DRAM Issue on LS1046A
2,276 次查看
Faizanbaig
Hi ,
I have initialized DRAM using QCVS Tool and was using DRAM successfully till date ,But suddenly I see that DRAM is currently not initializing properly Like it should have 0XDEADBEEF as initial value but I see many memory location having some random initial value .
 For reference I have pasted the Trace32 memory dump of DRAM  below.
Please check and let me know why this is happening?
Thanks ,
Faizan
4 回复数
2,228 次查看
SebastianG
Hello @Faizanbaig,
Could you please tell me which board are you using, and their memory part number?
Sebastian
2,221 次查看
Faizanbaig
The board is LS1046 ARDB
2,217 次查看
SebastianG
Hello @Faizanbaig,
Could you please share with me the following details:
  • Your RCW file configuration
  • Your DDR configuration in CodeWarrior
  • Can you do a QCVS DDR validation and share with a log with the results?
Sebastian
2,229 次查看
SebastianG
Hello @Faizanbaig,
I would like to inform you that I'm working on your question, I will let you know as soon as I have an update.
Thank you so much for your patience
Sebastian
