Enabling CAAM in LS1043A Yocto
4,005件の閲覧回数
mobyrktr12
I want to use SEC interface of LS1043A on TQMBLS10XX to use with OpenSSL. I did the kernel configuration as in this page. After that, in /lib/modules/${uname -r}/modules.builtin I see these modules:
  • kernel/drivers/crypto/caam/error.ko
  • kernel/drivers/crypto/caam/caam.ko
  • kernel/drivers/crypto/caam/caam_jr.ko
  • kernel/drivers/crypto/caam/caamalg_desc.ko
  • kernel/drivers/crypto/caam/caamhash_desc.ko
But I can't see the line below in dmesg.
caam algorithms registered in /proc/crypto
タグ(3)
5 返答(返信)
3,893件の閲覧回数
yipingwang
You could use the attached Linux Kernel configuration file, which is the defconfig file for Linux Kernel 5.4.47 in LSDK 20.12 release.
3,957件の閲覧回数
yipingwang
Please configure CAAM as the following.
root@TinyLinux:~# zcat /proc/config.gz | grep CAAM
# CONFIG_CRYPTO_DEV_FSL_CAAM_DMA is not set
CONFIG_CRYPTO_DEV_FSL_CAAM_COMMON=y
CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API_DESC=y
CONFIG_CRYPTO_DEV_FSL_CAAM_AHASH_API_DESC=y
CONFIG_CRYPTO_DEV_FSL_CAAM_SECVIO=y
CONFIG_CRYPTO_DEV_FSL_CAAM=y
# CONFIG_CRYPTO_DEV_FSL_CAAM_DEBUG is not set
CONFIG_CRYPTO_DEV_FSL_CAAM_JR=y
CONFIG_CRYPTO_DEV_FSL_CAAM_RINGSIZE=9
# CONFIG_CRYPTO_DEV_FSL_CAAM_INTC is not set
CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API=y
CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API_QI=y
CONFIG_CRYPTO_DEV_FSL_CAAM_AHASH_API=y
CONFIG_CRYPTO_DEV_FSL_CAAM_PKC_API=y
CONFIG_CRYPTO_DEV_FSL_CAAM_RNG_API=y
# CONFIG_CRYPTO_DEV_FSL_CAAM_TK_API is not set
# CONFIG_CRYPTO_DEV_FSL_CAAM_RNG_TEST is not set
CONFIG_CRYPTO_DEV_FSL_CAAM_SM=y
CONFIG_CRYPTO_DEV_FSL_CAAM_SM_SLOTSIZE=7
CONFIG_CRYPTO_DEV_FSL_CAAM_SM_TEST=m
CONFIG_CRYPTO_DEV_FSL_CAAM_JR_UIO=y
CONFIG_CRYPTO_DEV_FSL_DPAA2_CAAM=y
3,933件の閲覧回数
mobyrktr12
I inserted config lines into defconfig in meta-tq/recipes-kernel/linux/linux-tq-5.4/tqmls10xxa. However when I execute zcat /proc/config.gz | grep CAAM on new image, I get the output below:
root@tqmls1043a-mbls10xxa:~# zcat /proc/config.gz | grep CAAM
3,874件の閲覧回数
mobyrktr12
I inserted these lines into defconfig in /media/pc_1309/Disk/poky/meta-tq/recipes-kernel/linux/linux-tq-5.4/tqmls10xxa directory. However, when I execute zcat /proc/config.gz | grep CAAM in new image, I get the result below:
3,872件の閲覧回数
mobyrktr12
I added these inside defconfig in meta-tq/recipes-kernel/linux/linux-tq-5.4/tqmls10xxa but some of them are not included in image as you can see below.
