DDR4 clock (MCK) termination
2,232 次查看
trondwang
Hi NXP, in the reference design LS1043ARDB-PA/PB the termination resistor (R470 and R468) is 36 ohm for the differential clock.
The termination resistor for the single ended signals of the address bus/control  (R186+..) is 39 ohm.
Why do you use a lower resistance value for the differential signal.than for the adress bus/ control bus?
regards Trond Inge Wang
标签 (1)
1 回复
2,084 次查看
ufedor
The termination circuit was simulated and optimized for the specific layout using HyperLynx.
Similar method is recommended for new designs.
