Error in datasheet for LS1043
nikolaypuzanov
Hi, I am currently make a schematic symbol for the LS1043 and found a small mistake in the datasheet. Signal QSPI_A_DATA1/IFC_A23/IFC_WP2_B have a same pin number as GND021 (D12). Please fix it.
Pavel
You are right the Section QSPI in the Table 1 of the LS1043A Datasheet Rev.0 contains incorrect pin numbering for the IFC_A23 (QSPI_A_DATA1) signal. Previous parts of the Table 1 of the LS1043A Datasheet Rev.0 contain correct pin numbering for this the IFC_A23 (QSPI_A_DATA1) signal. Datasheet will be corrected.
Pavel Chubakov
Pavel
Pavel Chubakov
