase%202%3A%20DPL%20not%20to%20enable%20default%20interface%20of%20DPDMUX%3C%2FP%3E%3CP%3EOption%20'default_if%20%3D%20%26lt%3B0x1%26gt%3B%3B'%20is%20not%20set.%20But%20using%20dpdk%20to%20configure%20the%20default%20interface.%3C%2FP%3E%3CP%3EAPI%20'dpdmux_if_set_default'%20is%20used%20for%20this.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAny%20suggestion%20to%20avoid%20such%20error%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2269891%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS2%20Device%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20on%20DPDMUX%20default%20interface%20configured%20when%20external%20traffic%20is%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20using%20Kernel%3A%26nbsp%3B5.15.71%20and%20MC%20version%3A%2010.38.1.%20BSP%20is%20based%20on%20LSDK21.08.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20on%20DPDMUX%20default%20interface%20configured%20when%20external%20traffic%20is%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello.%3C%2FP%3E%0A%3CP%3EPlease%20share%20the%20MC%20version%2C%20BSP%20and%20kernel%20version%2C%20Processor%20and%20board%20used.%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2291352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20on%20DPDMUX%20default%20interface%20configured%20when%20external%20traffic%20is%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2291352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%0A%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThe%20issue%20could%20be%20due%20to%20a%20software%20version%20incompatibility%20%2C%20please%20take%20a%20look%20into%20the%20LLDPUG%2C%20there%20is%20where%20MC%2010.38.0%20was%20validated%2C%20this%20with%20Kernel%26nbsp%3Bv6.1.55.%3C%2FP%3E%0A%3CP%3EI%20recommend%20you%20to%20test%20again%20using%20the%20LLDP%20mentioned%20before%20building%20the%20images%20with%20Yocto.%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
