DPAA2 DPDK RTE FLOW
DPAA2 DPDK RTE FLOW
379 次查看
dehml
I'm trying to create DPDK RTE FLOW on a DPAA2 SolidRun LX2160A Clearfog CX without success.
Is it normal that it doesn't work ?
What could be done to make it works ?
I'm quite newbie with NXP DPAA2 and NXP in general, so can you please explain your technical words.
Thanks.
testpmd> flow create 0 ingress pattern eth / ipv4 / end actions rss queues 0 1 end types ip ipv4 end / end
DPAA2_NET: Add entry(0) to table(0) failed
DPAA2_NET: Create flow failed (-22)
port_flow_complain(): Caught PMD error type 1 (cause unspecified): cause: 0xfffff340a300, unknown: Operation not permitted
标记 (5)
336 次查看
yipingwang
Check how the DPNI behind your DPDK port was created. From the Linux shell on the board:
restool dprc show dprc.1 --resources          # find the dpni.X your DPDK port uses
restool dpni info dpni.X                      # look at the "options" line and "num_queues"
If options shows DPNI_OPT_NO_FS , or does not show DPNI_OPT_HAS_KEY_MASKING , that's your problem.
Recreate the DPNI with the right options. Either edit dynamic_dpl.sh (or the environment it reads — on NXP LSDK it is typically the DPNI_OPTIONS variable) so the create call looks like this :
restool dpni create \
    --options=DPNI_OPT_HAS_KEY_MASKING \
    --num-queues=2 \
    --num-tcs=1 \
    --container=dprc.2
Key points:
    • Do not include DPNI_OPT_NO_FS .
    • Do include DPNI_OPT_HAS_KEY_MASKING .
    • Set --num-queues to at least the number of queues your RSS action references (you asked for queues 0 and 1, so ≥ 2).
Then attach that DPNI to the DPDK container ( restool dprc assign … ) and rerun testpmd.
If you use a static DPL file , add the same to the dpni@X node :
 dpni@1 {
  options = "DPNI_OPT_HAS_KEY_MASKING";
    num_queues = <2>;
and reflash the DPL via fsl_mc apply dpl … in U‑Boot.
Sanity‑check with a simpler rule first. Before RSS, confirm plain steering works:
 testpmd> flow create 0 ingress pattern eth / ipv4 src is 10.0.0.1 / end \
                     actions queue index 1 / end
If this passes but the RSS variant still fails, the remaining issue is queue count / distribution config, not the DPNI options.
359 次查看
db16122
https://www.nxp.com/webapp/Download?colCode=DPAA2UM&location=null
DPAA2 User Manual could be helpful
BTW. what kind of BSP or SDK is used? Any resource from official websit?
%3CLINGO-SUB%20id%3D%22lingo-sub-2399170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDPAA2%20DPDK%20RTE%20%E6%B5%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20DPAA2%20SolidRun%20LX2160A%20Clearfog%20CX%20%E4%B8%8A%E5%88%9B%E5%BB%BA%20DPDK%20RTE%20FLOW%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%E5%AE%83%E4%B8%8D%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E6%98%AF%E6%AD%A3%E5%B8%B8%E7%9A%84%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E8%AE%A9%E5%AE%83%E5%A5%8F%E6%95%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%B9%20NXP%20DPAA2%20%E5%92%8C%20NXP%20%E4%BA%A7%E5%93%81%E9%83%BD%E6%AF%94%E8%BE%83%E9%99%8C%E7%94%9F%EF%BC%8C%E6%89%80%E4%BB%A5%E6%82%A8%E8%83%BD%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%8A%80%E6%9C%AF%E6%9C%AF%E8%AF%AD%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Etestpmd%26gt%3B%20flow%20create%200%20ingress%20pattern%20eth%20%2F%20ipv4%20%2F%20end%20actions%20rss%20queues%200%201%20end%20types%20ip%20ipv4%20end%20%2F%20end%0ADPAA2_NET%3A%20Add%20entry(0)%20to%20table(0)%20failed%0ADPAA2_NET%3A%20Create%20flow%20failed%20(-22)%0Aport_flow_complain()%3A%20Caught%20PMD%20error%20type%201%20(cause%20unspecified)%3A%20cause%3A%200xfffff340a300%2C%20unknown%3A%20Operation%20not%20permitted%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DPAA2%20DPDK%20RTE%20FLOW%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E6%A3%80%E6%9F%A5%20DPDK%20%E7%AB%AF%E5%8F%A3%E8%83%8C%E5%90%8E%E7%9A%84%20DPNI%20%E6%98%AF%E5%A6%82%E4%BD%95%E5%88%9B%E5%BB%BA%E7%9A%84%E3%80%82%3C%2FSTRONG%3E%E4%BB%8E%E6%9D%BF%E8%BD%BD%E7%9A%84Linux%20shell%E4%B8%AD%EF%BC%9A%3C%2FP%3E%0A%3CP%3Erestool%20dprc%20show%20dprc.1%20--resources%20%23%20%E6%9F%A5%E6%89%BE%E6%82%A8%E7%9A%84%20DPDK%20%E7%AB%AF%E5%8F%A3%E4%BD%BF%E7%94%A8%E7%9A%84%20dpni.X%20%E6%96%87%E4%BB%B6%3C%2FP%3E%0A%3CP%3Erestool%20dpni%20info%20dpni.X%20%23%20%E6%9F%A5%E7%9C%8B%E2%80%9Coptions%E2%80%9D%E8%A1%8C%E5%92%8C%E2%80%9Cnum_queues%E2%80%9D%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E9%80%89%E9%A1%B9%E6%98%BE%E7%A4%BA%20DPNI_OPT_NO_FS%EF%BC%8C%E6%88%96%E8%80%85%3CSTRONG%3E%E4%B8%8D%3C%2FSTRONG%3E%E6%98%BE%E7%A4%BA%20DPNI_OPT_HAS_KEY_MASKING%EF%BC%8C%E9%82%A3%E5%B0%B1%E6%98%AF%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%80%89%E9%A1%B9%E9%87%8D%E6%96%B0%E5%88%9B%E5%BB%BA%20DPNI%E3%80%82%3C%2FSTRONG%3E%E5%8F%AF%E4%BB%A5%E7%BC%96%E8%BE%91%20dynamic_dpl.sh%20%E6%96%87%E4%BB%B6%E3%80%82%EF%BC%88%E6%88%96%E8%80%85%E5%AE%83%E8%AF%BB%E5%8F%96%E7%9A%84%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E2%80%94%E2%80%94%E5%9C%A8NXP%20LSDK%E4%B8%AD%EF%BC%8C%E5%AE%83%E9%80%9A%E5%B8%B8%E6%98%AFDPNI_OPTIONS%E5%8F%98%E9%87%8F%EF%BC%89%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%88%9B%E5%BB%BA%E8%B0%83%E7%94%A8%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3Erestool%20dpni%20%E5%88%9B%E5%BB%BA%20%5C%3C%2FP%3E%0A%3CP%3E--options%3DDPNI_OPT_HAS_KEY_MASKING%20%5C%3C%2FP%3E%0A%3CP%3E--num-queues%3D2%20%5C%3C%2FP%3E%0A%3CP%3E--num-tcs%3D1%20%5C%3C%2FP%3E%0A%3CP%3E--container%3Ddprc.2%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E7%82%B9%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E4%B8%8D%E8%A6%81%E5%8C%85%E5%90%AB%3C%2FSTRONG%3EDPNI_OPT_NO_FS%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E%E8%AF%B7%E5%8C%85%E5%90%AB%3C%2FSTRONG%3EDPNI_OPT_HAS_KEY_MASKING%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CUL%3E%0A%3CLI%3E%E5%B0%86%20--num-queues%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E8%87%B3%E5%B0%91%E4%B8%8E%E6%82%A8%E7%9A%84%20RSS%20%E6%93%8D%E4%BD%9C%E5%BC%95%E7%94%A8%E7%9A%84%E9%98%9F%E5%88%97%E6%95%B0%E9%87%8F%E7%9B%B8%E5%90%8C%E7%9A%84%E9%98%9F%E5%88%97%E6%95%B0%E9%87%8F%EF%BC%88%E6%82%A8%E8%A6%81%E6%B1%82%E9%98%9F%E5%88%97%200%20%E5%92%8C%201%EF%BC%8C%E5%9B%A0%E6%AD%A4%20%E2%89%A5%202%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FUL%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E5%B0%86%E8%AF%A5%20DPNI%20%E9%99%84%E5%8A%A0%E5%88%B0%20DPDK%20%E5%AE%B9%E5%99%A8%EF%BC%88restool%20dprc%20assign%20%E2%80%A6%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%20testpmd%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20DPL%20%E6%96%87%E4%BB%B6%3C%2FSTRONG%3E%EF%BC%8C%E8%AF%B7%E5%B0%86%E5%85%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%20dpni%40X%20%E8%8A%82%E7%82%B9%EF%BC%9A%3C%2FP%3E%0A%3CP%3Edpni%401%20%7B%3C%2FP%3E%0A%3CP%3Eoptions%20%3D%20%22DPNI_OPT_HAS_KEY_MASKING%22%3B%3C%2FP%3E%0A%3CP%3E%E9%98%9F%E5%88%97%E6%95%B0%E9%87%8F%20%3D%20%26lt%3B2%26gt%3B%3B%3C%2FP%3E%0A%3CP%3E...%3C%2FP%3E%0A%3CP%3E%7D%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E9%80%9A%E8%BF%87%20U-Boot%20%E4%B8%AD%E7%9A%84%20fsl_mc%20apply%20dpl%20%E2%80%A6%20%E9%87%8D%E6%96%B0%E5%88%B7%E5%86%99%20DPL%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E5%85%88%E7%94%A8%E6%9B%B4%E7%AE%80%E5%8D%95%E7%9A%84%E8%A7%84%E5%88%99%E8%BF%9B%E8%A1%8C%E5%90%88%E7%90%86%E6%80%A7%E6%A3%80%E9%AA%8C%E3%80%82%3C%2FSTRONG%3E%E5%9C%A8%E5%AE%89%E8%A3%85RSS%E4%B9%8B%E5%89%8D%EF%BC%8C%E8%AF%B7%E7%A1%AE%E8%AE%A4%E6%99%AE%E9%80%9A%E8%BD%AC%E5%90%91%E5%8A%9F%E8%83%BD%E6%98%AF%E5%90%A6%E6%AD%A3%E5%B8%B8%EF%BC%9A%3C%2FP%3E%0A%3CP%3Etestpmd%26gt%3B%20flow%20create%200%20ingress%20pattern%20eth%20%2F%20ipv4%20src%20is%2010.0.0.1%20%2F%20end%20%5C%3C%2FP%3E%0A%3CP%3E%E6%93%8D%E4%BD%9C%E9%98%9F%E5%88%97%E7%B4%A2%E5%BC%95%201%20%2F%20%E7%BB%93%E6%9D%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%AD%A4%E6%96%B9%E6%B3%95%E9%80%9A%E8%BF%87%E4%BD%86%20RSS%20%E5%8F%98%E4%BD%93%E4%BB%8D%E7%84%B6%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%88%99%E5%89%A9%E4%BD%99%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E9%98%9F%E5%88%97%E8%AE%A1%E6%95%B0%2F%E5%88%86%E5%8F%91%E9%85%8D%E7%BD%AE%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20DPNI%20%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DPAA2%20DPDK%20RTE%20FLOW%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DDPAA2UM%26amp%3Blocation%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DDPAA2UM%26amp%3Blocation%3Dnull%3C%2FA%3E%3C%2FP%3E%3CP%3EDPAA2%20%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E9%97%AE%E4%B8%80%E4%B8%8B%EF%BC%8C%E4%BD%A0%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E7%A7%8DBSP%E6%88%96SDK%EF%BC%9F%E5%AE%98%E6%96%B9%E7%BD%91%E7%AB%99%E4%B8%8A%E6%9C%89%E7%9B%B8%E5%85%B3%E8%B5%84%E6%BA%90%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
