FIT image build error
jaikumarj
I am trying to create a FIT image for freescale ls1043ardb.
CMD: bitbake fsl-image-kernelitb
| install: cannot stat '/home/jaikumar/projects/freescale_LS1043A/Linux-LS1043A-SDK-V0.4-20150826-yocto/build_ls1043ardb_release/tmp/work/ls1043ardb-fsl-linux/fsl-image-kernelitb/1.0-r0/kernel-rdb.its': No such file or directory
| WARNING: /home/jaikumar/projects/freescale_LS1043A/Linux-LS1043A-SDK-V0.4-20150826-yocto/build_ls1043ardb_release/tmp/work/ls1043ardb-fsl-linux/fsl-image-kernelitb/1.0-r0/temp/run.do_deploy.32341:1 exit 1 from
|   install -m 644 /home/jaikumar/projects/freescale_LS1043A/Linux-LS1043A-SDK-V0.4-20150826-yocto/build_ls1043ardb_release/tmp/work/ls1043ardb-fsl-linux/fsl-image-kernelitb/1.0-r0/kernel-rdb.its /home/jaikumar/projects/freescale_LS1043A/Linux-LS1043A-SDK-V0.4-20150826-yocto/build_ls1043ardb_release/tmp/work/ls1043ardb-fsl-linux/fsl-image-kernelitb/1.0-r0/fsl-image-kernelitb-1.0
Please indicate what is going wrong.
Jaikumar
